Refining my Solar Options
Dogpilot
Dogpilot is offline
PostPosted: Sun Aug 19, 2007 9:07 am    Post subject: Refining my Solar Options Reply with quote
I finally got some time to mess around with the new 75 Watt solar panel W/ASC controller and make a mount for it. There turns out to be two families of Sattellite Dish mounts. Ones with one axis of adjustment and one with two axis on the same head. Luckily Laguna is the shining model of the disposable society. In short order my sister rounded up two sets.
If I wanted to make a luggage rack mount, I needed to be able to rotate the bottom one as well as have elevation adjustment. So I mounted the head on both the rear of the panel and on my foot unit. This gives you a rotational adjustment so you can turn the panel to meet the optimum position for the sun. It does not preclude you from taking it of the rack and putting it on the ground away from the van.
Coring out the City Water, 'rust formation port', is a good use of the panel. Get a Marinco plug and receptacle kit from West Marine, and you have a water resistant connection.
If anybody wants a nice 40 Watt panel with a charge controller and a mount PM me.
My extra 40 Watt panel:
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
mtodd
mtodd is offline
PostPosted: Sun Aug 19, 2007 11:37 am    Post subject: Reply with quote
That is a kick'in panel. Not all that large an area for 75 watts.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200263174_200263174
Northern Tool has a fairly nice 15 watt unit for the best prices I have seen.
$80 If I had to guess I would say they are 2/3 the size of your panel.
captainpartytime
captainpartytime is offline
PostPosted: Sun Aug 19, 2007 11:43 am    Post subject: Reply with quote
James, looks sweet!!! Keep raising the bar with your ingenuity. I ask my vans the same question every day, "why can't you be more like dogpilot's syncro?". Wink
Now tap into some of that sweet Arizona sun. Is that your controller mounted to the bottom of the panel?
-Kerry
1982 turbo diesel Westfalia
Dogpilot
Dogpilot is offline
PostPosted: Sun Aug 19, 2007 12:51 pm    Post subject: Reply with quote
Patience would have it. I scored the ASC/Siemens Controller off eBay for a pittance. It is totally sealed, so it can be in the elements. It is the box next to the junction box. It has a series of LED's that shows charge state of the battery, the charging function and if the overcharging circuit is kicking on or off.
http://www.oksolar.com/solar_controllers/asc_solar_controllers.html
I am sure there are even better controllers, but you must be judicious with the hobby budget, or you sleep alone.
Now we need to design the garbage reactor (even human waste, lots of energy in that stuff) fuel cell to provide power at night. I have one of the Krupps coffee grinders that the professor used in 'Back to the Future' to use for the body of the unit.
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
Christopher Schimke
PostPosted: Sun Aug 19, 2007 12:59 pm    Post subject: Reply with quote
Very nice use of surplus parts there James. If anyone would like one of those DISH mounts, I have an extra one here that you can have. Come and get it or pay the shipping and it's yours.
knyjff
knyjff is offline
PostPosted: Sun Aug 19, 2007 5:09 pm    Post subject: solar Reply with quote
hi...dog pilot...new samba guy here..new syncro owner...want solar and am beginning the search,learn,understand mode. question ?? when retracted does the panel sit flush with the lip of the luggage area + or - ? and what amp hr number will it deliver to your auxillary battery? thanks
Dogpilot
Dogpilot is offline
PostPosted: Sun Aug 19, 2007 5:15 pm    Post subject: Reply with quote
I keep the panel inside when traveling. It is way to expensive to let it get hurt by road debris, or removed by curious hobos. I am making a mount to fit it under the AC box inside along with the table. To figure your yield from a panel: Amps= watts/volts.
So if you have a 40 watt panel for example that you want to supply 13.5 volts on charge you would yield: 2.96 Amps per hour, a 75 would do: 5.56 amps.
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
tencentlife
tencentlife is offline
PostPosted: Sun Aug 19, 2007 6:23 pm    Post subject: Reply with quote
Except with PV the watts rating is determined at the maximum power point, which by design is between 16 and 19 volts, usually around 17 and change. Use 17.5 volts as a safe bet, and divide the rated watts by 17.5. That will give you the rated amps at maximum power point.
The panels are strings of nominally 0.5V cells that are stacked in series to set up the VMP (Voltage Max Power). You will usually see 34-38 cells in single string 12V panel. They are set up higher so there is a margin of voltage that can be lost due to reduced voltage of each cell as temps rise, so that at a range of working temps there will always be sufficient margin to be able to charge a battery at the nominal voltage.
PV is a constant-current device. Current (amps) and voltage both vary with light intensity but at full insolation the current will be steady while voltage will vary with temp. They are rated at the best combination of voltage to amperage under test conditions, and that is the published wattage, but in reality you can only expect to get 70% of the rated wattage while charging a nominally 12V system, unless you use an MPPT charge controller to recover some of the extra margin of power available. They aren't practical to use on only one- or two-panel systems, due to cost.
tclark
tclark is offline
PostPosted: Sun Aug 19, 2007 10:57 pm    Post subject: Re: solar Reply with quote
check this thread out good review of PWM vs MPPT controler
&solar panel types amorphic vs. poly vs. mono,
http://www.thesamba.com/vw/forum/viewtopic.php?t=239385&highlight=mppt
Ophir
Ophir is offline
PostPosted: Tue Aug 28, 2007 9:43 am    Post subject: Reply with quote
This is inspiring.
My last Westy was a 91 syncro that has a solar system installed. The array was glued to the roof in a fixed position. He didn't get the bugs worked out and honestly it didn't really work the way it was intended to, a trickle charge for the batt.
Now that I have my new van, Lucky, the 90 Westy. (I named him lucky based on where I test drove him, Lucky Pass, and in hopes of good mechanical karma. ) I'd like to get a PV system in him. I'm studying the designs you all have created. Smile
Lanval
Lanval is offline
PostPosted: Tue Aug 28, 2007 10:30 am    Post subject: Reply with quote
Ophir,
If you just want a solar trickle charger, you can buy VW brand chargers on ebay for around $25. They plug into your 12v lighter socket, and have suction cups for temp mounting on a window, or holes for more permanent mounting. You can see us using them here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...;start=140
scroll down to the orange/Nathan@el van, and you'll see he's got one in his window.
Best,
Lanval
Dogpilot
Dogpilot is offline
PostPosted: Tue Aug 28, 2007 12:17 pm    Post subject: Reply with quote
Actually, those small VW chargers are indeed cool. It seems like a containerload of them must have fallen off the back of a truck, if eBay is anything to judge. I put mine in the back window.
When I get around to the mod I want to do to the closet. Which has been put on hold until I finish the spot in Laguna. Wife's orders and tool access (all my wood tools are there). I want to figure out an alternative to the Curtain (which still puzzles me as to why it is there). I want to incorporate two of them in that spot, one for each battery.
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
captainpartytime
PostPosted: Tue Aug 28, 2007 8:09 pm    Post subject: Reply with quote
I thought of mounting two small panels in that back corner also. I have two small panels I got from Russia. Their really high efficiencypanels and are mounted to a PVC type backing so their slim. My only concern with a permanent mount is that panels can act like loads at night time and I don't want to manually switch them off and on every day. Will the Yandina prevent the panels from acting like a load and draining your battery?
-Kerry
Dogpilot
Dogpilot is offline
PostPosted: Tue Aug 28, 2007 8:19 pm    Post subject: Reply with quote
If you put a diode in line it should prevent them from becoming loads. The VW panels have the diodes in place. The downside of diodes is there is a .5 V voltage drop.
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
Ophir
Ophir is offline
PostPosted: Wed Aug 29, 2007 6:55 am    Post subject: Reply with quote
Lanval wrote:
Ophir,
Oh, those are a nice option for a trickle charge. And I did see that there are plenty of them on ebay. Thanks!
I still want to pursue the solar system option too. It would be nice to have 110v in the van. I lived on solar in Colorado for a number of years. It was before the good inverters were out. It will be nice to revisit solar and see what improvements are being made.
fyrgrrl
fyrgrrl is offline
PostPosted: Wed Aug 29, 2007 5:27 pm    Post subject: Reply with quote
Hey DogPilot....I found them on eBay but do you have a favorite, trustworthy vendor you bought them from? Cool
1987 Vanagon Westfalia (manual) - "Van Hildegaard"
1987 Vanagon Westfalia (auto)
1985 Vanagon GL 7-passenger van (auto) - "Blau Frau"
1985 Vanagon GL 7-passenger van (manual) - "Braunkuh"
1998 Subaru Legacy Outback (auto)
2003 Subaru Legacy L wagon (auto)
Dogpilot
Dogpilot is offline
PostPosted: Wed Aug 29, 2007 6:29 pm    Post subject: Reply with quote
Out of the over 2000+ transactions I've done on eBay, I've only had one problem. I did get my money back, from him and PayPal.
Any person you buy from can be great or a dick. I got mine from an individual and sniped about 15 auctions until I got it cheap. It was an experiment, and I didn't want to waste any money on it.
While they do charge your battery, it may take a while if it is flat, like a week. The suction cups are for looks only, for making and keeping suction they are not. They simply keep a battery floated.
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
