rogertj Samba Member
Joined: October 07, 2008 Posts: 505 Location: Tijuana, Baja California. Mexico
Posted: Sun Aug 11, 2019 7:52 pm Post subject: Looking for that adapter plate thread for Subaru conversion |
Does anyone remember the conversion thread where some one does his own adapter plate? I remember seeing it but did not save it and did not find it. Thanks in advance. _________________ Roger
Had a Carbureted ABA after engoing the heck out of it now going for ABA 2.0 Jetta EFI ill put a garrett in to the tin can later or maybe go electric?
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12122 Location: Port Manteau
Posted: Sun Aug 11, 2019 8:35 pm Post subject: Re: Looking for that adapter plate thread |
While you may be looking for some specific example of a DIY adapter, there are literally hundreds of them out there on the intertubes. Adapters are very engine specific, so you need to clearly identify which engine you're trying to swap. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Aug 12, 2019 1:48 am Post subject: Re: Looking for that adapter plate thread |
Zeitgeist 13 wrote: |
While you may be looking for some specific example of a DIY adapter, there are literally hundreds of them out there on the intertubes. Adapters are very engine specific, so you need to clearly identify which engine you're trying to swap. |
Hello Zeigest 13 It would be from a 2002 Subaru Outback Manual transmision donor car to a 1985 VW Vanagon with Manual Transmition I remember seeing it here in the Vanagon Forums made first the drawings with some type of cardboard sheeting for the pattern and then the person transfered that drawing to the machining of the plate. Dont remember where I saw it, last night i gave it my 3rd search and saw the small car bell housing thread vs the adapter plate setup and the SC looked very atractive because of the components needed vs the components needed with the adapter plate that use non subaru components.
Hope that someone gives me a hint on where to look. Thanks again! _________________ Roger
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17255 Location: Retired South Florida
Posted: Mon Aug 12, 2019 6:45 am Post subject: Re: Looking for that adapter plate thread |
Hello, a hand made engine adapter using cardboard templates, would be a challenge. The input shaft on a vw transaxle is off center. You also need to take into account flywheel clearance, starter depth, flywheel tooth, pressure plate location relative to the vanagon cross shaft and release bearing.
Not saying you can’t do it though. I would have remembered a thread like that. If I were mounting a Subaru to a vanagon, my choice would be the reverse ring and pinion with the Subaru transaxle. Vanagon transmissions are becoming as rare as hens teeth and have under design problems when torque and hp are increased over stock. _________________ ☮️ |
Posted: Mon Aug 12, 2019 9:46 am Post subject: Re: Looking for that adapter plate thread |
MarkWard wrote: |
Not saying you can’t do it though. I would have remembered a thread like that. If I were mounting a Subaru to a vanagon, my choice would be the reverse ring and pinion with the Subaru transaxle. Vanagon transmissions are becoming as rare as hens teeth and have under design problems when torque and hp are increased over stock. |
i definitely agree 100% with you Mark on the trans-axle "rareness" I did look in to the subarugears videos and information and that would be the cherry in the cake for sure. at 1,900 dollars sounds expensive in my country but would make a perfect assembly. Well actually 1200 because of the small car bell housing price (takig in to consideration that the bell housing set up sounded the most atractive because you go with stock components on the subaru tranny)
Taking about the posibilities of making one adapter plate I found this videos last night checked them out maybe it works.
Talking about subarugears or what ever vendor there is out there, other than the ring and pinion to the subaru box what other components are needed for this conversion? Does any one have a price list? Ill shoot an email to subarugears and let you guys know but if someone all ready did the conversion it will be greatly be appreciated it if you can give your experience and knowledge (and some photos of course ) on this tranny conversion.
Ill look around in the forum to see what can I find.
Thanks in advance! _________________ Roger
