allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Sat May 30, 2009 12:22 pm Post subject: torque converter question |
I am having trouble getting it to move to line up the bolt holes. The tranny and engine are mated togther in the van, Do I need to put it in nuetral or have the rear wheels in the air? Looked around online couldnt find the answer. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
mike boland  Samba Member
Posted: Sat May 30, 2009 12:57 pm Post subject: Re: torque converter question |
| allsierra123 wrote: |
| I am having trouble getting it to move to line up the bolt holes. The tranny and engine are mated togther in the van, Do I need to put it in nuetral or have the rear wheels in the air? Looked around online couldnt find the answer. |
put it in neutral, make sure your wheels are blocked. you don't want it to roll. put a socket & ratchet with short extension on the crankshaft pulley bolt If I recall correctly it is a 36MM. turn engine over by hand watch for bolts to line up in hole on case. there are 3 bolts. break first bolt loose, but do not remove... move on to next bolt break it loose then do last one, then go on back to other two bolts and remove those. It's nice to bag N tag your parts too.. |
Posted: Sat May 30, 2009 1:01 pm Post subject: |
OK would I do that in the reverse order for reinstall? _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
Posted: Tue Jun 02, 2009 12:43 pm Post subject: |
| OK would I do that in the reverse order for reinstall? |
yes, you would... |
Posted: Tue Jun 02, 2009 1:01 pm Post subject: |
| The torque converter should spin freely against the flex plate, the transmission does not need to be in neutral, park, or any gear, makes no difference. If it does not spin freely I would be concerned you didn't have the shafts splined correctly before you put everything is place. |
Posted: Tue Jun 02, 2009 4:21 pm Post subject: |
It was spinning I just doing it right, _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
