Ipaintem Samba Member
Joined: September 11, 2004 Posts: 522 Location: Brown Summit N.C.
Posted: Tue Oct 25, 2005 4:42 pm Post subject: CB breather q's |
Just got one today and have a couple questions before installing it.
Directions say the bottom holes go to the valve cover and or as well as the fuel pump block off. If you run the bottom to the valve covers, wont the hose take most of the oil. I know that its all going to end up in the same place, but it this ok?
I want to hook up the valve covers and the fuel pump block off to the bottom of the unit. There are only two holes there. Is it ok to T the two valve covers into one and use one hole in the box for the two covers and the other hole to the fuel pump
THe top holes I will just vent to atmosphere as suggested. Will this work OK? Thanks!! |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Wed Oct 26, 2005 8:59 am Post subject: |
I use one of the bottom holes to drain back to the pump block off and the other is plugged.
I tee the valve covers and run them ito one of the top holes and plug the other.
Then I put a small K&N style breather on a 90* fitting in the hole facing the shroud.
Look close and you can see the hoses in this picture:
http://img276.imageshack.us/my.php?image=rich25tp.jpg _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
RIS Samba Member
Joined: December 18, 2003 Posts: 3044 Location: Youngstown, Ohio
Posted: Thu Oct 27, 2005 8:29 am Post subject: |
The only problems I've had with them RIS is the gland nut holding the box to the stand.
Only engages about 3 threads.
Next one will get that area machined thinner to allow more engagement.
That and some blue loctite. _________________ Gary
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Thu Oct 27, 2005 2:43 pm Post subject: |
| make sure you use sealant along with the o-ring for the cover otherwise it will leak. |
Tom N. Samba Member
Joined: May 21, 2005 Posts: 782 Location: dReading, PennsylRAINia
Posted: Thu Oct 27, 2005 7:35 pm Post subject: |
I received my CB breather a few weeks ago. My motor has to be completed before I install it. I preferred the look of the Berg Breather, but I figured for <$40 I would try the CB. Your clues so far are helping, I will have mine machined for a better fit.
Thanks! |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Sun Oct 30, 2005 9:26 am Post subject: |
Thats because Gene PERSONALLY built yours,Bill!  |
Posted: Mon Oct 31, 2005 8:11 am Post subject: |
| bill may wrote: |
| it wont work as good as my 1985 gene berg breather. |
So I suppose you've had both and chose the Berg unit based on side by side comparisons. _________________ Gary
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Mon Oct 31, 2005 8:42 am Post subject: |
I had to machine the gasket surface of the breather box to keep it from leaking. Since then it works very well.
Jerry... |
Posted: Mon Oct 31, 2005 12:13 pm Post subject: |
| IMO Berg stuff is way over priced. There is no doubt that MOST of their stuff is good stuff and well thought out, but damn!! THe CB unit has baffles like the Berg and I have sence bought and installed the CB unit with no probs and no leaks. It should work just as good as the Berg and cost $150 or more less. Plus, ever wonder why only 1/3 or so of their parts on the internet have prices? And ever wonder why they put an MSRP price on there? Arn't they the acutall manufacturer? Just something to think about. |
a_67vdub Samba Member
Joined: April 06, 2003 Posts: 504 Location: Long Beach
Posted: Mon Oct 31, 2005 12:22 pm Post subject: |
| Quality costs. I have a CB breather. It's nice, but the quality is nowhere near that of the Berg breather. |
