g16stu Samba Member
Joined: January 12, 2009 Posts: 94 Location: NETHERLANDS
Posted: Tue Mar 17, 2009 1:35 am Post subject: '72 Spark Plug Removal |
I’m taking the plugs out of my '72 Westie and its a bitch! Does anyone have any tips on how to make this even a little bit easier, the search came up with a few recurring themes, i.e.
1) Remove the fan
2) Cut a hole in the engine bay roof and fit a later access panel
3) Ditch the bus and buy a later bay!
The main feeling I get though is that it’s just a bitch to do and I just need to get on with it and do it?
Suggestions please! _________________ '72 westie
All comments made are in accordance with the Rules of the Yorkshire County Cricket Club. |
Traveling Writer Samba Scribe
Joined: May 07, 2006 Posts: 1112 Location: Florence, Italy
Posted: Tue Mar 17, 2009 2:19 am Post subject: |
Relax, man! They're just spark plugs!
Yes, 72s can be a pain to work on sometimes because of the lack of access hatch, but there are plenty of people who love them and have learned to work around them. What exactly is the problem? Get a few different lengths of extenders for your ratchet, feel around with your fingers a lot to get a sense of the angles (they're all in there at funky angles, esp #2), maybe get a mechanic's mirror just so you can see what's back there till you get used to it.
BUT if the problem is that the plugs are not wanting to turn out, then be careful, or you'll be posting a thread about stripped spark plug holes next... Make sure the engine is COLD when removing plugs. Cold metal is harder. Use some penetrating oil spray on the plugs if they're tightening up as you turn them out, or if they feel too tight. Use a drop of motor oil or anti-seize on the threads when putting them back in, and torque them to the proper values: 3MKG or 22 foot-pounds.
More info please! And don't swap the bus or lose heart, for god's sake! Go slow and enjoy what you're doing!  _________________ Cheers,
Davi
1977 2.0 FI Westy
2011 1200cc Yamaha Super Tenere
1976 Feet (they work surprisingly well) |
g16stu Samba Member
Posted: Tue Mar 17, 2009 2:31 am Post subject: |
ha ha, dont worry, im not gonna cut up my bus and im definatly not selling it! theres no big problem really, im gonna get them out, am just looking for tips. as for doing it with the engine cold, theres no trouble there, the fecker wont start so ive got no choice!  _________________ '72 westie
Posted: Tue Mar 17, 2009 3:39 am Post subject: |
| g16stu wrote: |
ha ha, dont worry, im not gonna cut up my bus and im definatly not selling it! theres no big problem really, im gonna get them out, am just looking for tips. as for doing it with the engine cold, theres no trouble there, the fecker wont start so ive got no choice!  |
Whew! You know, when I first got my bus a few years ago, I knew nothing about them. I still don't know that much, but I did notice one thing: If you're new at it, after a while, a half year or a year or something like that, you somehow turn this magical corner where you understand enough about what's going on and have enough confidence and experience that working on the bus becomes this wonderful feeling of joy. I can't explain it better than that, but I'll say the third time you take out your plugs, your face will still be pressed against the back bumper, your arms will still be getting scratched, but you'll be whistling while you do it!
That said, two good threads:
http://www.thesamba.com/vw/forum/viewtopic.php?t=180224&highlight=hatch
http://www.thesamba.com/vw/forum/viewtopic.php?t=221901&highlight=spark+plug+removal _________________ Cheers,
Davi
1977 2.0 FI Westy
atmellovw Samba Member
Joined: September 05, 2006 Posts: 1652 Location: Minnesota
Posted: Tue Mar 17, 2009 5:46 am Post subject: |
Use a spark plug socket with a rubber insert to hold the plug when it comes loose otherwise you run the risk of the plug dropping into the abyss. What problem are you having? _________________ 1972 Westy ("Bubbles") - Pastel White - 1700(1974 MT) - Dual Solex |
g16stu Samba Member
Posted: Tue Mar 17, 2009 6:13 am Post subject: |
Yeah , I’m using one of those, its just a pain to line up the plugs is all. Anything that can speed this up and reduce the amount of time I spend sitting in the street is a bonus.
I’m thinking I might make some marks on the top of the engine compartment that I can line the ratchet extension up with before I pull the plugs, then when I put them back in at least I have a rough guide instead of fishing around and swearing a lot!
Why didn’t the Germans just make the holes bigger and put bigger rubber bungs on the leads? surely the extra rubber isn’t that expensive? or put a lead in the castings to guide the plugs in?
Are the holes located along the centreline of the hole perpendicular to the tin, maybe I could make a bushing locate to the tin and guide the socket and plug in?
ok, now I’m thinking too much! overkill I think! I'm just gonna keep fishing away and hope i get a "feel" for it J _________________ '72 westie
Posted: Tue Mar 17, 2009 6:26 am Post subject: |
Ultimately, you can feel the hole itself on all the plug holes except #2 (unless you have freakishly long fingers, maybe). All the holes and the plugs are set at weird little angles, not straight up and down. Before you pull them, run your fingers around them, feel around a lot, to get a sense of the angle you'll have to gently start turning them back in. OR you will crossthread them! SO, pull off the wires, feel the plugs up good to understand that weird angle. Also look at how the plug wires sit; that'll show you the angles too. All the bottoms are in a little toward the center of the engine; the tops are all further out from the center, about 10 degrees. All of them point in toward the center...ie the BASE of # 2 plug (bottom right) doesnt just point a little to the left, but also a little toward the front of the bus as well. The BASE of #3 (top left) points down a bit and to the right a bit. Get it? Not so important taking them out, but a pain putting them back correctly. #2 is the most tricky, it has the most angle (15%) but luckily, even if you had the hatch, it's easier to do from the rear. Move the air cleaner, I think, just loosen it a bit and you'll have room. _________________ Cheers,
Davi
1977 2.0 FI Westy
Posted: Tue Mar 17, 2009 6:28 am Post subject: |
A pic from Ratwell.com shows a stripped version of the right side of your engine, cylinders #1 and 2. See the angles?? The back of the bus is to the left in this pic.
Davi
1977 2.0 FI Westy
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53267 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Mar 17, 2009 6:42 am Post subject: |
Use a second plug socket and extension and put it on the opposite plug temporarily, then you have something to show you the angle you are aiming for, remember it's a mirror image though. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
g16stu Samba Member
Posted: Tue Mar 17, 2009 6:44 am Post subject: |
I like it! good thinking!  _________________ '72 westie
cambarner Samba Member
Joined: October 27, 2010 Posts: 101 Location: Southern Maine
Posted: Fri Nov 27, 2015 1:10 pm Post subject: |
| atmellovw wrote: |
| Use a spark plug socket with a rubber insert to hold the plug when it comes loose otherwise you run the risk of the plug dropping into the abyss. What problem are you having? |
Soo... what happens when I do drop the plug into the abyss??
I have a 72 that was only running on 3 cylinders, I went to switch the plugs to see if that was the problem, and no I have a bus with one (possibly) bad plug, and one plug that is dropped in that mystery cavity?? any advice?? _________________ 1972 Microbus, AKA 'SurfBus' |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13633 Location: West Coast, USA
Posted: Fri Nov 27, 2015 2:18 pm Post subject: Re: '72 Spark Plug Removal |
Big-ass magnet on a stick? I have a heavy duty one of these, and it could easily lift a spark plug. The end is approximately 2cm wide.
Grabber tool?
_________________ WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
timvw7476 Samba Member
Posted: Fri Nov 27, 2015 2:34 pm Post subject: Re: '72 Spark Plug Removal |
I never understood the need for a magnet-on-a-stick,
till I started driving a bus.
The engine is wrapped in a tin clam shell. |
Posted: Fri Nov 27, 2015 2:55 pm Post subject: Re: '72 Spark Plug Removal |
One on the handiest tools I have is a small super strong magnet duct taped to the end of a two foot piece of hanger wire. You can bend it to suit the situation. _________________ 1972 Westy ("Bubbles") - Pastel White - 1700(1974 MT) - Dual Solex |
Posted: Fri Nov 27, 2015 3:32 pm Post subject: Re: '72 Spark Plug Removal |
Got it out with a magnet and a hanger! Thanks guys! _________________ 1972 Microbus, AKA 'SurfBus' |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1706 Location: The Old Pueblo
Posted: Fri Nov 27, 2015 3:54 pm Post subject: Re: '72 Spark Plug Removal |
when reinstalling the plugs put a little oil or wd40 on them and start them with the plug in the socket and use your fingers, not the wrench to get them started. I have experience stripping the holes and hope you dont have to if your careful. Its too easy to think its a just a bit rough to turn and wrecking the threads. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Fri Nov 27, 2015 4:29 pm Post subject: Re: '72 Spark Plug Removal |
I always found that having two sparkplug sockets was helpful, one with the rubber insert and one without. The one without was easier to orient onto the sparkplug and then to loosen but then switch to the one with the insert to complete the removal. Then reverse these steps for reinstallation. Note that if you use the one with the insert to reinstall all the way you may find that when you go to remove the wrench the extension will pull out of the socket leaving the socket affixed to the plug! Just my thoughts... _________________ 1972 Westy ("Bubbles") - Pastel White - 1700(1974 MT) - Dual Solex |
Posted: Fri Nov 27, 2015 6:24 pm Post subject: Re: '72 Spark Plug Removal |
| atmellovw wrote: |
| I always found that having two sparkplug sockets was helpful, one with the rubber insert and one without. The one without was easier to orient onto the sparkplug and then to loosen but then switch to the one with the insert to complete the removal. Then reverse these steps for reinstallation. Note that if you use the one with the insert to reinstall all the way you may find that when you go to remove the wrench the extension will pull out of the socket leaving the socket affixed to the plug! Just my thoughts... |
If you are really into this, you can braze a socket onto an extension so the extension can't be pulled free from the socket.
Seems that most engines I have taken the tin off of over the years have a extra plug or three laying on top of the heads and cylinders. Doesn't seem to hurt much though it seems pretty shoddy to leave them there verse fish them out. |
Sloride Samba Member
