gypsygirl61 Samba Member
Posted: Fri Nov 30, 2007 11:08 am Post subject: insulation |
i need to replace the insulation around the heater duct underneath the back seat. the left side has the original insulation, i was wondering if i could use the foil backed insulation on the other side? or any recommendations |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6543 Location: Northern Illinois
Posted: Fri Nov 30, 2007 11:23 am Post subject: |
Anything like the foil backed black stuff will get soft and or melt and stink you out of the car. I used aluminum repair tape, then wrap the duct with foam padding and secure with a couple of jumbo zip ties. _________________ Midwest Autosavers, Inc. Crystal Lake, IL |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16801 Location: State College, PA
Posted: Fri Nov 30, 2007 11:34 am Post subject: |
Go to a motorcycle shop and get 2 sheets of "baffle" wrap. This is for fiberglas wrapped muffler baffles. Comes in a rectangular sheet. The purpose is to help absorb sound. It will get pretty warm from the hot air, but not real hot, so you could use other materials as well that could stand up to the temp of the air coming from the heater boxes. (not sure what that temp really is, but I would be surprised if its much over 150 degrees) _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
