Rear tire carrier
yellowvan
yellowvan is offline
PostPosted: Mon Feb 23, 2009 2:08 am    Post subject: Rear tire carrier Reply with quote
I would like a rear tire carrier to bold my 15" spare but don't want to pay $600 or more. Has anyone tried adapting one from a junked Pathfinder or other car and has it worked well? I've seen burly ones on old broncos and others on jeeps and sportages that might work with some cutting and welding back together.....
McVanagon
McVanagon is offline
PostPosted: Mon Feb 23, 2009 3:32 am    Post subject: Reply with quote
Check out page two. I love recycling.
http://forums.vwvortex.com/zerothread?id=2444476&page=1
'69 Mike
'85 GL
'87 Wolfsburg Hardtop
View user's profile Send private message Twitter Instagram Gallery Classifieds Feedback
jfarsang
jfarsang is offline
PostPosted: Mon Feb 23, 2009 8:56 am    Post subject: Reply with quote
Bronco's, Jeeps, they all work with little to no modding
'86 Westy 2.1
'94 TD Delica spacegear
'86 TD Syncro camper - gone to a good home
'72 Baja bug (project) - can't seem to leave us
'92 TD Delica camper - gone to a good home
WestyBob
WestyBob is offline
PostPosted: Mon Feb 23, 2009 8:58 am    Post subject: Re: Rear tire carrier Reply with quote
The only ones I'm familiar with are the Broncos - two different types but the mounting brackets are very close to the vanagon contours. Need a little shaping to fit perfectly. I have two in waiting but haven't installed yet. McVanagan's link is to Eric's past project where he installed one.
yellowvan
PostPosted: Mon Feb 23, 2009 9:50 am    Post subject: Reply with quote
thanks guys, sounds like the Bronco 2 is the way to go. I was thinking Pathfinder cause I believe it is a bit wider across the back and may be able to accomidate a big fuel can as well. Time for a little junk yarding! I will report back if I find a pathfinder carrier and how it would fit- it would be nice to stow a can back there like the RMWesty carrier (their $600 carrier!).
allsierra123
allsierra123 is offline
PostPosted: Mon Feb 23, 2009 9:57 am    Post subject: Reply with quote
also one from a kia sportage will work only needs a little reinforcement around a 00 I heard.
95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold
Outback Kampers
Outback Kampers is offline
PostPosted: Mon Feb 23, 2009 10:15 am    Post subject: Reply with quote
The Pathfinder unit fits very closely to the curve of the corner. You can modify the mounts if you'd like, I wasn't too worried as the body on my old van is already rough and you can see the small deformity anyway. I did have to fabricate a reinforcement plate inside the corner to support the bolts, and another inside the rear lid to support the latch, but this thing is bomber! I can stand on it and it doesn't give--super heavy duty. I also cut the original studs (6-lug) and welded in three for the Vanagon pattern. Then added some angle iron for a fuel can holder. Total cost? $75 + time.
[/i]
Karl Mullendore
1990 Syncro 16" sunroof Reimo highroof conversion
1990 Westy Multivan 112i automatic
1992 LT31 Karmann Distance Wide 'La Tortuga'
2014 Touareg X TDI
GWTWTLW
GWTWTLW is offline
PostPosted: Mon Feb 23, 2009 11:56 am    Post subject: Reply with quote
Thx Karl! Any chance of getting a pic or 2 of the the mounting?
I am in the same boat. I've tried to make the VanCafe spare tire carrier work but I can't get it to stop rubbing on the steering column. I think it's time for plan B. As much as I'd like one of the Gary Lee racks or carriers, my "financial advisor" (i.e. wife) is rather reluctant at this point.
Thx!
89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw
Outback Kampers
PostPosted: Mon Feb 23, 2009 12:23 pm    Post subject: Reply with quote
If I were to do it over, I would have mounted the hinges about 3/4" higher--you see where the latch plate ended up going! No worries, that rear lid is dented and rustyed out anyway. Wink
Karl Mullendore
2014 Touareg X TDI
Last edited by Outback Kampers on Mon Feb 23, 2009 12:27 pm; edited 1 time in total
GWTWTLW
GWTWTLW is offline
PostPosted: Mon Feb 23, 2009 12:24 pm    Post subject: Reply with quote
Thx!
@gwtwtlw
Tristar Eric
Tristar Eric is offline
PostPosted: Mon Feb 23, 2009 12:54 pm    Post subject: Reply with quote
That looks like it fits really well. Is there another bolt besides the two visable ones on the sides of the anchors?
I like the extra wide, the Bronco carrier is only good enought to carry a tire.
Vanagon/Transporter flares here: www.terrawagen.com
[email protected]
Outback Kampers
PostPosted: Mon Feb 23, 2009 1:09 pm    Post subject: Reply with quote
Yes, there is a bolt from behind as well, you can almost see the recess in the top hinge photo. So three bolts on each hinge. There was a fourth but that is the part that gets cut off.
Karl Mullendore
2014 Touareg X TDI
allsierra123
PostPosted: Mon Feb 23, 2009 1:16 pm    Post subject: Reply with quote
ebay sales of pathfinder spare tire carriers just doubled.
mblotz
mblotz is offline
PostPosted: Mon Feb 23, 2009 2:07 pm    Post subject: Reply with quote
which vehicle will give a Driver side swing? or can the pathfinder one be flipped to swing on the driver side?
hiram6
hiram6 is offline
PostPosted: Mon Feb 23, 2009 2:17 pm    Post subject: Reply with quote
Many Pathfinders have been flipped, but usuallly due to driver error. Laughing Laughing
Thanks, I'll be here all the week. Try the veal!!
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
Crughy
Crughy is offline
PostPosted: Mon Feb 23, 2009 5:10 pm    Post subject: Reply with quote
The generation 1 Kia Sportage is on the driver side. it's a common one too.
JP
yellowvan
PostPosted: Mon Feb 23, 2009 6:46 pm    Post subject: Reply with quote
Love it!
JeffRobenolt
JeffRobenolt is offline
PostPosted: Mon Feb 23, 2009 7:54 pm    Post subject: Reply with quote
Has anyone tried a full size Bronco?
For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com
vinnyvango
vinnyvango is offline
PostPosted: Mon Feb 23, 2009 8:35 pm    Post subject: Reply with quote
Awesome Karl! I saw 2 at the pullapart (I went to pull a complete EJ22 turbo.....that got crushed the day before...DOH!).
You say you wished you had mounted it a little higher. When you get a chance would you mind measuring from, say, the bumper to the bottom mount so I can get an better idea of fitment.
Thanks.
Shawn
84/90 Westy/EJ22 sadly non-turbo
Bruce Wayne
Bruce Wayne is offline
PostPosted: Mon Feb 23, 2009 9:34 pm    Post subject: Reply with quote
how about this one!
http://eugene.craigslist.org/pts/1018349889.html
