Camper flooring question
vw57drvr
vw57drvr is offline
PostPosted: Mon Mar 23, 2009 10:14 am    Post subject: Camper flooring question Reply with quote
Just curious, but to the guys that have put wood flooring in their camper, did you put it under the sink, jump seat and z bed? Anyone have pictures of this? Im about to put some laminate wood in mine. I have everything out, so Im wondering if everything will fit back in ok if I put the wood across the entire floor( with the exception of the mounting brackets). Next question is in what order is the best way to put everything back in? Mine is a 69 by the way.
60 Rock Grey Vert
Orangeena
Orangeena is offline
PostPosted: Mon Mar 23, 2009 10:19 am    Post subject: Reply with quote
I did not extend the flooring underneath the zbed. I think it would boost it too high for the fixing places on the back shelf to work well. Also my zbed has its own floor, so it would not need another one.
Cheers
Max
1973 Bay in L20B
- Originaly a panel van
- Partial Westy Interior
- Viking Spacemaker roof
- Slider of a donor bus
- Doors imported from Australia
- 22nd Owner !
vw57drvr
vw57drvr is offline
PostPosted: Mon Mar 23, 2009 10:22 am    Post subject: Reply with quote
Makes sense, so what did you use to trim it off? around the edges of the furniture?
60 Rock Grey Vert
Orangeena
PostPosted: Mon Mar 23, 2009 10:30 am    Post subject: Reply with quote
I did not add any trim to the edge of the zbed, just butted the particle board up and then tiled right up to it. the other furniture does sit on the floor so no problem there.
Below is a picture I took for another thread about the edging. Might help
Cheers
Max
1973 Bay in L20B
- 22nd Owner !
hazetguy
hazetguy is offline
PostPosted: Mon Mar 23, 2009 10:42 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=220546&highlight=laminate
http://www.thesamba.com/vw/forum/viewtopic.php?t=127233&highlight=laminate
http://www.thesamba.com/vw/forum/viewtopic.php?t=294269&highlight=floor
http://www.thesamba.com/vw/forum/viewtopic.php?t=300314&highlight=floor
http://www.thesamba.com/vw/forum/viewtopic.php?t=275921&highlight=floor
http://www.thesamba.com/vw/forum/viewtopic.php?t=260485&highlight=floor
http://www.thesamba.com/vw/forum/viewtopic.php?t=198832&highlight=floor+replacement
vw57drvr
vw57drvr is offline
PostPosted: Mon Mar 23, 2009 10:43 am    Post subject: Reply with quote
Looks good. The only concern I have is that with me using pergo type floor, I have to cut the edges on each sheet. If they arent perfect, it is gonna show.
60 Rock Grey Vert
uiterwyk
uiterwyk is offline
PostPosted: Mon Mar 23, 2009 10:50 am    Post subject: Reply with quote
The original vinyl flooring with underlay, etc was almost 1/2" high. This is why the inner mounts for the jump seat and the front mounts for the z-bed are up about 1/2".
I put in a laminate floor a few weeks ago. It consisted of:
Laminate Flooring (5/16")
Thin foam plastic they sell as underlay
1/4" plywood
Roofing felt.
That came to just about 9/16" It fit nicely under the jump seat, z-bed, icebox, and closet.
Note: the original floor DID NOT go all the way under the z-bed, just up o (not around) the front raised mounts.
I used Plantation Oak Laminate at Lowes, which (IIRC) is about 52 inches long. Anyway, if fit perfectly up to the z-bed mounts without any cutting. And..., a single box does the whole thing with one plank left over. The only cutting I had to do was holes for the 2 inner jump seat mounts and ripping the last plank the correct width to fit.
For the edge, I used a ceramic tile trim Lowes sells. It is 5/16" and fits perfectly around the edge of the laminate and is held in place with some Sumo glue.
p.s Yes, the icebox is a transplant from a 1972 bus. If anyone wanted to trade me for a 68-70 color laminate icebox......[img][/img]
1970 Hardtop Westy w/1600DP - "Betsy"
2009 VW Tiguan AWD
vw57drvr
vw57drvr is offline
PostPosted: Mon Mar 23, 2009 10:55 am    Post subject: Reply with quote
Thanks uiterwyk. That helps a lot. Looks great. And Hazet guy, I appreciate you doing a search and posting the results, but I have been through most of those threads without the exact answer I needed. My specifics were really about whether to go under the furniture and what effects that would have, and the order in which to re install the furniture. So, if it offends you to have another floor thread, as soon as I get good answers, we can have it deleted.
60 Rock Grey Vert
SuperSamba
Samba False Idol AI
SuperSamba is offline
PostPosted: Mon Mar 23, 2009 12:11 pm    Post subject: Reply with quote
In the future, please add to an existing thread so people can find everything in a single place.
DSM8
DSM8 is offline
PostPosted: Mon Mar 23, 2009 2:05 pm    Post subject: My wood flooring Reply with quote
I cut the floor around the sink, removed the fridge/stovetop and cut the flooring just under the door of the bed. Made things alot easier to fit, and no one sees under the bed anyway. Could'nt believe how easy it was.
static
static is offline
PostPosted: Tue Mar 24, 2009 6:28 pm    Post subject: Reply with quote
Please refrain from posting any question, comment or suggestion about anything, ever. Any and all knowledge about everything VW-related has been covered before and doing do just makes self-important pouty-lipped misanthropes post "do a search". Shortly, this will be a frozen website that functions as an encyclopedia instead of as a living community of users.
akscooter
akscooter is offline
PostPosted: Tue Mar 24, 2009 7:44 pm    Post subject: Reply with quote
Ah yes, mumbo jumbo gumbo Brick wall
1975 campmobile
1949 Ply Special Deluxe
1991 Custom 1200 HD Sportster XLH
71_georgia_beetle
71_georgia_beetle is offline
Wikisamba
71 Standard Beetle "Big Bird"
74 Westfalia "Winifrid"
Call me if I need you!
www.burelphotography.com
vw57drvr
vw57drvr is offline
PostPosted: Wed Mar 25, 2009 6:45 am    Post subject: Reply with quote
Very nice clean interior. Im about to start mine, but it just started raining.
60 Rock Grey Vert
Rubber Duck
Rubber Duck is offline
PostPosted: Wed Mar 25, 2009 7:35 am    Post subject: Reply with quote
I didn't go under in mine as well. I believe the subfloor has to go under...there's some spacers that came with the bed for that. But the actual floor did not fit under the bed.
In hindshight, maybe I should've gone with a thinner subfloor, I went with the recommendations of some members here, but I also put a little bit of foam underlay (the kind that goes under laminate anyway) and that little bit is what added up.
This is the original trim piece that came with the bus, as well as the white plastic piece. It cleans up good with dishwashing liquid.
As you can see, the flooring goes fine under the jump seat as well as the fridge/cooler thing.
The net result though, is quite nice, to my eyes at least Smile
And yes, someday...I will change the canvas. I think its just about the ONLY thing left for me to do Shocked
Rubber Duck
1974 Westfalia
Gr8tfulEd
Gr8tfulEd is offline
PostPosted: Wed Mar 25, 2009 7:49 am    Post subject: Re: My wood flooring Reply with quote
Dang that looks sharp. Is there a frig or icebox in that layout?
1973 Kombi Riviera camper named "Belle"
1979 Super Beetle Convertible named "Otto"- daily driver
itlives
itlives is offline
PostPosted: Wed Mar 25, 2009 7:53 am    Post subject: Reply with quote
I removed everything. It worked better for me becuse I wasn't going back with the original fridge. I still have to get a trim piece for the door edge. The original one doesn't fit.
[IMG]
With the back seat in.
http://img182.imageshack.us/img182/396/trannyinteriorstickers0iw6.jpg[/IMG]
vw57drvr
vw57drvr is offline
PostPosted: Wed Mar 25, 2009 8:01 am    Post subject: Reply with quote
Very nice and clean. I do not have that original trim piece at the sliding door unfortunately. Seems like someone took this thing apart, then lost all of the little pieces. Trim, screws, etc.
60 Rock Grey Vert
uiterwyk
uiterwyk is offline
PostPosted: Wed Mar 25, 2009 9:31 am    Post subject: Reply with quote
Like I said before, I did not have the trim either, so I used this from Lowes:
http://www.lowes.com/lowes/lkn?action=productDetail&productId=62442-1255-10831&lpage=none
They say white, but it is actually silver color. When I was at my local store, they also had this in gold color.
It fits just over the edge of the laminate. (You don't need to worry about the sub floor, because where the laminate stops at the door, there is none.)
Robert
2009 VW Tiguan AWD
afhusband
afhusband is offline
PostPosted: Wed Mar 25, 2009 12:04 pm    Post subject: Reply with quote
I did extend mine under the bed. Mind you I do not have the stove or fridge in mine either. Or the cabinets for that matter!
The bamboo flooring from Home Depot came with the trim peices. i just had to do a little cutting.
I think it looks pretty good!
1974 TinTop Westy -I'm Lovin it!!
Glass blowing, banjo pickin, bay-window bus driver.
vWYo New aircooled club for Cheyenne WY and surrounding areas!
