vwhelmot Samba Member
Joined: May 04, 2006 Posts: 618 Location: united kingdom
Posted: Wed Jun 24, 2015 8:24 am Post subject: |
I plan on having it ready for paint by the end of this year, I`m about two months away , maybe less in finishing the panel work then its onto rubbing it down.. Hopefully back from paint in the spring and then the rest of the year for assembly, finishing in time for VoWo 2017 .That's the plan. :)
PS The motor in your bug is a thing of wonder and delight! :D |
Posted: Thu Jun 25, 2015 6:27 am Post subject: |
So while the scuttle was off I tackled this area. I converted it to standard style.
Smoother and neater
Other side. These areas were really tricky to clean the weld, really awkward job and getting my pinky stuck in the sander didn't help. Nice 45 degree chamfer though. Bit of insulation tape and carry on :D
Posted: Fri Jun 26, 2015 6:54 am Post subject: |
Back onto the scuttle, before tacking it in I fitted the hinge mount panel just to make sure that it was in the right place.
Deck lid fitted ok.
Gap still needs adjusting
As the deck lid mount panel is still going to be a bolt on affair, I wanted it to look clean from the inside so instead of welding m6 nuts on the inside like last time I got some Henk nuts and pressed them on with my hydraulic press.
Neater
Tack time
Getting to the inside to smooth the weld was a bitch.
Posted: Fri Jun 26, 2015 7:04 am Post subject: |
Edge needed building up.
While I was there I tidied this bit
Other side
Welded and tidied up the seam too
Hinge mount tidied up.
Posted: Fri Jun 26, 2015 7:11 am Post subject: |
Done
wcfvw69 Samba Purist
Posted: Fri Jun 26, 2015 8:14 am Post subject: |
You're doing great work here. Very inspirational. Having done some of these repairs myself (no where near your quality), I know how you are burning up tons of hours to fix this to this level.
It's amazing what our hearts and nostalgia do to us. I should of scrapped my 69 vert when I saw how rusted it was. I didn't and spent hundreds of hours welding in new/used panels. There's still SO MANY rust free bugs in the SW USA that don't require this kind of welding yet I did it as well.
Great job to you! _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Fri Jun 26, 2015 2:04 pm Post subject: |
Thank you. You are right when you say lots of hours, some of it is mind numbing but I have a vision in mind and I'm doing this to the best of my abilities and doing it it for myself. You are also right in that I could have just bought a lhd rust free shell or complete car to start and most of this work would have not been needed but that wasn't the point for me. I know this sounds strange but I feel I owe it to the car as it looked after me for so long. :D.
As you will see later on I've made a few small personal changes from stock just to give it my stamp. Now that I'm a member of DBK UK, there are standards that have to be kept too so that's driving me on. |
Posted: Sat Jun 27, 2015 12:43 am Post subject: |
Remember the crusty egay rear valence? Well I thought about using it instead of my NOS one as I still want to convert it into a quick release panel and the thought of cutting up a genuine new one fills me with dread. I`m going down a different route with this and I`m going to try and make it release in two sections.
I blasted it first to see how bad it was . It was bent and twisted but not too badly pitted.
Edge had disappeared
Made a new one
old new and new old ;D
The inner panel was removed and modified with a few choice dimple holes. I had to rebuild the corners too.
I`ve still got to finish and figure out how I`m going to do this but I will make some quick release mounts so that the inner panel can be removed separately as not to scratch paint or have the fixings showing from the outside.
Posted: Sat Jun 27, 2015 1:25 am Post subject: |
Posted: Sat Jun 27, 2015 1:31 am Post subject: |
One of the previous owners had fitted aluminium panels so I had to get rid of the nutserts and weld up the holes.
Posted: Sat Jun 27, 2015 1:38 am Post subject: |
Going back to the N/S rear wheel arch , where I had replaced the rear quarter panel previously , the original square nutserts had gone so I had to replicate them. Again this took hours and hours as I didn't want to warp the quarter panel with heat.
Before
Made a new section.
Patented super tool
Another one
And another
No filler required
aka pip Samba Member
Joined: September 15, 2004 Posts: 2034 Location: LongBeach Fool
Posted: Sat Jun 27, 2015 7:25 am Post subject: |
I like that!
#dbkstunners _________________ http://www.dbkvw.com/ |
DBK UK Samba Member
Posted: Sun Jun 28, 2015 2:13 am Post subject: |
looking good Lyndon! _________________ DBKUK |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Sun Jun 28, 2015 2:40 pm Post subject: |
Yeah, very cool.
How are you going to attach it to the vent side? _________________ If you can't join them, beat them! |
Posted: Mon Jun 29, 2015 12:03 am Post subject: |
Thanks
I
I welded countersunk m5 screws to the vent side and made slots in the vent panel. I made some dished washers to suit. Those have been there for 14 years and work fine. :) |
Blinker Samba Member
Joined: January 24, 2005 Posts: 1187 Location: LONG BEACH
Posted: Mon Jun 29, 2015 8:45 am Post subject: DBK_UK |
Happy to see you updated your avatar..!!
DBK_UK :2gunfire: _________________ D.B.K.
WWW.DBKVW.COM |
Posted: Mon Jun 29, 2015 11:21 am Post subject: |
Flying the flag 8) |
Posted: Mon Jun 29, 2015 1:15 pm Post subject: |
Next I had to tackle the channels. As I had replaced them all those years ago I knew they were rot free but the wrong shape so I had to convert them to the early smooth style. Some of you may question why I did this and not just put in a pair of gerson ones but I had fitted these old ones correctly, the doors fitted nice so to me it was easier to modify these plus I'm getting rid of the heater vents at the front too so I would have had to modify the gerson ones too. I also had to get rid of the harness mounts I had welded to them too.
I had to cut a section out and replace it as I had indented this area for the harness mount.
Big section to cut out
Posted: Mon Jun 29, 2015 1:41 pm Post subject: |
