gcan Samba Member
Posted: Sun Jun 08, 2008 2:40 pm Post subject: interior door release w/lock |
I don't know why but I can not find an interior door handle with the lock.
I have fond the release only but my 73 convertible doesn't have a seperate pull lock at the top of the door. The ones on it are chrome and have the pull knob with the lock switch below it as one unit. One is broken and I need to replace
Can anybody help? _________________ 73 vert |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Jun 08, 2008 3:30 pm Post subject: |
I can look around, but cannot promise anything. When side do you need it for. Left or right?? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
gcan Samba Member
Posted: Sun Jun 08, 2008 4:34 pm Post subject: |
the drivers side is the one that isn't working. We have to open the door from the outside.
I took it off today and it looks like the problem is the return spring is broken but the pin that holds it on does't look like it can be removed. So repleacement ismy best option.
What makes this so odd? what type do other convertibles have? How do they lock the door from the inside? _________________ 73 vert |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6150 Location: 37.5N 77.1W
Posted: Mon Jun 09, 2008 5:32 am Post subject: |
I think those handles with a lever for the lock is what is in Ghias too. Maybe easier to find that way. |
