SSChicken Samba Member
Posted: Mon Mar 30, 2009 9:24 am Post subject: Types of Steel? |
I'm still trying to get into metal fabrication, but a little leary on the lingo here. I called my local steel shop and asked for:
' 2 Inch round stock steel, .090"
and he said:
' I don't have that, I've only got schedule 40, try shop xyz '
I'm not used to using schedule measurements on steel, only on PVC so far.
So what is the correct terminology I should be using? was what I said correct? I kindof know what I want (2" x .090 and something 1.5"), but I'm not sure what the correct lingo is.
Also, what is a good thickness for 1.5", just for general use like light bars or whatever. I wouldn't dream about doing anything structual yet
Sorry for the super newbie question but I come from a family of carpenters so I'm all alone in the metal working world! |
joescoolcustoms Samba Member
Posted: Mon Mar 30, 2009 9:33 am Post subject: |
You are close on terminology.
Tubing is sized in the true thickness as in your 0.090 inches.
"Pipe" thickness is sized in the schedule table.
You will need to go to a supplier that carries tubing and not pipe. 0.090 is good for light bars. 0.120 is best for bumpers and cages. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
earthquake Samba Member
Joined: January 10, 2008 Posts: 4005 Location: SANDY VALLEY, NEVADA
Posted: Mon Mar 30, 2009 9:35 am Post subject: |
SSChicken
next time tell them you are looking for "tubing", Pipe is measured by "ID"
while tubing is measured by "OD", you never want to use pipe for any roll cage, I guess it would not hurt to make bumpers out of it other then the fact that you would need different dies for you bender for pipe and tubing.
.090 wall 1 1/2 round tubing would be fine for most bumpers I would think. I hope this helps.
Earthquake _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20882 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Mar 30, 2009 9:41 am Post subject: |
For main roll cage members 1.5 OD (or 1-5/8), .120 DOM (Drawn Over Mandrel) is probably best because its stronger then plain "mild steel" tubing and not near as expensive as chrome molly tubing....
For non-cage bracing 1.5 inch .090 wall is probably sufficient...
I believe Schedule 40 refers to PLUMBING PIPE not STEEL TUBING.... The key phrase here is "tubing" and you search should take you to steel sales & suppliers not plumbing supplies....
http://www.engineeringtoolbox.com/ansi-steel-pipes-d_305.html
And time somebody throws a "zinger" at you and infers you dont know what you are asking for do a little GOOGLE search and become informed buyer or searcher....
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Mon Mar 30, 2009 9:47 am Post subject: |
| Dale M. wrote: |
For main roll cage members 1.5 OD (or 1-5/ , .120 DOM (Drawn Over Mandrel) is probably best because its stronger then plain "mild steel" tubing and not near as expensive as chrome molly tubing....
And time somebody throws a "zinger" at you and infers you dont know what you are asking for do alittle GOOGLE search and become informed buyer ot searcher....
Dale |
Thanks for all the info, helps a bunch. I asked for pipe specifically, but I'm assuming he misheard me perhaps? I can't imagine they don't have any, I called Cliff's Welding who doesn't do any (or very little) plumbing from what I've seen. They are the ones who did the upstanding job on my my windshield frame, bent a 1/8" piece of flat stock laterally around the frame o.0 Pic
Anyways, I might call them again and ask what thicknesses they have in 2" tube and see if I get a different answer. I'm guessing he misheard me or perhaps I accidently said pipe.
Thanks all for the info though, learn something every day  |
runslikeapenguin Samba Member
Joined: August 07, 2005 Posts: 4674 Location: Federal way WA
Posted: Mon Mar 30, 2009 12:13 pm Post subject: |
also instead of throwing around super fancy terms like CREW (cold rolled electric welded) and DOM (drawn over mandrill) use the terms, seamed and seamless. _________________ never forget 1-31-07 |
dustymojave Samba Member
Joined: January 07, 2007 Posts: 5842 Location: Lake LA, Mojave Desert, SoCal
Posted: Mon Mar 30, 2009 11:23 pm Post subject: |
"Seamless" tubing is another animal RLAP. And far more expensive. DOM has a seam which spirals, but the tubing is drawn over a mandrel after the seam is welded, which metallurgically reduces the effects of the seam as well as visually.
If the people at the steel supply aren't familiar with terms such as "CREW" and "DOM", I'd head to another supplier. _________________ Richard
SoCalBajas Member
STOICH Samba Member
Joined: November 26, 2004 Posts: 1101 Location: Fallbrook
STOICH Samba Member
Posted: Tue Mar 31, 2009 8:21 am Post subject: |
| Quote: |
| I did a stint out of state once |
What is your deffinition of "Stint"? Which Prison in which state?
In KY they call all of it Piipe (with emphisis on the i). I was in Western NY and they called it tobing.
In TN I heard it all called pipe. Water Pipe, Drain Pipe, Fence Pipe, muffler pipe and cage pipe.
The DOM also sizes the wall thickness very consistantly. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Glasser Samba Member
Joined: September 18, 2007 Posts: 1643 Location: Calgary Alberta Canada
Posted: Tue Mar 31, 2009 9:23 am Post subject: |
| dustymojave wrote: |
If the people at the steel supply aren't familiar with terms such as "CREW" and "DOM", I'd head to another supplier. |
Funny all the DOM I have seen has a straight seam along length of tube...
Posted: Tue Mar 31, 2009 9:40 am Post subject: |
| Dale M. wrote: |
Dale |
There is something to that.... My neighbor bought a roll bar (pre fab type) and they stated it was DOM. Looked more like ERW to me. My DOM has no seam and a spiral effect that you can faintly see going the full length of the tube. But it is definitely not a seam. _________________ Brent
My build up http://www.thesamba.com/vw/forum/viewtopic.php?t=265364&postdays=0&postorder=asc&start=0
Project#2. Neighbors build up. http://www.thesamba.com/vw/forum/viewtopic.php?t=327008 |
Posted: Tue Mar 31, 2009 9:56 am Post subject: |
| Quote: |
That is the way DOM is supposed to look. The inside mandrel smooths out the seam to where it is almost undetectable, visually and by feel and the outside mandrel does the same thing. The process rotates which produces the twisted appearance.
If it has a visable seam, and is in a straight line, it is not DOM. Someone is selling you a bill of goods. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Terry Cloyd Banned
Joined: March 23, 2004 Posts: 2218 Location: Valley Center "SO CAL"
Posted: Tue Mar 31, 2009 2:14 pm Post subject: |
| If your building a car you need to look at OD size. The OD is what you can buy dies to bend your frame parts. I think your roll bar needs to be .095 1 1/2 OD. |
Posted: Tue Mar 31, 2009 5:42 pm Post subject: |
Ok so yesterday I picked up a 20 foot length of 1-1/2" x 0.120 from a different proveder. Cost $55 (fair price?). My sole intention with this bit is for practice, so that's what I've been doing. Just welding tubes together, I'll be cutting this up and welding it to something else in another fashion here pretty soon, also be cutting some of the welds just to see the penetration (which I think was a little low this time around).
I'm using a Lincoln 3200HD which I have liked very much, I really have no formal training and most of what I do know comes from http://www.mig-welding.co.uk/ , though I'm planning on taking a course this summer some time.
I'm also using the 60 degree tubing notcher from Harbor Freight. It's TERRIBAD! The shaft wouldn't turn when I bought it, and it's like 1/8" off to one side. I cleaned and polished the shaft, and put some spacer washers in so that the holes are centered finally. Also the degree marker is completely off, 45 degrees actually makes a ~35 degree notch, so I'm just going to start using a protractor to measure from now on. Maybe I'll make my own scale on the notcher using the protractor as a guide. 39 bucks, though, so I can't complain too much. 39 bucks, and a little over an hour rebuilding it, polishing the shaft and bearings, oiling, etc. and I feel it will work for what I need. The ridgid bimetals I use with it kick ass, though. Not sure I'll be able to change blades since it's probably jammed on too tight, but I'll tackle that when it comes to.
Anyways, after all that babbeling, the reason I am posting is to show you my welds. They aren't perfect and I'm just asking you constructive criticism. Does it look like I've got too much/little power, feed? do I move too fast or slow? Are these welds acceptable? (not pretty >.<) They have just been cleaned with a wire wheel.
Again, this is 1.5" .120.
Thanks!
hendersoned Samba Member
Joined: November 23, 2007 Posts: 80 Location: Las Vegas, NV
Posted: Tue Mar 31, 2009 5:54 pm Post subject: welds |
| try a bit more heat (amps) the welder should have a nice steady sizzle not pop pop pop |
Bubba 72 Samba Member
Joined: December 18, 2006 Posts: 416 Location: Roanoke, Va.
Posted: Tue Mar 31, 2009 6:03 pm Post subject: |
It looks to me like you need to turn up your wire speed a little and try the heat up one notch. I use a little less than 3 for wire speed and C for heat. You can always back off to find a good setting for both.
Try to rest your gun hand on something while you weld and you will get way more consistant faster. I use both hands as much as I can.
Then again, I might be full of crap and some of the other guys I hope will say so. _________________ Stand on it! You can fix broke stuff later! |
Posted: Tue Mar 31, 2009 7:57 pm Post subject: |
| Bubba 72 wrote: |
| It looks to me like you need to turn up your wire speed a little and try the heat up one notch. |
Alright now I'm up at D - 3.5, It looks alot better but doesn't penetrate the steel all the way. Isn't it supposed to? It is a smooth sizzle, also, not pop pop pop. I do notice on the other side that it is cutting into the metal, a bit, though.
Is this any better? |
Posted: Tue Mar 31, 2009 8:01 pm Post subject: |
Slow down a little and burn through. Watch as you burn through to see just what it looks like. Then try welding slow enough to just keep ahead of burning through.
And practice, practice, practice. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
