chrissev2 Samba Member
Posted: Sat Oct 29, 2022 8:20 pm Post subject: Wheel size versus maximum speed |
So interesting experience this weekend.
I tried out some 17 inch wheels on the diesel Vanagon (1.9AAZ with a 3.27 RP automatic tranny).
The wheels took the tire height from 22.7 inches up to just over 25 inches.
So I figured, that is only about 2.5 inches in tire height. This couldn't make all that much of a difference.
The difference, though, was quite a lot.
The Vanagon would not go past 80km/hr and had trouble getting there. It lost all of its power.
The "sweet spot" in the transmission, where it shifted up from second to third at just past 60km/hr, and had power all the way up to about 110km/hr, was gone.
It is amazing how much difference wheel size makes on these old vans. When I put the 14 inch wheels with the 185 60 14s back on it again, the power was restored and it was the old Vanagon again, able to get up to about 110km/hr without difficulty (and struggle past that, but I usually don't go past 110km/hr as it is an old van (1986) and I don't really like how it sounds going past that).
I guess these things were meant to be run on 14 inch rims. Everyone will tell you different, but larger wheels in my experience meant all my power was gone, I could hardly get it to 80km/hr and it was a horrible driving experience. _________________ 2024 GLI Jetta 6spd manual
2023 VW Atlas 3.6 VR6 Highline
1978 Volkswagen super beetle convertible
1992 Eurovan 2.5 5spd westfalia |
jimf909 Samba Member
Posted: Sat Oct 29, 2022 8:35 pm Post subject: Re: Wheel size versus maximum speed |
Experience is a good teacher.
Keep in mind that the tire dimensions determine the revolutions per mile and the change in gearing you experienced. Wheel size has less to do with revolutions per mile because a high profile tire on a 14" wheel can have a greater circumference than a low profile tire on a 16" wheel.
Experiment with different wheel/tire combinations here:
https://www.tacomaworld.com/tirecalc
Regardless, larger tire diameters can rob a Vanagon of its zip. _________________ - Jim
| Butcher wrote: |
| This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
DuncanS Samba Member
Posted: Sun Oct 30, 2022 6:32 am Post subject: Re: Wheel size versus maximum speed |
This is the size you would need. I don't even know if such a size exists.
Duncan |
jlrftype7 Samba Member
Posted: Sun Oct 30, 2022 7:57 am Post subject: Re: Wheel size versus maximum speed |
I kept the stock 25” overall diameter in mind when swapping to 15” rims from the stock 14” rims on our ‘84 1.9.
I’d watched too many people put lifts and over sized tires on a stock vehicle over the years for off roading, only to be surprised at what their larger tires got for them when daily driving on the road.
Then, they start talking about final drive changes….
It is a wake up call when you drive a modified vehicle sometimes.  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10356 Location: N. Idaho
Posted: Sun Oct 30, 2022 9:30 am Post subject: Re: Wheel size versus maximum speed |
Chris,
Thanks for being open and honest about your experience. As most know, for decades I have been an advocate for stock rims and tire sizes to get the most out of your Vanagon. But there are always people who've spent $3000 on new larger rims and over size tires that insist they are getting better ride, better MPG, better traction, and even that their hair is growing better.
The loss of power (and braking power!) is the ratio of the new diameter vs the old. Yours was over 10% so you had a loss of both braking and acceleration power of 10% on a car already in marginal territory for power.
Thanks for providing a real life experience all the young whippersnappers can see and read... _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Sun Oct 30, 2022 9:44 am Post subject: Re: Wheel size versus maximum speed |
Yes, it does happen.
Keep in mind that wheel size really has nothing to do with this. It's overall tire diameter that affects power and braking. You can have 16" wheels with smaller diameter tires that would be the same as stock. _________________ 89 Westy 2.1 Auto |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10158 Location: Where?
Posted: Sun Oct 30, 2022 10:20 am Post subject: Re: Wheel size versus maximum speed |
Power = Torque X RPMs
A larger diameter tire reduces engine RPMs for a given speed and that reduction in RPMs means that the engine will produce a proportionately lower power for that given speed. The max power that the engine will produce at a given RPM is unchanged, you have just changed the RPMs for all given speeds. In other words, the power that the engine produced at 45 MPH, is now what the engine will produce at a higher speed (e.g. 50 MPH). That can certainly have a significant effect as wind resistance increases exponentially with increases in speed. Given the Vanagon's relatively poor aerodynamics and large frontal area, the effect of wind resistance is more dramatic than it is for most vehicles and because of that, it is remarkably easy to overgear these vehicles and reduce top speed and performance for no actual gain. |
Posted: Sun Oct 30, 2022 11:33 am Post subject: Re: Wheel size versus maximum speed |
| ?Waldo? wrote: |
| ....as wind resistance increases exponentially with increases in speed. Given the Vanagon's relatively poor aerodynamics and large frontal area, the effect of wind resistance is more dramatic than it is for most vehicles. . |
Wind resistance goes up by the square of the speed. Each 10 MPH is 10 times that of the lower speed.
Duncan |
VicVan  Samba Member
Joined: July 01, 2015 Posts: 2007 Location: Vancouver Island, BC
Posted: Sun Oct 30, 2022 1:32 pm Post subject: Re: Wheel size versus maximum speed |
Weight of the turning object (the wheel, i.e. rim+tire) can also affect performance. I don't know if its significant compared to a difference in overall diameter.
What is the weight difference between a stock wheel (14 in) and a 16 in wheel? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Joined: January 01, 2007 Posts: 18000 Location: sticksville, ct.
Posted: Sun Oct 30, 2022 1:34 pm Post subject: Re: Wheel size versus maximum speed |
| IdahoDoug wrote: |
Chris,
loss of power (and braking power!) |
may want to watch this:
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
fxr Samba Member
Joined: December 07, 2014 Posts: 2709 Location: Bay area CA
Posted: Sun Oct 30, 2022 2:06 pm Post subject: Re: Wheel size versus maximum speed |
| DuncanS wrote: |
| ?Waldo? wrote: |
And that means the power needed is proportional to the *cube* of the speed. 10% more speed needs 33% more power. _________________ Jim Crowther
Vespa GTS 300
atomatom Samba Member
Joined: May 15, 2012 Posts: 1911 Location: in an 84 Westy or Bowen Island, BC
Posted: Sun Oct 30, 2022 2:12 pm Post subject: Re: Wheel size versus maximum speed |
i have 16" rims but the same tire diameter as stock, so my 16" tires have much shorter sidewalls. net result is same power but a lot more stability. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
Posted: Sun Oct 30, 2022 2:37 pm Post subject: Re: Wheel size versus maximum speed |
| atomatom wrote: |
| i have 16" rims but the same tire diameter as stock, so my 16" tires have much shorter sidewalls. net result is same power but a lot more stability. |
What size are your tires? I wear 205 65 16s and they are about 5% larger in diameter than stock.
Duncan |
Alaskaberrys  Samba Member
Joined: June 19, 2016 Posts: 1085 Location: SE Alaska
Posted: Sun Oct 30, 2022 2:39 pm Post subject: Re: Wheel size versus maximum speed |
| skills@eurocarsplus wrote: |
| IdahoDoug wrote: |
Chris,
Very informative video. Definitely worth a watch - helped flip my understanding of the relationship of brake friction and tire friction to stopping power. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
do.dah Samba Member
Joined: August 27, 2015 Posts: 874 Location: Washington
Posted: Sun Oct 30, 2022 2:56 pm Post subject: Re: Wheel size versus maximum speed |
| VicVan wrote: |
What is the weight difference between a stock wheel (14 in) and a 16 in wheel? |
When my stock, 14 inch tires wore-out on my factory alloy wheels, I scored a set of factory alloy Audi (speedline brand) 15 inch wheels. Et required spacers.
After I got load rated, 205/70/15 pirelli tires mounted up, I weighed them, along with the spacers, and compared them to the 14inch tire/wheel assembly.
The Audi's, even with spacers, weighed about 2 lbs less.
I'm not sure about steel wheel weights, but, if you look at the Vanagon factory alloy wheels, they are basically a thick, solid disk with a coupla small cut-outs to give the impression of 5 spoke wheels.
My current 16 inch factory alloy MB wheels with correct et, and 205/65-16 load rated nokians, weigh the same as my 15inch Audi's. |
VicVan  Samba Member
Posted: Sun Oct 30, 2022 3:35 pm Post subject: Re: Wheel size versus maximum speed |
Thanks for these figures. So weight is not a factor, or at best it helps... _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Sun Oct 30, 2022 4:49 pm Post subject: Re: Wheel size versus maximum speed |
| IdahoDoug wrote: |
Chris,
Thanks for providing a real life experience all the young whippersnappers can see and read... |
This is very true.
I have now tried larger rims and tires for a taller tire (just over 25 inches in height, as opposed to the stock 22.7 inches).
With what speed I could get (not much, would not go over 80km/hr) I noted that the braking was not as good, the handling was very wobbly and uncertain and the power of course was completely gone.
The transmission shifted like it didn't know what to do. Back and forth from second to third, like it was lost and couldn't find its place.
I think VW was right with the 14 inch rims.
A lot of people will disagree, but that is my experience now that I have tried a taller tire set up. It did not work at all. _________________ 2024 GLI Jetta 6spd manual
do.dah Samba Member
Posted: Sun Oct 30, 2022 4:53 pm Post subject: Re: Wheel size versus maximum speed |
| I think by the mid to late 80's, no vehicle manufacturer was using 14 inch wheels on their trucks/vans besides VW. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12438 Location: Santa Cruz, CA
Posted: Sun Oct 30, 2022 4:57 pm Post subject: Re: Wheel size versus maximum speed |
| chrissev2 wrote: |
You put bigger tires on a taller freeway flier R&P trans. Your gear alterations in addition to the tire size were too much, I wasn't the tires. |
Posted: Mon Oct 31, 2022 6:44 am Post subject: Re: Wheel size versus maximum speed |
| syncrodoka wrote: |
| chrissev2 wrote: |
Probably true.
I had to change the RP so the 3spd auto would work with the AAZ. The 4.09 RP in the stock Vanagon 3spd is too low for the AAZ.
I am guessing the tall wheels combined with the 3.27 RP was the problem.
It is just amazing how much difference 2.5 inches makes in tire height. The vanagon literally becomes undriveable. It is a huge difference. _________________ 2024 GLI Jetta 6spd manual
