amishpower Samba Member
Joined: August 03, 2006 Posts: 81 Location: los angeles
Posted: Fri Aug 18, 2006 10:27 pm Post subject: carb synchrometer |
first time acvw owner- 69 square back. i've been goin through the muir book, following the tune up section to get my new car on the road. it starts up real nice, but PO said it had been sitting a few years. any way, here's a question... if the empi synchrometer i ordered didn't come with instructions,(thanks cip1.com?!) then am i still to follow the same procedure that's in the book, or is there a different way to do it with the synch i got? ( the muir book uses a uni-synch). i'm not a total mechanical idiot, and i'd like to accomplish this on my own, without having to rely on having someone do it for me. proud of myself for the valve adjustment, but i hear synching the carbs is a frustrating task, so any tips would be appreciated- thanks! |
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1103 Location: Dover, DE
Posted: Sat Aug 19, 2006 5:35 am Post subject: |
The procedure is the same it's how you place the sync on top of the carbs that's different. (I have the unisync- because of the bolt sticking up through the middle of the carb I put a metal tomato paste can on top of the carbs and then sit the sync on top of that.) Remember that the sync only measures air flow so the tool can be different but the procedure is the same.
Anybody out there with the empi style that can shed some further light
By the way, it would help to know if these were stock carbs or after market _________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Aug 19, 2006 6:54 am Post subject: |
I use a piece of 1 1/2" PVC pipe to space it up off the carb. Take the rubber o'ring around the top of the carb with you to the hardware store. You will need about a 4" long piece. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sat Aug 19, 2006 11:51 am Post subject: carb synchrometer |
they are dual solex 32's- thanks for the tips!!! |
