Electrical problem with blinkers and wipers on my 66 Bug
jnoble
Banned
jnoble is offline
PostPosted: Sat Dec 06, 2008 6:59 pm    Post subject: Electrical problem with blinkers and wipers on my 66 Bug Reply with quote
I have a 66 bug that is having electrical problems with the blinkers and wipers. The blinkers will flash a few times and then stop. The wipers used to work intermitantly but quit all together. I do not know if this is all part of the same trouble, but when driving at night with my headlights on and I turn the blinkers on, the car spits and sputters. I have new generator brushes in and also a new voltage regulator. Any help would be great, Thanks!!
roy63
roy63 is offline
PostPosted: Sat Dec 06, 2008 7:03 pm    Post subject: Reply with quote
check the wires to see if you are getting good continuity. make sure the connections are clean and that you have the correct voltage. make sure your grounds are good...
MyBuild http://www.thesamba.com/vw/forum/viewtopic.php?t=571921
Some day when the rust is gone, I will at last found inner peace... (Peace has Been Found)
"Wide awake, and keeping distance from my soul"
Sigurd
Sigurd is offline
PostPosted: Sat Dec 06, 2008 8:30 pm    Post subject: Reply with quote
The flash-a-few-times-then-die blinker syndrome means you need a new relay. It's shot.
Define 'intermittent' for the wipers. Did they make a pass and stop? Change speed? Make three passes and stop straight up?
jnoble
Banned
jnoble is offline
PostPosted: Sun Dec 07, 2008 11:28 am    Post subject: Reply with quote
at first they would make a pass then stop. Then they needed help from me to go, then they stopped completely.
