Early Huf carb
kevm
kevm is offline
PostPosted: Sat Aug 02, 2008 2:10 am    Post subject: Early Huf carb Reply with quote
Hi All,
I just bought this carb off ebay, from the pics I couldn't tell what it was exactly but it only a tenner so I thought I could use it for spares if nothing else.
Anyway it arrived in the post today and it has a Huf logo, perfect for my 47 perhaps, but it looks a bit odd, can anyone help me identify it or post a pic of an original 40s Huf carb.
It doesn't have nuts either side of the throttle spindle and the mechanism looks a bit home made.
What do you think
Thanks
Kev
RareAir
RareAir is offline
PostPosted: Sat Aug 02, 2008 2:00 pm    Post subject: Reply with quote
I've got a HuF carburetor on my '47 as well. Here's a pic of mine (Left side) next to a later Solex 26VFIS carb
kevm
kevm is offline
PostPosted: Sun Aug 03, 2008 11:10 am    Post subject: carb Reply with quote
Great thanks Rareair, looks like I got lucky. One quick question about the linkage, is it the same as the solex, ie the same length and secured at the back in the same way ?
Cheers
Kev
RareAir
RareAir is offline
PostPosted: Sun Aug 03, 2008 2:42 pm    Post subject: Reply with quote
The linkage on mine is attachd with a series of springs, washers & a cotter pin
kevm
kevm is offline
PostPosted: Fri Aug 22, 2008 1:26 pm    Post subject: Reply with quote
Many thanks Rareair for the answers to my last questions but I have another, I took the carb apart to rebuild it today and have a problem in that the float is missing, comparing it to a solex carb the cut off valve is central over the bowl unlike the solex thats offset and operated by the pivoting arm which sits in the slot of the carb body.
I just need to know if I can use a solex float and cut off valve, bearing in mind there is no cut off operating arm in the Huf if I used the solex parts there would be more fuel in the carb before the cutoff valve kicks in, would that be a problem ? Maybe the original Huf cut off valve had a longer stem ?
Assuming your carbs are not on a car any chance you could compare the two sets of internals for me.
Cheers
Kev
meker
meker is offline
PostPosted: Fri Aug 22, 2008 6:26 pm    Post subject: huf Reply with quote
http://www.huf-group.com/home/openCms.nsf/documents/HistoryEnglish
HeSa
HeSa is offline
PostPosted: Sat Aug 23, 2008 2:05 am    Post subject: Reply with quote
Kevin Maddock wrote:
....comparing it (the float) to a solex carb the cut off valve is central over the bowl unlike the solex thats offset and operated by the pivoting arm which sits in the slot of the carb body....
Solex 26VFI has the same structure as the "Huf?" you are describing. 26VFIS with the non-centered cut off and pivoted float is first seen in 1950 parts book.
kevm
kevm is offline
PostPosted: Sun Aug 24, 2008 1:33 pm    Post subject: Reply with quote
Ok cheers thats helpful info, anyone have a parts diagram for a 26VFI ?
Thanks
Kev
HeSa
HeSa is offline
PostPosted: Sun Aug 24, 2008 3:31 pm    Post subject: Reply with quote
Here are pictures from 46 and 49 parts books. The one from 49 looks like yours. Send me a pm with your email if you want bigger pictures.
