1969 Ghia coupe door hinge oil plugs
panard2013
panard2013 is offline
PostPosted: Thu Oct 06, 2022 1:59 pm    Post subject: 1969 Ghia coupe door hinge oil plugs Reply with quote
Does anyone know if there is an outlet for the tiny clear oil plugs for the door hinges I have one good one but the top one turned to dust trying to pry it out of the hole
kingkarmann Premium Member
kingkarmann is offline
PostPosted: Thu Oct 06, 2022 2:16 pm    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
I wasn’t aware the door hinges have an oil plug.
Maybe a P.O. application?
"Who died and made you king of anything?"
Sara Bareilles
"Ego is the anesthesia that deadens the pain of Stupidity."
Rick Rigsby
"Motion is lotion, the rest is rust"
Anonymous
Era Vulgaris
Era Vulgaris is online now
PostPosted: Thu Oct 06, 2022 3:07 pm    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
I'm with kingkarmann. What oil plug?
Pics would help.
Maybe it's a Zeibart rustproofing plug in the door pillar?
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica
Previously owned:
98 Porsche Boxster, silver, 2.5L overhauled by Jake Raby -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
panard2013
PostPosted: Thu Oct 06, 2022 3:53 pm    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
Pics would help.
No these also came with later bugs
Marcdeb Premium Member
Marcdeb is offline
PostPosted: Thu Oct 06, 2022 5:02 pm    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
Here's a picture from my unmolested 68 Regatta Blue Ghia Vert. I had not seen these before either. Both upper and lower hinges have them. I wonder if they were used from the very first year? Hopefully they are available some where. This thread may cause a run on them. Smile
Yes I realize she needs new door check rods! Embarassed
Marc
68 Karmann Ghia Cabrio
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
panard2013
PostPosted: Thu Oct 06, 2022 7:06 pm    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
I have an an all original 1969 coupe. Has 43 original miles on it. I remember buying those things for my wife’s 69 vert. at the local dealership. I’ve had no luck finding the clear ones.
Marcdeb is offline
PostPosted: Thu Oct 06, 2022 7:22 pm    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
What a gorgeous Ghia. Love the color. That's Sunset, L31k isn't it? I bought a front trunk lid and a single door from a 69 Sunset convertible. They had been in storage for years. Now I'm storing them.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Marcdeb is offline
PostPosted: Thu Oct 06, 2022 7:30 pm    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
I just looked at your other threads and I think you meant to say 43,000 miles. Not 43 miles right? I believed the low number as your car does look new. The paint and the chrome look perfect.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
panard2013
PostPosted: Fri Oct 07, 2022 6:11 am    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
Yes, 43,000 miles. When I put new brakes on the Ghia I found this on the backside of beauty ring
Compare original window crank to repro
Marcdeb is offline
PostPosted: Fri Oct 07, 2022 7:11 am    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
My beauty rings have the same number on them. They look good but not perfect as they've been marred from someone trying to pry the hubcaps off with screw drivers or some thing similar.
68 has the same window cranks with the chrome on either side of the black center. I believe 68 and 69 are the only two years that Ghias had those window cranks. The went to all black in 1970. My 68 convertible only has 22,900 miles. It was mostly parked from the 1980's until I bought it 5 months ago. There's a link to the thread under my signature.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
panard2013
PostPosted: Fri Oct 07, 2022 8:22 am    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
The beauty rings on my 69 are not perfect but very presentable. Yes those window cranks are two years only. I love your ‘68 ‘vert by the way, what’s not to love. I think I will replace the main door seal on both doors, they are pretty decayed from time. My car was sold in Klamath Falls at the local VW dealership. It never left the area. Klamath Falls is high desert and very dry plus the car was always garaged. The only seals I changed were the two front grills and the seal around the logo in front. Everything else as far as I can tell is original.
Marcdeb is offline
PostPosted: Fri Oct 07, 2022 8:36 am    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
That's a great find! Especially in that one year only color. Yours is the first time I've seen a complete car in the color "Sunset". I think it's pretty rare. It's nice to have all the history with a car.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
panard2013
PostPosted: Fri Dec 09, 2022 10:36 pm    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
Today I decided to remove the door panel on my ‘69 coupe. There was a door panel clip or some object caught and was threatening to penetrate through the upholstery. I removed the panel and removed the clip. I was amazed by how clean the door interior was. I guess whoever removed it the first time dislodged the clip. I’ve never seen this type of clip and there were no rubber grommets. Check out how clean every thing is. Also no plastic vapor barrier, is this normal. The panel has a type of wax paper protecting it.
Marcdeb is offline
PostPosted: Sat Dec 10, 2022 4:25 am    Post subject: Re: 1969 Ghia coupe door hinge oil plugs Reply with quote
I've seen this exact paper installed the same way on a set of original door panels. This is the vapor barrier that was used during this time period. It's a fragile paper but mine had these same fiber threads as well.
As to the rubber boots for the clips I'm sure it changed over the years, but no rubber clips on later during this period. I bought a full set of the rubber boots for my 71. It had no interior at all when I bought it but the description for the plugs all say "for Beetles and Ghias", then later discovered that's not true. Frustrating but seller descriptions are not always correct.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
