Speedsterboy Samba Member
Posted: Wed Aug 10, 2005 6:39 pm Post subject: Judson |
I keep hearing negative stuff about Judsons, would anyone recommend using it on a daily driver especially with our weather in Oz being extremely hot? I'm increasingly becoming reluctant running it on my car as I'd rather not have an engine I have to pamper and treat with a glove..
Cheers,
AL |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80683 Location: Sneaking up behind you
Posted: Wed Aug 10, 2005 6:44 pm Post subject: |
I'm a "all motor" guy and there's nothing like a stroker engine with dual carbs. But the Judson was sold to people who used them on daily drivers.
Just drive normally and don't have your foot into it all the time.
If you drive 12,000 miles a year don't expect it not to wearout after a resonable amount of time.
If you want it 20 years from now... don't drive it daily. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1697 Location: Nebraska
Posted: Wed Aug 10, 2005 10:57 pm Post subject: |
Where do you keep hearing negative stuff?
I have been running a Judson on my car for the last few years. This year I have driven to Effingham IL on a 1600 mile round trip and also to Denver CO and back, another 1100 miles. No problems with the Judson.
This last Sunday I drove across Eastern Colorado in temps in the high 90's and it didn't get hot. I run a temp dip stick and a couple times the light flickered but that was when I was pushing 70 for a while but when I backed it off and ran 60 (speed limit) it was fine.
They also make a clattering noise that you can hear more at idle because of the rotor vains, but I'm not complaining, just explaining.
If you want more horsepower, your money might be better spent on a bigger motor. If you want to be different from all the rest, run a Judson. |
jeffreystarks Samba Member
Joined: August 01, 2005 Posts: 112 Location: Seattle, Wa
Posted: Thu Aug 11, 2005 2:09 am Post subject: Judson |
Whats a Judson? _________________ Jeffrey Starks
1970 VW Beetle
_May the fleas of a thousand camels infest the crotch of the person who screws up my day and may their arms be too short to scratch...AMEN. |
Glenn  Mr. 010
Posted: Thu Aug 11, 2005 3:05 am Post subject: Re: Judson |
| jeffreystarks wrote: |
| Whats a Judson? |
Late 50's, early 60's super charger designed for the 36hp and 40hp engines.
Member #1009
#BlueSquare
Posted: Thu Aug 11, 2005 3:18 am Post subject: Judson |
HHHmmm, I'm fine with how my engine is now...thanks for the response. _________________ Jeffrey Starks
1970 VW Beetle
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14276 Location: Southampton U.K.
Posted: Thu Aug 11, 2005 4:43 am Post subject: Re: Judson |
| al9 wrote: |
Cheers,
AL |
Al I've battled against a lot of negativity over the last 10 years. If you listen to all of it you wouldn't touch one.
There are a hell of a lot of people out there with positive stories about Judsons because these are the people who actually OWN one.
Most people who tell you bad stories know a guy who knows a guy who had one once. A Judson is a mechanical pump with moving parts that are subject to wear...sound familiar?
If you run one for a long time like an engine it will wear, as it wears it becomes noisier but unlike an engine when Judsons make a strange noises people continue to drive them hell for leather.
The Judson believe it or not, when new didn't add to the decebel count from the engine. The clatter from the vanes is an indication of the gradual wearing of the rotor slots. They will still run well for years making a slight clatter, like and engine will but eventually you're going to have to take it apart and give it an overhaul.
Very few do...they take them off the car, give them a lick of paint and sell them on Ebay. Surprise, surprise you get a lot more negative stories about Judsons.  _________________ John.
coad  Samba Scapegoat
Posted: Thu Aug 11, 2005 5:13 am Post subject: |
OK John, you're the Judson expert. How will a Judson affect the lifespan of an engine?
I mean, it's almost a given that the guy who puts a Judson on is gonna drive his engine harder than the average guy so in some ways that's not a fair question.
But all things being equal, if a non-Judson engine is good for 75,000 miles then a Judson engine should be good for _________ miles. |
Posted: Thu Aug 11, 2005 8:12 am Post subject: |
| coad wrote: |
You've half answered your own question already Coad ("it's almost a given that the guy who puts a Judson on is gonna drive his engine harder") people have this idea that a Judson is a "Hot" item but you have to look at whom the original was aimed.
This is not a unit aimed at ultimate performance, it's designed to give a modest boost to a cheap family car of the '50s. If you have a Judson and use it to take advantage of the performance characteristic of supercharging (mid range torque) your Judson augmented engine and drive train will last longer. That's the theory anyway...the problem is, as you say the human element comes into it...i.e. foot to the floor.
This way the Judson gets blamed for every engine failure whether it's the fault of supercharging the engine or not.
The Judson adds little to the top end of the power curve so you might get 80 out of it but where it scores over the 36hp is that you can keep up a really good average speed over a long trip...you just don't slow to a crawl on the hills and you're not chopping up and down through the box. Judson recommended shifting through the box at all the same points as on the normally asperated car, hang onto a gear a little longer, occasionally but on no account overrev the engine. That way the engine is less stressed, the transmission is less stressed and the driver is less stressed.
Incidentally, I'm not a Judson expert...I have opinions, I've read all there is to read about them and I have contact with a lot of owners. I've had my Judson for 10 years but I know someone who bought his first Judson powered Oval in 1958, he's still driving it...same Oval, same Judson.
He's an expert and Alejandro Martin and George Folchi, but I'm just someone who can put you in touch with an expert  _________________ John.
Posted: Thu Aug 11, 2005 5:18 pm Post subject: |
Then I guess I'll run the Judson! Thanks for all the replies. It's just a matter of locating that darn hood scoop!
Cheers All! |
Compoundbuilt Samba Member
Joined: September 15, 2004 Posts: 2035 Location: LongBeach Fool
Posted: Fri Aug 12, 2005 8:43 am Post subject: |
will the judson for the 36hp fit on the 40hp? what is the diffrents. _________________ http://www.dbkvw.com/ |
DaveM Mad Samba Scientist
Joined: June 11, 2002 Posts: 3010 Location: Dry side of Oregon
Posted: Fri Aug 12, 2005 8:46 am Post subject: |
There is always the option of the Mag or pepco supercharger. These are both roots type instead of the vane type judson. Mag superchargers are very difficult to find, I have a couple of pepcos for sale at the moment. _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
Posted: Fri Aug 12, 2005 10:23 am Post subject: |
thanks for the info! _________________ http://www.dbkvw.com/ |
Posted: Fri Sep 23, 2005 10:28 pm Post subject: |
Is evryone absolutely certain that the regular Judson coil works on both 6-12 volt system coz i heard otherwise that a resistor is required to be fitted?
Thanks,
AL |
Posted: Sat Sep 24, 2005 7:48 am Post subject: |
| al9 wrote: |
Thanks,
AL |
100% Guaranteed. I have one NOS with instructions and it very clearly states that it will work on either 6 or 12 volt systems. |
Posted: Sat Sep 24, 2005 5:57 pm Post subject: |
Thanks everyone! Has anybody ever tried to run their Judson without the carb spacer mounting plate in order to lower the aircleaner slightly in a Ghia application?
Thanks,
AL |
Posted: Sat Sep 24, 2005 7:40 pm Post subject: |
| al9 wrote: |
Thanks,
AL |
that's been covered in the ghia forum, and the short answer is that it won't work-- you 'll need the scoop that mounts on the engine decklid.
For details search in there for "JUDSON" |
Posted: Sat Sep 24, 2005 9:57 pm Post subject: |
Sorry Coad, I am fitting a scoop, the question is more like can I run it without the carb spacer as I don't have it...
Thanks,
AL |
