Scott Faivre Samba Member
Joined: February 26, 2004 Posts: 368 Location: Las Vegas, NV - USA
Posted: Mon Nov 05, 2007 9:15 pm Post subject: Ever spun the splines out of a drum? |
It was pretty wierd, I thought for sure that I was going to be up for swapping out a tranny. My wife took my car out to run some errands and she calls me about an hour later. "The whole car shudders and it won't go anywhere!"
Oh crap! Tell me the old lady was hot rodding again! (She's got a lead foot in a car with performance ) Well I got the thing home and I found this:
http://www.german-pride.com/Joomla/index.php?optio...39#msg1339
10,000 miles not a lick of trouble and then this! Moral of the story, check the torque on those axle nuts!
It turned out to be a $50 drum instead of $500 tranny! I'll take that anyday!
Scott Faivre _________________ 66 Sedan & 64 Convertible
64 Vert Resto Gallery |
Hotrodvw Samba Member
Posted: Mon Nov 05, 2007 9:31 pm Post subject: |
Yup, been there done it. I had the same exact reaction that your wife had. Crap.....lost the tranny. I was verrrrrry happy to find it was only a drum.  _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
NOTAHONDA Vegas Don
Joined: September 30, 2006 Posts: 1411 Location: Arizona
Posted: Mon Nov 05, 2007 10:32 pm Post subject: |
| Same thing happened to me on the way home from First Findlay Scott. |
Panhandle_dubs Samba Member
Posted: Mon Nov 05, 2007 10:43 pm Post subject: |
| damn I just to 2 new drums in over the past 4 weeks, be sure to tighten that axle nut! |
Stan Monterrosa Samba Member
Joined: April 16, 2004 Posts: 75 Location: Granada Hills, CALI-4-NIA
Posted: Mon Nov 05, 2007 11:02 pm Post subject: |
is it always the nuts? my friends 62 used to kill the passenger drum only for some reason........... _________________ What??? |
Itawayoflife Samba Member
Joined: February 20, 2006 Posts: 1181 Location: Buena Park,CA
Posted: Mon Nov 05, 2007 11:10 pm Post subject: |
Yup, tighten those drums. Put shims behind the axle nuts so that the nut is actually making contact with the drum and not just hitting the end of the threads. What also helps is tighten the axle nuts then take it for a quick spin around the block, then check them again. I had a nut come undone while driving once, that was one hell of a ride. Sheared the cotterpin right off. _________________ The quest continues... |
ScrapJunkie (O\U|U/O)
Joined: March 17, 2004 Posts: 3977 Location: Hutchinson, Kansas
Posted: Mon Nov 05, 2007 11:16 pm Post subject: |
Had it happen a few times..it's not always because of loose axle nuts! If your car is lowered 2 splines or more, the toe in could be a factor, I know it was for me and a lot of others. _________________ (O\U|U/O) Top Vw (o\UU/o) |
Zundfolge1432  Samba Member
Posted: Tue Nov 06, 2007 6:03 am Post subject: |
Unmentioned here but most common cause is aftermarket drums... We got loads of this crap from Mexico and Brazil several years back.. Insist on German drums even good used would be preferable to the replacement crap fobbed off on the poor unsuspecting consumers...
Jim- |
visibleink Samba Member
Joined: May 03, 2002 Posts: 1669 Location: Austin, Texas
Posted: Tue Nov 06, 2007 8:50 am Post subject: |
Cool! _________________ Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
<-- Helga, she slammed her dub in '53 and adjusted valves with her teeth |
Posted: Tue Nov 06, 2007 10:56 am Post subject: |
Well the weirdest thing was that this happened after 10,000 miles of use! Cotter pin was still in place and everything!
Oh well, I pick up a new drum today. I'm just glad it was a $50 drum and not a $500 tranny!
Scott Faivre
P.S. GermanPride, I like your screen name! Have you seen our website? Look at my link in my signature. _________________ 66 Sedan & 64 Convertible
Posted: Tue Nov 06, 2007 11:12 am Post subject: |
| Scott Faivre wrote: |
Scott Faivre
P.S. GermanPride, I like your screen name! Have you seen our website? Look at my link in my signature. |
This sounds like what Zundfolge1432 said. Aftermarket drums. Did you do any work to the brakes in the last few thousand miles? _________________ The quest continues... |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Tue Nov 06, 2007 11:18 am Post subject: |
| Be sure to put some wheel bearing grease on the splines of the drum/axle... Installing them clean and dry causes wear too. |
Posted: Tue Nov 06, 2007 1:40 pm Post subject: |
| Itawayoflife wrote: |
Scott Faivre
This sounds like what Zundfolge1432 said. Aftermarket drums. Did you do any work to the brakes in the last few thousand miles? |
No brake work needed. I still had a solid pedal, and a good strong e-brake. To tell the truth, I don't know what kind of drums they are. They were new on the car when I bought it at the auction. I just checked everything for leaks, adjusted them up and torqued the snot out of them.
This car has been a dream! I put in a new electrical harness, and went through everything when I painted it. All I do is check valve adjustments and change oil. My little 1776 with kadrons is "spirited" at best, but it's no spline stripping power house. Oh well, I can't complain.
Here's a shot of the wife driving it.
Click Here - I can't get my photos to post on this forum because of my filenames.
$50 repair and few hours time. I'll take that over a new car payment any time!
thinghunter Samba Member
Joined: May 18, 2004 Posts: 403 Location: North Texas
Posted: Tue Nov 06, 2007 2:24 pm Post subject: |
| My brother had that happen over and over again. We would put on a new drum torque it down to spec put in a new cotter pin and it would keep happening. Turned out the very bottom threads were slightly stripped out and it would torque down correctly but after a couple thousand miles it would strip out the splines. Just something to watch out for if it happens again. |
DrvwStevo Samba Member
Posted: Tue Nov 06, 2007 4:36 pm Post subject: |
Yep, years back, my sisters friend had me come look at her POS bug, for a tranny problem. Some shop tried to sell her a tranny replacement for $1500......
I go over, fire it up, shift into 1st gear, and I hear clanging in the left rear hub cap... I get out and pop the hubcap (still in gear) and there's the axle spinning free as a bird in the drums hub. I got her a NEW german drum for $25 @ S.C.I.D. and swapped it out...... _________________ Those who can, DO. Those who can't, wish they COULD
'68 bug |
Dirty Hippie Samba Member
Joined: July 19, 2007 Posts: 189 Location: Huntsville, Alabama
Posted: Wed Nov 07, 2007 5:42 am Post subject: |
| I was stupid enough to actually replace the whole transaxle on one of my first bugs. Turns out that it was only the drum. I had no clue. Now i've probably spun about 15 or more drums. I allways just kept a spare in the car just so I knew I could get it home. |
Posted: Wed Nov 07, 2007 2:32 pm Post subject: |
Well rather than a 6 foot pipe over my breaker bar, I think I'm just going to call my buddy that has a torque meister tool. If it strips out again, we'll know it's just the brute HP and Torque of my little 1776 with stock heads and tiny kadrons.
Here's a question for you...
Does this also happen with Rotors? I haven't heard of any complaints about this problem with rotors. I've knew a lot of people had spun drums, but this was my first.
Posted: Thu Nov 08, 2007 12:51 am Post subject: |
Scott Faivre |
I just read a thread in the Performance/Engines forum that actually had this happen with rear discs. I don't remember what the issue was though. _________________ (O\U|U/O) Top Vw (o\UU/o) |
atye Samba Member
Joined: September 02, 2004 Posts: 580 Location: Peachtree City, GA
Posted: Thu Nov 08, 2007 11:05 am Post subject: |
Had that happen on a '63 convertible about 20yrs back... Just wouldn't pull off from a red light. I panicked and figured I had blown my transmission. Then I noticed that the axle nut was spinning while a friend had it in gear trying it out.
LOTS better to replace a drum than a whole transmission!!
Always torque them down ! _________________ Alex
1990 Audi 90q 20v sedan
1998 Suzuki Sport Sidekick
2002 Suzuki Grand Vitara
2005 Subaru Legacy GT wagon 5spd Turbo AWD |
clearsurf2001 Samba Vaccinator
Joined: February 26, 2004 Posts: 1671 Location: Dave-AKA-fortyeye-Oceanside, Ca
Posted: Thu Nov 08, 2007 11:24 am Post subject: |
| Germanpride wrote: |
Scott Faivre |
I just read a thread in the Performance/Engines forum that actually had this happen with rear discs. I don't remember what the issue was though. |
Not sure if this is what you're thinking about, but, a few years ago when C.B. came out with their race strength wide 5 rear disc kit, there was a problem with the nuts backing off after a few hundred miles. Never heard the fix but I check mine on a regular basis. After the first re-torque they've never come loose since. _________________ Get ready for the injection
| EverettB wrote: |
| Make sure it is coherent. Rodney |
| mharney wrote: |
I think Glenn has an EMPI crank in his engine. |
