65busser Samba Member
Joined: April 17, 2004 Posts: 84 Location: Melburg Australia
Posted: Wed Dec 06, 2006 5:24 am Post subject: Type 3 experts - here's one for ya |
Haven't been able to get my driver's backrest upright enough, so decided to pull the seat out and found the problem. In the backrest adjuster, there's a rod that runs from one side to the other. The cam that adjusts the backrest angle, and the little stop on the ends of the rod, are held in by pins and one of the pins, the one that holds the cam in place, is missing. I could prob make up a pin of sorts, but I'd like to get the real thing. What I don't understand is how the pins are removed. If I can find a trashed seat, I might be able to salvage a pin. See pic.
Any experience?
_________________ 66 Single Cab
56 Oval
64 Bug
www.busnbug.com |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Wed Dec 06, 2006 7:34 am Post subject: |
those are called roll pins. to remove or replace, you have to use a punch and hammer and drive them in or out. any hardware store should have them. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35900 Location: Conejo Valley, CA
Posted: Wed Dec 06, 2006 9:52 am Post subject: |
You may have to cut/file the length of the one you are missing, because it must be fully embedded in the hub/cam--it shouldn't stick out beyond the outer circumference hub/cam. It will jam if it sticks out. They are VERY hard so use a sharp saw and then grind or file it smooth. |
Posted: Wed Dec 06, 2006 1:27 pm Post subject: |
Much appreciated. Thanks _________________ 66 Single Cab
56 Oval
64 Bug
www.busnbug.com |
