petrol punk Samba Member
Joined: August 21, 2007 Posts: 1035 Location: Las Vegas, NV
Posted: Sat Mar 29, 2008 11:28 am Post subject: removing Heater Tubes |
Trying to get my seized 36hp (Or is it 34hp in European models?) out of my '56 and the heater tubes are what's holding me back. I can't get these metal bastards off, my brother said on his '70 he just beat the shit out of them with a hammer until they fell out but I think I'll want to keep mine unless they're worthless. Any other ideas? _________________ 36hp '56 European DeLuxe oval
'70 bug 1835cc |
dgrnga Samba Member
Joined: February 06, 2006 Posts: 224 Location: Macon,Georgia
Posted: Wed Apr 16, 2008 5:52 pm Post subject: |
I had troubled getting my heat exchangers off of my 65, it has fresh air heating. I had success in using BP Blaster and letting them soak awhile, They seemed stuck to muffler area. 1 did OK , but other was really stuck, ended up prying muffler flang off around opening and had it repaired later ( re-welded together).
Not sure if this helps, but Good Luck!
Gordon |
Snort Samba Member
Joined: April 02, 2005 Posts: 1964 Location: Seattle, WA
Posted: Fri Apr 18, 2008 8:32 am Post subject: |
I've never done this on the car, but it might work.
You may be able to remove the J tube section of the heat exchanger from the motor, tie it up until you get the motor out, then it will be easier to work on it. Remove the front exhaust nuts, remove the control cable, remove the bottom screw that holds the J tube/control levers to the engine cooling tin, remove the muffler clamp, push the J tube forward off the exhaust studs and tilt down to remove the rear flap control rod from inside. |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9407 Location: Northwood, NH USA
Posted: Fri Apr 18, 2008 9:11 am Post subject: |
Snort wrote: |
Actually you could just remove the front half of each heaterbox and leave them in the car. Would be easier to get to them at that point and address the siezure.
If they are the early ones with screws or nut and bolt it would be easy. If they are later or after-production LMBs, you'll need to bend the tabs back, and it is all but impossible to bend them back without breaking them off. _________________ John Henry
'57 Deluxe
'56 Single Cab |
