sjt_711 Samba Member
Posted: Wed Jun 02, 2021 9:11 am Post subject: Anyone have One of These?? |
I just bought a '95 EVC and it's frigging sweet, I love it.
Drove it several hours home after buying, opened the hood and noticed the secondary air injection air check valve was all burned up.
So I'm searching now for one of these and have had zero luck. Does anybody out there have a parts vehicle or one of these laying around?
Thanks!! |
wannabecamper Samba Member
Joined: May 09, 2019 Posts: 227 Location: Sunnyside, US
Posted: Wed Jun 02, 2021 9:32 am Post subject: Re: Anyone have One of These?? |
That is the check valve for the secondary air injection system. The part number is 037 131 367. It is hard to come by, but search with part number and you may be able to find it. |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2724 Location: East Nassau, NY
Posted: Wed Jun 02, 2021 2:35 pm Post subject: Re: Anyone have One of These?? |
If that part is melted then the combination valve is probably bad and stuck open letting exhaust blow through it. there's a good chance it also ruined the air pump too. |
TheOneTrueQuux Samba Member
Posted: Thu Jun 03, 2021 7:27 am Post subject: Re: Anyone have One of These?? |
sjt_711 wrote: |
Thanks!! |
There's a NOS one on ebay in Latvia right now.
https://www.ebay.com/itm/202637378329?epid=9015280994&hash=item2f2e210319:g:wLwAAOSwa9dgjMWo
But as others have said, this didn't melt on its own, find the cause of this happening before you install a new one or it'll be ruined in short order.
Also, there are likely other similar parts that can be substituted. Other VWs from the same time period likely have a similar valve that can be made to work. |
Posted: Thu Jun 03, 2021 10:56 am Post subject: Re: Anyone have One of These?? |
There no emissions standards for where I live. Seems like I could just bypass the entire secondary air injection system and never look back. Anyone have thoughts on that? |
Posted: Fri Jun 04, 2021 4:15 pm Post subject: Re: Anyone have One of These?? |
If you disconnect the secondary air injection pump electrical connector, then you will get a CEL. But if you just disconnect check valve and plug all vacuum lines and holes, then you may be good. You will probably need a filter on the SAI pump intake side though.
If you don't mind the CEL, remove all SAI parts, plug all the holes, and call it done. |
Posted: Fri Jun 04, 2021 4:28 pm Post subject: Re: Anyone have One of These?? |
I'll look around for a generic check valve for now. There is no CEL at the moment and the van runs great. I just can't see spending a rediculous amount of time and money on a mediocre system that works for a few minutes on start-up. I wish I knew I knew what electrical specs the ECM was looking for on the silly SAI system cause I could absolutely design something to satisfy it if I knew exactly what the ECM needed. |
Posted: Tue Nov 08, 2022 1:24 pm Post subject: Re: Anyone have One of These?? |
xoo00oox wrote: |
Adding to this thread long after the fact to add a part number that may be of use.
Pierburg W0133-1833370-APG is ALMOST the same as the combo valve that the Eurovan uses. The only difference is the clocking of the housing. It's readily available, and it's trivial to loosen the crimps and rotate the housing to match the Eurovan specific part, then re-crimp with a vice grips. |
AlexandMary Samba Member
Posted: Thu Nov 17, 2022 11:19 am Post subject: Re: Anyone have One of These?? |
wannabecamper wrote: |
Do you know if the system throws an engine light if the SAI doesn't work? Especially the pump?
Thanks. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2931 Location: North Carolina
Posted: Thu Nov 17, 2022 12:20 pm Post subject: Re: Anyone have One of These?? |
AlexandMary wrote: |
Thanks. |
Yes. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Thu Nov 17, 2022 1:47 pm Post subject: Re: Anyone have One of These?? |
mikemtnbike wrote: |
Thanks. |
Yes. |
It will also do it if the solenoid that supplies vacuum to the two vacuum controlled valves fails. That solenoid will fail if the hot side valve (name?) diaphragm has a hole in it. Hot humid exhaust will cause corrosion in the solenoid. |
volkybus Samba Member
Joined: November 03, 2013 Posts: 486 Location: CASTLETON VT USA
Posted: Thu Apr 13, 2023 5:34 pm Post subject: Re: Anyone have One of These?? |
Mine looks like that - I took one off my parts van .93 mv luckily the new one didn't get burned but if the new one is hooked up to the valven the engine stalls so I have it partially hooked up with a t fitting & it seems to be fine..Any thoughts anybody?? Bill VT & PR |
