Tim Minton 72 Samba Member
Joined: May 12, 2005 Posts: 34 Location: Modesto California
Posted: Mon Oct 03, 2005 9:52 pm Post subject: passenger window removal. |
okay, i need to pull the passenger window out of my 72 baywindow, and put it into my new(to me)passenger door. whats the best way to get that thing out of there? _________________ 1972 Campmobile 1800 |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4659 Location: Oklahoma City, OK
Posted: Tue Oct 04, 2005 6:56 am Post subject: |
Maybe not the best, but the safest. Remove the door panel, undo the two 6mm bolts holding the window to the winder mechanism, carefully lower the window to the bottom of the door, pull the upper channel felt(nearest the vent window) out for about 6" - 8", remove the screw, leave felt pulled out, remove the 6mm bolt holding the vent window frame, carefully pull the vent window assy back (top first) and wiggle the vent window assy out. Removing the inner scraper makes this easier, for getting it past the rubber scrapers can be tricky but it will go. There is a metal tab on the vent frame that the 6mm bolt went into and it invariably will want to hang up. Once the vent window frame is out, carefully lift the window out through the opening. Installation is reverse. Some do not drop the window down to the bottom, I have seen (personally done) several windows break while getting the vent window frame out due to stress on the glass. Tempered glass makes a heck of a mess. |
dembus Samba Member
Joined: February 02, 2005 Posts: 1272 Location: Fleming Island, Florida
Posted: Tue Oct 04, 2005 7:02 am Post subject: |
Do a search on this topic and you will find several threads, as this job can be a P.I.T.A.! Good luck  _________________ "Want a little peace of mind, grab the lowest branch and start to climb"
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy |
Posted: Wed Oct 05, 2005 8:32 pm Post subject: thanks, but new question. |
what is the best method to remove the scrapers and the chrome trim, and then put those also into my new door? _________________ 1972 Campmobile 1800 |
Posted: Thu Oct 06, 2005 6:48 am Post subject: |
Carefully! The inner scraper is rather simple. The outer is all one peiece. Once the window and vent are out remove the felt channel. Come under the lip of the scraper from inside the door with a flat pry stick (nylon) or a screwdriver and pop the scraper off. Slowly work the chrome off the door. Just work slowly. |
dembus Samba Member
Posted: Thu Oct 06, 2005 8:00 am Post subject: |
busman78 wrote: |
Seems like I remember it being very tough to remove the glass with the scrapers in. I think I disconnected the glass, dropped it into the bottom of the door and then removed the felt and scrapers. The glass comes out much easier with the scrapers and felt channels removed. I also remember inventing a few new cuss words while doing that job. _________________ "Want a little peace of mind, grab the lowest branch and start to climb"
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy |
Posted: Thu Oct 06, 2005 11:59 am Post subject: |
The vent felt will come out with the vent window assy, the top/side felt does not have to come out for you will clear it with the vent asy out. Removing the inner scraper makes the job easier, good point. Would rather not pull the outer when doing a window exchange, course he is also swapping scrapers so might as well get it out of the way.
Don't forget to remove the winder mechanism, not to get the window out, but always good to have a spare hanging around. |
