Fresh Air Fans
Jaegermeister
Jaegermeister is offline
PostPosted: Wed May 17, 2006 10:43 am    Post subject: Fresh Air Fans Reply with quote
I just bought a set of fresh air fans to put in my 79 Westy and just need to install them. I looked at the wiring diagram in the Bentley and have no idea how to read it.
Does anyone have a picture of the wiring from the fan control switch to the fuse panel? I'm not electrially inclined and not sure how I need to hook it up to the fuse panel. Is there only one wire that needs to go? It only looks like there is space for one wire on the switch.
Thanks for the help.
Jimmy
1979 Deluxe Westy
Lurst
Lurst is offline
PostPosted: Wed May 17, 2006 12:38 pm    Post subject: Reply with quote
I think its just one wire to the fuse box #6 from the switch. On the switch its #30 terminal. Then 2 wires connects the two fans together and each fan has a ground. I just installed my set a few weeks back. Hope this helps. David
Jaegermeister
PostPosted: Wed May 17, 2006 1:42 pm    Post subject: Reply with quote
That does help. I figured it was the one wire since there are grounds for each fan but not being too electrically inclined I thought it was best to ask.
Thanks for the help!
1979 Deluxe Westy
Lurst
Lurst is offline
PostPosted: Wed May 17, 2006 1:44 pm    Post subject: Reply with quote
Right on Very Happy
