spindles/calipers
BSQUARE
BSQUARE is offline
PostPosted: Sun Apr 23, 2006 11:37 am    Post subject: spindles/calipers Reply with quote
i took my calipers off today. i noticed that the mounting holes on the spindles are further apart (3") than on a 69 beam (2 1/4") that i have in the garage. could somebody tell me what year my spindles are from, so that i can more accurately shop for parts? FWIW- it's a 65 that seems to have been bastardized.
i'd like to keep the 3" calipers, as the pads are larger.
1968 Regatta Blue Squareback
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Apr 23, 2006 11:57 am    Post subject: Reply with quote
If you have a 65 with disc brakes then it is not stock. If you have the wider spaced holes, then you have the mid 72 up spindles . The calipers and rotors are the same as a T-4 also.
Gary: OK. Ima poop.
BSQUARE
BSQUARE is offline
PostPosted: Sun Apr 23, 2006 12:09 pm    Post subject: Reply with quote
thanks russ.
i'd guess that when it was switched to 12v, the front beam was swapped as well, to have the 4 luggers all around.
