Ball joints and camber question
djsun
djsun is offline
PostPosted: Sun Mar 01, 2009 9:06 pm    Post subject: Ball joints and camber question Reply with quote
Are both top and bottom ball joints concentric for adjusting camber or just the top one. I have replaced both top and bottom ball joints and after adjusting the top one 90 degrees out the wheel still has positive camber.
____________________________________________________
Video of the car in action
http://www.youtube.com/user/djsunproductions
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Mar 01, 2009 10:33 pm    Post subject: Reply with quote
Both are eccentric, but ideally you only adjust the tops, so you don't mess up the steering lock angles.
djsun
djsun is offline
PostPosted: Sun Mar 01, 2009 10:35 pm    Post subject: Reply with quote
but if you had them both out to replace them where do you set the bottom one?
KTPhil is offline
PostPosted: Sun Mar 01, 2009 10:43 pm    Post subject: Reply with quote
There is usually a mark on the end of the ball stud that faces forward as a starting point. You then turn the uppers up to 90 degrees each way.
If you really can't adjust to get the right camber, something is bent, like a torsion arm or the beam.
djsun
djsun is offline
PostPosted: Sun Mar 01, 2009 11:06 pm    Post subject: Reply with quote
I might be crazy, but when I turn the tops I can see the roter lean in and out but when I turn the bottoms I can see any movement.
KTPhil is offline
PostPosted: Mon Mar 02, 2009 9:41 am    Post subject: Reply with quote
Are you measuring on the ground or on jack stands?
djsun
djsun is offline
PostPosted: Mon Mar 02, 2009 2:42 pm    Post subject: Reply with quote
the car is on jack stands and I'm using a floor jack to hold up the lower control are to "Ride hight". When I turn the upper balljoint I can see the top of the rotor lean out and then back in and I sping the ball joint, but I dont see any movement when i spin the bottom one.
KTPhil is offline
PostPosted: Mon Mar 02, 2009 2:57 pm    Post subject: Reply with quote
Unfortunately, the BJ front ends are harder to diagnose bent parts on than the link/kingpin setups on the old bugs. For those you just needed a couple of straightedges. You need jigs for the BJs.
