humfrydog Trained Attack Dog
Joined: June 27, 2003 Posts: 529 Location: reno,nevada
Posted: Wed Oct 22, 2003 11:53 am Post subject: is this for real?how small are those tires? |
i may be getting a 71 panel. if i do i want to lower it. i was cruising through the gallery for height,wheel tire combos options and found this photo. how small are those tires? its on the ground and dosen"t look like the wheel wells are even tubbed! https://www.thesamba.com/vw/gallery/pix/24070.jpg _________________ Somebody stop the world spinning.I think I am getting dizzy.
OGJHC Nevada chapter |
VW Addict Samba Salesman
Posted: Wed Oct 22, 2003 11:56 am Post subject: |
Ya, I dont see any fake thing about it. They must have higered the beam, for the tires to be able to turn. They dont seem like small tires, but I am sure they cutt out the holes, or else it would hit the inside fenders...
Posted: Wed Oct 22, 2003 12:18 pm Post subject: |
ok what does "higered the beam" mean?you can see the top of the tire so i dont follow what you mean about cutting the holes? no i am not being a jerk,worse a "newbee to buses" what about the front vents? i see a lot of them shaved.what were they originally for? and what about turn signals? please educate a newbee. _________________ Somebody stop the world spinning.I think I am getting dizzy.
llamas1 Samba Member
Joined: July 27, 2003 Posts: 237 Location: Houston, TX
Posted: Wed Oct 22, 2003 12:59 pm Post subject: |
Reminds me of my brother in-laws Honda Civic. He couldn't go over speed bumps without grinding something. |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Wed Oct 22, 2003 1:00 pm Post subject: |
I think he meant Highered the beam. Raise the whole thing up higher. As for the vent. It is for fresh air to the inside of the bus. The turnsignals must be those little light looking things at the bottom. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
vwcampin Samba Member
Posted: Wed Oct 22, 2003 1:12 pm Post subject: |
To me it looks like the dog legs and doors have been modified. The distance between the bottom of the door at the top of the dog leg to the bottom of the window is way less than stock....... |
NeverHadaBeetle Samba Member
Joined: October 08, 2002 Posts: 442 Location: Missouri
Posted: Wed Oct 22, 2003 1:26 pm Post subject: |
Since air bags are adjustable then my vote says the bus probably can't be driven at this height. All the cutting, tubbing, heightening, etc. are done so you can actually drive the bus while it's nearly on the ground. Notice how the rear engine vents appear to be filled in? I wonder what that's all about. |
WAVEPIMP Samba Member
Joined: February 13, 2002 Posts: 156 Location: Houston, Texas
Posted: Wed Oct 22, 2003 1:43 pm Post subject: |
Its probobly body droped and cut the area around the doors so it could be lowered to the ground with the bags. It looks like the offset of those rims make the tire stick out even with the side of the bus, so they had to modify the front door area so it would lay down that low.
A body drop, is when they cut around the entire inside of the bus about 2 or 3 inches from the sides and lower the body down from the pan as far as they need and use channel iron to fill the gap and weld it all back together. If you look at the seat inside the front windsheild you notice the back of it sits higher than it would normally. When doing a body drop you loose some of your head room. I'm sure they had to raise the rear engine compartment deck up to make up the difference as well from lowering the body down. |
Posted: Wed Oct 22, 2003 1:45 pm Post subject: |
Posted: Wed Oct 22, 2003 1:46 pm Post subject: |
Posted: Wed Oct 22, 2003 1:48 pm Post subject: |
Posted: Wed Oct 22, 2003 1:51 pm Post subject: |
Man my computer stuck that post out there 5 times. Sorry guys. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Wed Oct 22, 2003 1:54 pm Post subject: |
The body was cut so the wheel wells could be raised higher then it was bagged to lay it on the ground. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
Posted: Thu Oct 23, 2003 1:05 am Post subject: |
i see what you mean. the doors look shorter and seats do look higher. that makes sense now. _________________ Somebody stop the world spinning.I think I am getting dizzy.
UncleBob Grease Midget
Joined: August 21, 2002 Posts: 2862 Location: Northeast Florida
Posted: Thu Oct 23, 2003 11:12 am Post subject: |
Isn't that 'channelling'? _________________ OG JHC
don't worry, the ciggaret is fake. |
busrocker71 Samba Member
Joined: September 30, 2003 Posts: 333 Location: Welcome to the OC
Posted: Sat Oct 25, 2003 1:38 pm Post subject: |
im still wondering about the air vents! how in the heck does that thing stay cool? crazy set up...looks dope though.. _________________ 1971 BayWindow Deluxe+SoCal=Good Times
_______________________________ |
vwjosh6070 Driveway Camper
Joined: August 24, 2003 Posts: 2802 Location: not camping...
Posted: Sat Oct 25, 2003 10:11 pm Post subject: |
i think the body is fiberglass or something. how the heck do they get in and out of that thing? no door handles. as for the air vents, i have no idea. that bus is wacky, and it is very scary in my opinion..but whatever floats your boat! ") _________________ josh, AKA "the infamous josh"
1973 Transporter "Floyd"
****Wheres my old bus?! 1967 Montgomery Ward Camper****
KI4MXO |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Sat Oct 25, 2003 10:30 pm Post subject: |
UncleBob wrote: |
Isn't that 'channelling'? |
Thats when cut a section out of the middle I believe?
As far as the other dude with the stuck computer that posted a bunch of times you can delete some of them. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
