72 Super popping out of reverse
ofcdoug
ofcdoug is offline
PostPosted: Mon Sep 01, 2008 5:56 pm    Post subject: 72 Super popping out of reverse Reply with quote
my 72 S.B. is popping out of reverse. I know the shift rod bushing needs to be replaced but I dont think thats the problem. Any sugestions??
homeworld8118
homeworld8118 is offline
PostPosted: Mon Sep 01, 2008 7:07 pm    Post subject: Reply with quote
yea same hear in my 74 sb(but its a 73 pan + drive train). Its just fine in every other gear but quite often does it pop out when in reverse. If all's right in the world it actually goes in you can just feel the gears lock in but most of the time i doesn't feel like it. I always just assumed that the reverse gear wasn't in the proper alignment any more. I don't use reverse often so i never worried a whole lot about it with mine, but it would be nice to hear some info on the topic.
BUGSTUFF
BUGSTUFF is offline
PostPosted: Mon Sep 01, 2008 7:29 pm    Post subject: Reply with quote
Hmm, our '72 Super does the same thing. Fluid was changed, bushing was changed, coupler was changed and the clutch cable was changed & adjusted to specs. Still does it so I'm assuming it's something internal.
Kirk
Northeast IL VW Association - www.nivaclub.org
www.facebook.com/nivaclub
Volkswagen Club of America - www.vwclub.org
Bob Loblaw
Bob Loblaw is offline
PostPosted: Mon Sep 01, 2008 10:05 pm    Post subject: Reply with quote
If it's popping out of gear, and the shift linkage is aligned, you're gonna have get inside the trans, my friend. No external adjustments to be made.
Or swap it out for a fresher tranny.
sent from a phone using poor grammar and spelling
Bruce
Bruce is offline
PostPosted: Mon Sep 01, 2008 10:09 pm    Post subject: Reply with quote
Bob's right, the problem is inside the gearbox. On the late gearboxes, it is ALWAYS the small reverse idler gear that is worn out. Crappy metalurgy is the cause. It should be swapped out now instead of waiting, otherwise, you risk damaging the 1-2 slider as well. New late model 1-2 sliders are not available new.
BUGSTUFF
BUGSTUFF is offline
PostPosted: Thu Sep 04, 2008 1:10 pm    Post subject: Reply with quote
Can the small reverse idler gear be replaced with the trans still in the car? I'm planning on doing an engine swap soon.
Hey ofcdoug, know anyone in the area who works on transmissions?
Kirk
Bruce
Bruce is offline
PostPosted: Fri Sep 05, 2008 12:06 am    Post subject: Reply with quote
Nope.
And you have to take the gearbox apart to do it.
Terrispots
Terrispots is offline
PostPosted: Sun Sep 21, 2008 9:24 pm    Post subject: Reply with quote
We had the same issue on our 74, a trans is inexpensive and was easy enough just to replace! We had some engine removal and reinstall issues, then a clutch issue, but all in all, I think it will be worth it.
74 Super Beetle
08 Scion xB RS 5.0
Lotrat
Lotrat is offline
PostPosted: Sun Sep 21, 2008 9:33 pm    Post subject: Reply with quote
Reverse is the weakest gear. Someone said that you should always hold the stick in reverse to make it last longer and to prevent it from popping out...
rterfert
rterfert is offline
PostPosted: Sun Sep 21, 2008 10:47 pm    Post subject: Reply with quote
number 57 the brass gear carrier is probably worn
Holding it in reverse will only prolong the problem.
It's an easy fix, once you get inside the trans case Very Happy
They do make a later steel version (if that's the case?)
the gear might just be toast.
Bruce
Bruce is offline
PostPosted: Mon Sep 22, 2008 1:12 am    Post subject: Reply with quote
IMO that will accelerate the wear on the reverse lever's fork. This will make it pop out of gear sooner than if you keep your hand off the shifter while backing up. VW specifically advises against holding onto the shifter while driving. You shouldn't hold ANY gear engaged while moving.
Terrispots
PostPosted: Mon Sep 22, 2008 5:13 pm    Post subject: Reply with quote
If you are already going to have the engine out its only another 10 mins to pull the trans and it would be easier to work on. Set it up on the work bench for easy reach instead of working on it upside down.
74 Super Beetle
08 Scion xB RS 5.0
