miniT2 Samba Member
Posted: Wed Nov 30, 2022 8:48 am Post subject: JC Whitney Cam specs |
Hello. I have an 1835 engine in my street buggy. It has a cam from JC Whitney from the mid to late 70's. If my memory is correct, the grind was 286 duration and 410 lift. Does anyone have an old catalog or can cross reference the grind to a brand and part?
The engine has stock DP with 44IDFs. It goes like stink if you spin it...I'm thinking I'd like more low end. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15599 Location: Deep in the 405
Posted: Wed Nov 30, 2022 9:02 am Post subject: Re: JC Whitney Cam specs |
JC Whitney did not grind cams, they just re-packaged and sold somebody else's cams. It could be a reground stock cam. My guess it is an Engle W-110
I'm guessing the 44 IDF's are too big. If you want more bottom HP you may need smaller carbs or at least smaller venturies in the 44's _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Wed Nov 30, 2022 9:29 am Post subject: Re: JC Whitney Cam specs |
miniT2 wrote: |
If it says AP-2 or AP-3, then we ground it. We sold thousands and thousands of cams to JC Whitney _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2872 Location: HdG, MD & NJ
Posted: Wed Nov 30, 2022 10:16 am Post subject: Re: JC Whitney Cam specs |
I always thought they were Scat cams. I installed a few back in the day.
_________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
miniT2 Samba Member
Posted: Wed Nov 30, 2022 10:57 am Post subject: Re: JC Whitney Cam specs |
Thanks! That's exactly what I was looking for. I have the Super Street Eliminator and my memory is not as bad as I feared.  |
&Dan Samba Member
Posted: Wed Nov 30, 2022 11:12 am Post subject: Re: JC Whitney Cam specs |
Sheeesh...I recall well the day the reground crank/bearing combo from JCWhitney showed up, after the crank in my old 40-horse snapped in half, circa 1981.
That's where you got parts if you lived in, say, South Dakota.
Filled out the order form, sent a money order, waited a month.
Mem-o-ries... |
Bonesberg55 Samba Member
Posted: Wed Nov 30, 2022 4:34 pm Post subject: Re: JC Whitney Cam specs |
I remember getting a reground crank with bearings from JCW for $39.95 for my 40 hp in 1975. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5300 Location: Atlanta,Michigan
Posted: Wed Nov 30, 2022 5:21 pm Post subject: Re: JC Whitney Cam specs |
I warned a guy about buying a 'Cheap' CW crank from J.C, witless, he didn't listen ,It became a two piece a month after the build  _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
BFB Samba Member
Posted: Sat Dec 03, 2022 8:08 am Post subject: Re: JC Whitney Cam specs |
I used to love looking at those catalogs _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7825 Location: Videbaek Denmark
Rickf1985 Samba Member
Posted: Sat Dec 03, 2022 9:32 am Post subject: Re: JC Whitney Cam specs |
ah, Seeing that page brings back memories!!!! Everything in that catalog added horsepower, and I mean EVERYTHING, They swore by it.  |
Posted: Sat Dec 03, 2022 9:38 am Post subject: Re: JC Whitney Cam specs |
Its too bad that W & Company evolved into a glorified chain-type store that sells wiper blades and air fresheners. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6137 Location: CONGERS, N.Y.
Clatter Samba Member
Joined: September 24, 2003 Posts: 7769 Location: Santa Cruz
Posted: Sat Dec 03, 2022 10:47 am Post subject: Re: JC Whitney Cam specs |
My Dad used to get the Whitney catalog.
It was always kind of a joke even back then.
Snake oil and low prices; carnival barker salesmanship.
Can remember being like 12 years old and looking at those very items.
Thinking how one day I'm going to build me a fast bug with all the cool stuff...  _________________ Bus Motor Build
It does not exist! |
Posted: Sat Dec 03, 2022 12:58 pm Post subject: Re: JC Whitney Cam specs |
I wish I had ordered some of those horizontal sweep gauges. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Posted: Sat Dec 03, 2022 3:34 pm Post subject: Re: JC Whitney Cam specs |
They certainly could pack a ton of crap on each page. And this was LONG before Chinese junk was here. This was good old fashioned Made in USA junk.
And there is not one of you out there that did not buy something from them, we all did. If you say you didn't then you are lying or you grew up under a rock and never had a car or a mailbox! |
Posted: Sat Dec 03, 2022 3:50 pm Post subject: Re: JC Whitney Cam specs |
3rd & 4 th close ratio gears ,Didn't last the weekend at the Dunes stripped them  _________________ 'Black Ice'Drag Buggy 'Turbo'
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1615 Location: The South Zone
Posted: Sat Dec 03, 2022 4:41 pm Post subject: Re: JC Whitney Cam specs |
Rickf1985 wrote: |
I'm pretty sure I STILL have parts that I got from JC Whitney on my car! _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
