What type of carbs do i have?
wardo_3000
wardo_3000 is offline
PostPosted: Mon Oct 03, 2005 2:31 pm    Post subject: What type of carbs do i have? Reply with quote
just wondering what type of carbs do i have there off of a 73 1700cc heres the link to the pic. also wondering what the pipes are coming out the back left side.http://community.webshots.com/user/wardo_3000
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Tue Oct 04, 2005 3:53 pm    Post subject: Reply with quote
Those are stock carbs... read this and be thankful we have guys like Ratwell around Very Happy Cool
http://www.ratwell.com/technical/DualCarbs.html
metropoj
metropoj is offline
PostPosted: Thu Oct 06, 2005 6:01 am    Post subject: Reply with quote
They're a neat idea, central idle system on the drivers side carb with pipes connecting to the 'dummy' passenger side carb. Both cards have enrichment circuits though. Check your throttle bushings aren't too worn out or you'l get false air and have a helluva time getting them running properly.
The pipe at the top of the drivers side carb is air intake for the central idle circuit. The big screw is air bypass and the little screw is mixture. The scres in the base are for your throttle plates .....
Ratwells site I'm sure has a lot of info on the procedures to get them running good.
