brazing?
enjoispammy8
enjoispammy8 is offline
PostPosted: Thu Dec 18, 2008 6:59 pm    Post subject: brazing? Reply with quote
is brazing as good as welding for a battery tray?
1969 Westy, 1690cc. montana red and cloud white.
1969 Standard Beetle [sold]
Watch My Movies: https://www.youtube.com/user/taylorlikesacdc
Desertbusman wrote:
Is there a message here? Enjoy Spammy Ate
EZ Gruv wrote:
Way to fuck up some little kids riding in the car next to you.
hazetguy wrote:
you need to be doing better drugs.
View user's profile Send private message Send e-mail AIM Address Facebook Gallery Classifieds Feedback
Wildthings
Wildthings is offline
PostPosted: Thu Dec 18, 2008 8:41 pm    Post subject: Reply with quote
Not as quick and easy as welding, but if done well it should work. Others probably will disagree.
Depending on the level of damage you have, you might consider using fiberglass on yours. Use multiple layers and do a careful job and you should have something that will last for decades. I like glass because it is quick and easy, doesn't burn your paint, and doesn't rust. Again others will disagree.
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Thu Dec 18, 2008 8:46 pm    Post subject: Re: brazing? Reply with quote
Yes.
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
enjoispammy8
PostPosted: Thu Dec 18, 2008 8:56 pm    Post subject: Reply with quote
thanks for the answers. i plan on getting my front floors welded, but because the engine is in the way, i wont be getting the battery tray welded. but when i pull the engine over winter break, it looks like i will be brazing in a new tray!
busdaddy
busdaddy is offline
PostPosted: Thu Dec 18, 2008 9:44 pm    Post subject: Reply with quote
Why braze and not weld when the engines out?
You have to be super careful to get ALL the flux off the joint or anything you put on it will bubble up. Shurely someone you know can get thier hands on a 110V pocket mig. Brazing creates alot of heat that can warp your corner to s**t too, be careful.
I'd weld if given the choice personally.
Слава Україні!
enjoispammy8
PostPosted: Thu Dec 18, 2008 9:46 pm    Post subject: Reply with quote
im not sure if my welding friend can transport his equipment, but i will be sure to ask him.
busdaddy
busdaddy is offline
PostPosted: Thu Dec 18, 2008 10:00 pm    Post subject: Reply with quote
Call your local rental outfit, I'd rather battle a gassless 110V MIG than cook my corner tacking in a battery tray.
Don't get me wrong, brazing has it's place and is great for some repairs, but the middle of large, flattish body panels isn't one of them.
Слава Україні!
enjoispammy8
PostPosted: Thu Dec 18, 2008 10:58 pm    Post subject: Reply with quote
well i have no welding experience of any kind, but thanks for all the ideas.
donemoto
donemoto is offline
PostPosted: Fri Dec 19, 2008 7:49 am    Post subject: Reply with quote
If you don't have any experience you should not braze or gas weld. As others have said warpage will occur if not careful. Also the flame will burn out and away thin rusted renants of the metal. For something as easy as a batterry tray to replace; try getting a new one and po rivetting it in place then use seam sealer to waterproof.
If mig is used; try to get good penetration. Avoid big popcorn welds that hold only to the surface of the metal.
Your best bet may be to pop rivet it in; then, later, have someone tack it where the rivets were.
1975 Campmobile
1962 Bug Convertible
Homebuilt VW Trike
1966 HD Sprint H
1940 HD ULH Flathead
1985 Electra-glide Classic with Tour-Pac
1968 Harley Rapido
1968 Honda CL Scrambler 175cc
1962 Honda Cub 50 Step-thru
1980 Honda Cub 70
rneithammer
rneithammer is offline
PostPosted: Fri Dec 19, 2008 10:55 am    Post subject: Reply with quote
I agree with Busdaddy - get yourself a small MIG welder. That's what did when I put in my new battery tray, and did absolutely no damage to the exterior paint. My welder uses gas (C25) but I suppose gasless will work, too. MIG is easy to learn - easier than OXY or stick.
Blaubus
Blaubus is offline
PostPosted: Fri Dec 19, 2008 11:57 am    Post subject: Reply with quote
i have heard over and over again that brazing promotes rust.
with all the questions about brazing, it would be worthwhile to weld regardless of extra cost.
alikatcraig
alikatcraig is offline
PostPosted: Fri Dec 19, 2008 3:30 pm    Post subject: Reply with quote
If you can find a TIG inverter, then brazing is fine with silicon/bronze rod. It will give you a very strong joint that has better resistance to stress than mig, doesn't rust, and needs no flux. Brazing with gas is messy on a car and puts too much heat into the panel.
Best stick to mig. It can help to drill/punch 1/4" holes on battery tray raised edge and puddle the weld into this hole onto the rear panel. It will duplicate the factoty spot weld look. Just remember not to put too much heat into a small area to avoid distortion. A damp rag on the outside panel can help.
Al
1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug
dreamaker33
dreamaker33 is offline
PostPosted: Fri Dec 19, 2008 3:56 pm    Post subject: Reply with quote
Has anyone tried using a torch with silver sauder or something like that?
'71 bus
Air_Cooled_Nut
PostPosted: Fri Dec 19, 2008 8:23 pm    Post subject: Reply with quote
Ooo, uhm, yeah...I agree w/the others, have a pro do it for you. Learning on your ride leads to more expensive repairs.
The First Invasion
Northstate Trev
Northstate Trev is offline
PostPosted: Sat Dec 20, 2008 9:53 am    Post subject: Reply with quote
I think the biggest problem with braving or silver soldering a pan repair would be the level of cleanliness for the process. Your metal has to be shiny clean to get a proper job. With welding you can get away with a little rust, it will include in the weld, whereas the braze or solder will not bond and you'll have a void.
On sheet metal just keep low heat and a small tip.. 000... and be prepared to move fast
Good Luck
56 oval
66 Sunroof Sedan 1776 POWER(Daily Driven)
71 Bay Deluxe
72 Super Beetle Baja Champion SE
73 FI Squareback
59 Willys pick-up
38 Plymouth Coupe
akscooter
akscooter is offline
PostPosted: Sat Dec 20, 2008 1:09 pm    Post subject: Reply with quote
As others have said go mig or tig if you braze you will warp the panel, newer cars that are not older than the 60s will most likely warp, the bigger and flatter the panel the more chance of you warping it. if it was pre-60s or 50s and earlier, no problem. if you haven't welded..maybe consider fiberglassing.
1975 campmobile
1949 Ply Special Deluxe
1991 Custom 1200 HD Sportster XLH
chazz79
chazz79 is offline
PostPosted: Sat Dec 20, 2008 2:35 pm    Post subject: Reply with quote
sears sells a flux core wire feed (gasless mig) for 130. If you have a harbour freight nearby you can get a simular unit for under a hundred bucks. You won't lay a pretty bead with either but for spotting in a panel it'll work fine. Buy one and practice, it'll be worth the investment in the long run.
One day as a lion, or a lifetime as lamb
The green monster in bits and peices: http://www.thesamba.com/vw/forum/viewtopic.php?t=332556&highlight=green+monster
busdaddy
busdaddy is offline
PostPosted: Sat Dec 20, 2008 5:45 pm    Post subject: Reply with quote
There's always body panel adhesive too, no heat or welding skills required.
Слава Україні!
enjoispammy8
PostPosted: Sat Dec 20, 2008 6:05 pm    Post subject: Reply with quote
where is this sold? o and my panels came. hooray.
busdaddy
busdaddy is offline
PostPosted: Sat Dec 20, 2008 6:09 pm    Post subject: Reply with quote
Any body shop supply should stock it, it's how the plastic door skins are attached on Saturns and the like. I wouldn't install rockers or anything structural on a body designed to be spot welded, but it'll hold up a battery tray just fine.
Слава Україні!
