Who offers the best engine gasket set for the 2.1?
Page: Previous  1, 2
DanHoug
DanHoug is offline
PostPosted: Mon Dec 19, 2022 3:07 pm    Post subject: Re: Who offers the best engine gasket set for the 2.1? Reply with quote
i just measured 4 water jacket seals... 2 V-R and 2 unknown but look identical to the V-R in all machining marks. all 4 measured at 0.220".
according to the memo, this exceeds the typical gasket thickness of "Commonly (.145"-.170")". i have not measured my head to water jacket clearance but if we assume for a moment that it is the typical .130"-.150" clearance, my resulting crush on the rubber gasket is .070"- .090" which exceeds the memo suggested crush of .020"- .030".
all very curious.
-dan
www.thefixitworkshop.com
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Tue Dec 20, 2022 9:35 am    Post subject: Re: Who offers the best engine gasket set for the 2.1? Reply with quote
So then.. The floppy gaskets are poor, seemably, from all sources. Would there be a point to finding the right thickness of gasket rubber, tracing the outline, and cutting it flat, and just forgo the U shape? I'm just about to do some engine work; what thoughts are out regarding why the continued use of a gasket that has the original shape if it is already going to be a 5k mi disaster?
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Dec 20, 2022 10:04 am    Post subject: Re: Who offers the best engine gasket set for the 2.1? Reply with quote
There as a guy back in the days here who cut silicone gaskets out of a red sheet I recall. That's a vague memory....
I think the U shape is essential so it doesn't migrate away under pressure
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Dec 20, 2022 10:10 am    Post subject: Re: Who offers the best engine gasket set for the 2.1? Reply with quote
hardway wrote:
I have one leg in VAG products and one leg in BMW land. Reinz is reviled by BMW techs and for good reason. Reinz BMW valve cover gaskets leak profusely. Oil filter housing profile gaskets also. Now I only use genuine BMW gaskets on any rubber profile gasket. The same with Mercedes. Only OE or for the old ones Bruss,
Elring used to be the standard. Two years ago I was in a pinch for a Valvetronic motor gasket on a BMW valve cover job. I ordered an Elring. The Elring package contained a Reinz gasket.
I talked to the Elring rep at the BIMRs meeting about it. Unlike Reinz, Elring is still owned by the founding family. Most of the mittlestand firms have been sold to the very large international corporations. The rep told me that when they have a lack of a product that they will repackage other brands. Next time I see the Elring rep I will discuss this with him. I will say that I still use Elring gasket and seals in many applications and have no trouble with them.
I have probably done less than 30 Waterboxer head jobs in my time. I have measured every one and never found one to be outside the desired crush. But I am extremely averse to machining those cylinder heads. I have done my share of machining in the past and getting both cylinder bores fly cut square and to the same depth and then the same on the water jacket sealing surface is asking a bit much.
I am certain that I have used Elring in this application before. Something to consider is that there are a lot of counterfeit parts around. I have found them in the WorldPac supply chain. But They never made OE waterboxer parts in China. So that means that it is unlikely that counterfeits are making their way into the OE supplier pipelines. But on Amazon? FCP? Etc.. But this is the second thread on The Samba with failing gaskets branded Elring.
I have to pull an old original VW gasket out to verify but I'm almost certain that Bruss was the manufacturer of the rubber jacket gasket for VW. I didn't know that was a brand until today, I thought it was short for Brussels, where it was made Laughing
I bought a NOS DPH seal kit made in Germany recently, it had a Bruss gasket in it.
DanHoug
DanHoug is offline
PostPosted: Tue Dec 20, 2022 10:27 am    Post subject: Re: Who offers the best engine gasket set for the 2.1? Reply with quote
Rocky Jennings confirmed with me that the set he sent was V-R and he said he's never had a problem with them. so there's that!
i won't machine the heads to decrease my gasket squish and i haven't been able to get anything other than V-R so i'm just going with what i have but with The Right Stuff as sealant.
i would be kinda interesting to try making a urethane mold and casting silicone water jacket seals. seems like it would be a frustrating process to get right between the deep channel and the durometer needed.
-dan
SlalomVan
SlalomVan is offline
PostPosted: Thu Jan 05, 2023 3:46 pm    Post subject: Re: Who offers the best engine gasket set for the 2.1? Reply with quote
I finally got around to replacing the leaking water jacket seal on the passenger side of my van. If you remember, the rebuilt engine has less than 5K miles on it. I had to replace the drivers side water jacket seal after it failed about 1K miles ago. The first failure on the drivers side was exactly the same as this time. Unfortunately I am getting really good and tearing off the heads while the engine is still in the van. Shocked
The gasket set I used when I originally rebuilt the motor was the Elring brand. The new water jacket seals I installed were Victor Reinz. The following photos show what happened.
Seal bulging out between block and head
Split seal still attached to block
Split in seal
Cracks in seal when bent. These show up all along the seal, not just the in the corners where the splits occurred.
I will be contacting the vendor I purchased the set from and let them know that I think these parts are flawed and prone to failure. I am not a professional engine-builder by any stretch of the imagination. I take my time, keep things very clean, measure, weigh and measure again and in general feel that I am pretty meticulous when putting these motors together. After looking closely at these parts and having similar back to back failures, I am confident the failures were not from how this motor went together.
A word of advice to all who take on an engine rebuild. Check your parts before you install them. A lot of these NOS parts are old and have been sitting on a shelf or in a box for a long time. They should all be checked and thrown out if they are old. Despite looking and feeling okay before I installed these water jacket seals, I should have looked at these parts more closely for cracks and potential issues.
Live and learn!
1989 Vanagon GL - 2.1 (White - "Northlake" Totaled/Gone)
1988 Vanagon GL Wolfsburg (Orly Blue - "Poulsbo" - Sold)
1989 Vanagon G - 2.1 (White - "Kingston") - Full rebuild underway - Last on the road in 1997
mark-hans
mark-hans is offline
PostPosted: Fri Jan 06, 2023 3:02 am    Post subject: Re: Who offers the best engine gasket set for the 2.1? Reply with quote
Oh, Oh, this horror story continues (now years). We haven't had a water jacket seal problem in a long while, but again, we are short of VR, so we will be using Elring. I only hope that the quality control is better than 4 years ago. This jacket seal is essential to be correct and a bit flexible. Apart from the sea itself, there are various trains of thought of how to fit them. Sometimes I do wonder if this has an effect? I use a VERY small amount of sealant on both sides of the seal. Not a lot.... truly a small spread. When using copper fire rings, I tend to retighten the head bolts 10 minutes after the last round. If everything sets correctly I hope this problem doesn't return. Truth is, I don't actually know. I imagine these jacket seals are made by an independant company? supplying VR and Elring?
Mark, Amsterdam.
ZsZ
ZsZ is offline
PostPosted: Fri Jan 06, 2023 3:25 am    Post subject: Re: Who offers the best engine gasket set for the 2.1? Reply with quote
Probably that is the case. They are made on the same production line somewhere "east" from the contemporary self destructing rubber.
Elring, Victor Reinz and Ajusa are the only brands available. I would say the rubber parts are made in spain in all these kits
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
Page: Previous  1, 2
Page 2 of 2
