porche cooling system
rearenddude
rearenddude is offline
PostPosted: Mon Mar 10, 2008 8:51 am    Post subject: porche cooling system Reply with quote
In a previous thread I requested some info on a porche style cooling system.
one of the responses reads "why are you interested in an in-efficient cooling system?".
I was under the impression that this system was superior to stock VW.
I am very interested in all opinions here, as these systems are expensive.
stoneloco808
stoneloco808 is offline
PostPosted: Mon Mar 10, 2008 9:03 am    Post subject: Reply with quote
Taken from this thread, its a sticky above, http://www.thesamba.com/vw/forum/viewtopic.php?t=153387
The line up is as folows
DTM
Stock non modified (includes 181 in my testing)
36HP aftermarket
911 style shrouds
center mounted systems that utilize the stock radial fan (these are HORRIBLE)
VW Gol
Nothing performed as bad as the Gol shroud!
I saw no differences in cooling with the 181 shroud that would prove it's worth the money.
My DTM only beat the stock shroud by about 10% in average engine temperature, but it did significantly decrease temperature delta between all 4 cylinders. The biggest benefit of the DTM was the cooler oil temperatures due to the TIV cooler and the 17% of added airflow we direct through it over stock.
Jake Raby
Jake Raby is offline
PostPosted: Mon Mar 10, 2008 9:07 am    Post subject: Reply with quote
Do searches and you'll see that the VW engine and the Porsche engine are different in just about every regard. For years the unsuspecting public (myself included) "thought" that if a system would cool a Porsche 6 cylinder it would do the same for a VW engine.
This has been proven inaccurate to say the least and many engines that once donned the Porsche system have now been re-fitted with the stock VW system, or my DTM.
It's all available in the search function.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
Jimmy111
Jimmy111 is offline
PostPosted: Mon Mar 10, 2008 10:38 am    Post subject: Reply with quote
The problem is not in the fan or really the system. All the people who manufacture the shrouds do a very bad job of it and the air is not directed well or evenly to the cylinders. It is possible for someone to make a really good porsche system for a VW but no one has done it yet.
Jake Raby
PostPosted: Mon Mar 10, 2008 10:53 am    Post subject: Reply with quote
I concur totally.
BUT the VW engine faces some challenges that will be hard to overcome. The biggest issue is the fan's position on the case, being directly above the #2 and #4 cylinders... The 911 engine has its first pair of cylinders much father from the cooling fan exit.
I get calls and emails weekly from guys begging me to make a 911 system that works, but I have zero interest in the design.. The Carrera system I am working with now is my favorite design and a design that I feel will be much easier to effectively package, especially for the TI engine.
Jake Raby
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Mar 10, 2008 10:57 am    Post subject: Reply with quote
Twin fan center mount?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Jimmy111
Jimmy111 is offline
PostPosted: Mon Mar 10, 2008 11:04 am    Post subject: Reply with quote
It is really not so hard to do. It is just that the people designing the aftermarket systems have little knowledge or understanding of the technical aspects of the system. They are mostly after the coolness factor. Coolness sells.
Jake Raby
PostPosted: Mon Mar 10, 2008 11:30 am    Post subject: Reply with quote
Yep, coolness sells today with few cars being daily drivers.
Glenn,
I have replicated and updated the dual inlet fan and have recently created the mold for the fiberglass housing of the "X4CS" cooling system.
I spent a solid week in Wyoming with Bill Doyle doing solid works modeling and getting data from real 4 cam Carrera engines to assist with the newest addition to my DTM line...
I'll be done with it in mid 2009.
Jake Raby
Mr. 010
Glenn is offline
PostPosted: Mon Mar 10, 2008 11:35 am    Post subject: Reply with quote
Will it be a true "bolt in" or will it require some trimming like the DTM?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Jake Raby
PostPosted: Mon Mar 10, 2008 11:39 am    Post subject: Reply with quote
Trimming will be necessary and should be.. Because no two engines are the same and why leave big gaps for air to escape just to make it "easier to fit".
Jake Raby
Lionhart94010
Lionhart94010 is offline
PostPosted: Mon Mar 10, 2008 1:27 pm    Post subject: Reply with quote
Jake,
The 2009 ETA is that for the T4 only or for both T1 & T4 Carrera style cooling systems?
Also based on comments from Bob Hover:
"The maximum sustainable power available from any air-cooled engine is determined by the engine's ability to cool itself -- to couple its waste-heat to the atmosphere. And with a carburetted, spark-ignited, gasoline-fueled engine there is a lot of waste heat to be managed since such engines are no more than 25% efficient when it comes to converting the heat of combustion into torque at the crankshaft. That means that for every horsepower measured at the crank you must generate at least four horsepower's-worth of heat in combustion..."
http://bobhooversblog.blogspot.com/2008/02/another-100hp-vw-conversion.html
Can you please give us a ballpark figures for maximum sustainable power when using your current DTM system for T1. I like to go camping in mountains witch means I have to clime some long steep grades and would like to keep my engine HP(running at 3500-4000 RPM) within the ability of the Your DTM setup to cool it…
Regards,
Andre
Jake Raby
PostPosted: Mon Mar 10, 2008 1:43 pm    Post subject: Reply with quote
Cooling capability of an engine will forever determine the effectiveness of the cooling system it is coupled to.
If you have an aplication that is using 100% of it's output (like a Bus climbing a mountain) the max HP per cylinder I have used with a DTM is 40HP. At that level the engine was 160HP, not many people with an engine that large and powerful can sustain load long enough to use 10% of it's power.
The components that comprise the engine will determine this much more than the cooling system and things like Nickies cylinders give the engine a HUGE edge.
I plan on debuting the TI version of the Carrera system before the TIV version.
Jake Raby
Jimmy111
Jimmy111 is offline
PostPosted: Mon Mar 10, 2008 2:14 pm    Post subject: Reply with quote
The majority of the cooling in a VW engine is not from the fan. It is from the exhaust and the incoming air thru the induction system and just plain convection cooling from the exposed metal surfaces. This is why a free flowing head and exhaust system is so important.
Believe it or not a VW motor produces MORE heat than is supplied to it by the gasoline. This can be as high as 3 times as much heat as is burned in the gasoline. Most of this excess heat is supplied by heat of compression so the higher your compression ratio, the more heat your motor will develop.
\The fans primary use is to get air around the motor. If you take a stock motor out, remove all the shrouds and just set it on the ground and run it with no shroud, it wont get much above 400 CHT. I have done this in many cases with engines modified as air compressors and hydraulic pumps. The fans purpose is to get the air into the area where the motor is. Now, most people will never see the constand 40hp per cylinder that jake mentioned. They might reach their peak HP for a minute or so but in reality most people will only use 30 or 40 hp from their 160hp motor. The bigest problem that most people have whgen it comes to overheating is improperly set up oil system, bad ignition management and improper F/A mixture. A lot can be done to address overheating issues by just concentrating on those issues.
rearenddude
PostPosted: Mon Mar 10, 2008 5:30 pm    Post subject: Reply with quote
wow, i asked for opinions and i got them.
but let me be clear, i do not doubt the stock type 1 cooling system in a car designed for it, however my car came stock with a water-cooled engine.
as with a beatle the fiat also required air "closure" around the motor to direct the air flow correctly, however this is prooving to be a difficult task.
It would be a simpler task if the fan drew its incoming air from the generator side.
so therfore my question in reguards to the Porche style system.
prehaps i should ask if anyone has made a type 1 system draw air from the generator side?
rearenddude
PostPosted: Mon Mar 10, 2008 5:35 pm    Post subject: Reply with quote
again im very new to VW
can you tell me what a DTM is?
Jimmy111
Jimmy111 is offline
PostPosted: Mon Mar 10, 2008 6:30 pm    Post subject: Reply with quote
Type 3 motor would probably work better.
DTM is Jakes down the middle cooling system.
Lionhart94010
PostPosted: Mon Mar 10, 2008 6:35 pm    Post subject: Reply with quote
Thanks Jake,
That is valuable information, for my next motor! How much more do you think the Carrera style T1 cooler will be capable cooling?
Jimmy111,
Due to the size and design of the T1 Motor, cylinder head compared to the other air cooled motors I have been looking at for inspiration, I am concerned most about the heat they can dissipate, I agree that the motor must be looked at as a set of interdependent systems.
I have several "Bus" engines in the works, on my 2007cc 78x90 I will use the following parts to address the heat question:
Standard VW FI Fans shroud with velocity Ring(I have two different models one seems to have more development that the other)
I don't believe that I will be able to use a DTM with this setup because I’m using a Stock VW FI intake connected to CB FI end castings; I know that the CB FI end castings will limit intake air but they are larger than the Factory 1600cc FI intakes and this will not be a high revving motor, I need the lower end torque.
CB Center mount Fuel injection with a dash mounted Innovate F/A meter, to keep an eye on F/A
(I am limited to center mount FI because of the BN4 heater taking up lots of valuable space in Driver side of engine bay)
Full Flow Oil filter with thermostatically controlled external oil cooler, I have found several Thermostats ranging from 170 to 190, (I am leaning toward the 190 as it hopefully will only be needed on long hills and hot summer freeway driving, the stock or T4 cooler doing it for normal driving)
Originally, I was going to use an MSD-6 AL-2 with a stock SVDA distributor but I am now thinking of using a Mallory Unilite after reading many postings on thesamba.
Heads are CB 044 and have 40 x 35.5mm
Exhaust is 1 ½ Merged
Current compression ration is set to 7.2:1
Scat C25 Cam w/Stock Rockers
This motor will probably not make 160hP :0)
The DTM or Carrera style cooer will be for my 82x90.5 or some LN Nikes from Jake if I can afford them. (I already have most of mechanical long block parts)
For that motor I am hoping for 150-200 HP :0) It will have a MegaSquirt FI & ignition control and I will build a custom optimized air intake for it, and apply any and all lessons leaned from the data I collect from my 2007cc FI T1 motor.
rearenddude,
DTM stands for Down The Middle, it is a custom made cooling shroud currently being made and sold by Jake Raby
www.aircooledtechnology.com
I would think that keeping the incoming air coming from stock setup would be the simples way to go, the VW fan sits pretty close to the fire wall...
Can you post some pictures of your engine compartment to get an idea of what you are faced with?
rearenddude
PostPosted: Mon Mar 10, 2008 7:10 pm    Post subject: Reply with quote
a photo.
the bar directly behind the carbs and shroud is the engine mount.
the motor "hangs" from the top two tranny bolts.
rearenddude
PostPosted: Mon Mar 10, 2008 7:13 pm    Post subject: Reply with quote
sorry, crappy photo.
a good view of the engine bay is on this web site.
click the "home" tab above and in the galley search box type "fiat" then pick "go"
on page 2 you will be able to get the photo I sent in a viewable size.
Jimmy111
Jimmy111 is offline
PostPosted: Mon Mar 10, 2008 7:14 pm    Post subject: Reply with quote
Eh? You got one that has a few thousand more pictals in it??
