Engine model number question
[email protected]
flagpoleskater@yahoo.com is offline
PostPosted: Tue Sep 03, 2002 8:48 am    Post subject: Engine model number question Reply with quote
I was trying to find out more specific information on my engine. Looking on Type2 I found the following for 1971 bus engines:
1971 Chassis Number 211-2000-001 - 211-2300-000
Engine Number AE-0-000-001 - AE-0-529-815
1584 cc, 60 HP @ 4400 rpm
Transmission: 4-speed manual, 002 CM
Fuel System: Solex 34 PICT-3 carburetor
Total Produced:
Imported to U.S. 68,561
The number that read off of my engine is:
AS 497 342
Any ideas of where this engine came from. I didn't see any AS numbers.
Thanks,
[email protected]
speirsn@telusplanet.net is offline
PostPosted: Tue Sep 03, 2002 5:38 pm    Post subject: Engine model number question Reply with quote
I believe the AS engine serial# indicates a new (at the time) factory replacement crankcase that usually came in long-block form. The shortblocks often came with AES before the engine number, but were rebuilt AE cases. The new bare cases generally came without any number. Your AS case should be a dual-relief valve type with case-savers for 8 mm head studs meant for dual-port heads, 85.5 mm P/C and have the larger oil galleries and (25 or 26 mm) oil pump with dished camshaft. It should be a great one to hang on to as you can rebuild it some day with 90.5 mm P/C to create a 1776 cc with tons of torque for your bus. It would also be great in a Beetle! Neil.
