1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2458 Location: Acton, Ontario, Canada
Posted: Tue Oct 09, 2007 7:05 am Post subject: 1975 trany parts availability automatic ??? |
Can these tranys still be rebuilt. The trany shop here in Canada says that the clutches or listings are no longer available. My trany has sat for 20 years and he said the clutches would have dried out and in very short time after the running of the trany they would come apart. The trany has and not moved in 20 years. So I just want to know if the parts are still available. Thanks _________________ Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
germansupplyscott Samba Member
Posted: Tue Oct 09, 2007 7:22 am Post subject: |
the tranny shop is more or less correct. internal parts for the 003 are getting difficult to find. the parts jobbers that service the transmission shops have discontinued them. try long enterprises. _________________ SL |
Posted: Tue Oct 09, 2007 7:34 am Post subject: |
Is long a supplier or rebuilder. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4143 Location: Los Gatos,Ca.
Posted: Tue Oct 09, 2007 8:40 am Post subject: 003 trans |
Try this www.drivetrain.com or 1-800-216-1632 You will need to use the search and type in volkswagen 003 _________________ V.W.owner since 1967 |
Posted: Tue Oct 09, 2007 7:27 pm Post subject: |
| germansupplyscott wrote: |
| the tranny shop is more or less correct. internal parts for the 003 are getting difficult to find. the parts jobbers that service the transmission shops have discontinued them. try long enterprises. |
Scott do you know any good trany guys in the area. I am going to make a couple more calls in the coming weeks to see if I can find someone who knows the old VW tranys well. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Posted: Tue Oct 09, 2007 7:48 pm Post subject: |
yes, i have a shop we use for automatic transmissions.
any auto transmission shop that has a clue can rebuild an 003, it is common (or at least used to be) and not a complicated unit to service. the jobbers in this area do not usually have the hard parts for the 003, however. _________________ SL |
The trany guy here said that it was a 7 hour job. So at 70 an hour shop labour and 200 in parts I am looking at $700.00 to rebuild the thing. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Posted: Tue Oct 09, 2007 8:01 pm Post subject: |
last time i did one, we charged 550.00 for a rebuilt 010, P&L. that was last year, not sure if parts costs are higher lower or the same. so you might save a few bucks that way. _________________ SL |
Posted: Tue Oct 09, 2007 8:06 pm Post subject: |
I have a '82 091 side shift here. Anyone need one I have to pay for a trany job. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Posted: Wed Oct 10, 2007 8:57 am Post subject: |
we have some good used 003 transmissions. _________________ SL |
Posted: Wed Oct 10, 2007 7:30 pm Post subject: |
The price would have to be really cheap. I think this one only has 60,000 on it. So I don't mind throwing a bit of cash in it. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
WestyPop Samba Member
Joined: February 08, 2005 Posts: 1734 Location: SoCal
Posted: Thu Oct 11, 2007 2:50 am Post subject: |
You could even look for an '80-early '83 Vanagon auto tranny. The wasserboxer auto trans supposedly also fits, with the added bonus of having lines in/out for an external ATF cooler. That would minimize the heat soak-back from the torque converter to the engine case & oil.
J.R.
68 Westy
(+ others) |
Posted: Thu Oct 11, 2007 4:45 am Post subject: |
| WestyPop wrote: |
J.R.
68 Westy
(+ others) |
I'm guessing that is the 010 trany. I will look it up. Anyone want to trade a 091 side shift for a auto 010. Thanks. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Posted: Thu Oct 11, 2007 5:56 am Post subject: |
you can't easily put an 010 in a 75 bus. linkage issues will make it hard. _________________ SL |
Posted: Thu Oct 11, 2007 6:02 am Post subject: |
Alright back to sticking with the 003. Thanks Scott for all your help. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Posted: Thu Oct 11, 2007 6:17 am Post subject: |
Hey Scott I just spoke to a Mr. Transmission guy in Milton and he said that he has modified a 010 with heavy duty parts to beef it up. Stronger in other words. So is the 003 able to be upgraded to the heavy duty version. He is not sure until he sees it. He said if the guts are the same as the 010 then he will be able to strengthen it. Not sure if it needs it but maybe throw in a shift kit. lol. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Posted: Thu Oct 11, 2007 6:32 am Post subject: |
the 003 is not the same as an 010, so anything you do to an 010 will probably not work on an 003 - i don't see any need to beef up either of them anyhow. they are very strong units. either of them can take about 200HP without difficulty. for instance the 003 has been used in VW drag cars for decades.
one thing you need to be careful about is making sure the seals are good between the transmission and final drive. it is common as they get older for the transmission to start leaking into the final drive. this will not be included with a typical rebuild since the final drive is not technically part of the transmission. _________________ SL |
Posted: Thu Oct 11, 2007 6:38 am Post subject: |
Thanks Scott again. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Frozenbutt Samba Member
Joined: December 14, 2005 Posts: 184 Location: Near Toronto, Ontario
Posted: Fri Oct 12, 2007 4:37 pm Post subject: |
To rebuild the 003 auto final drive you need the following 5 seals:
Govenor 003 507 125 10X19X7mm German Supply
Pinion 003 519 085 30X42X7mm 2 req'd, use Timken 223010
from your FLAPS
Axle 018 409 399 45X60X8mm 2 req'd, Bus Depot, same as
the 010 final drive axle seals
there are also 4 metric o-rings that are hard to find. I reused my old ones. |
Posted: Thu Nov 03, 2011 5:26 am Post subject: |
Here is a picture of the over haul kit and the kit contains a governor seal and the large o ring that seals the trans to the final drive.
There are a couple of internal seals on the final drive that need to be replaced along with the torque converter seal, governor seal and the axle seals. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
