dogcoves Samba Member
Joined: September 09, 2005 Posts: 266 Location: Santa Cruz, CA
Posted: Sun Sep 13, 2009 5:28 pm Post subject: Strange sound after engine is shut off |
I just got back from a 3 day camping trip and when I pulled into the driveway, turned off the motor, a strange sound came from the front of the vehicle. Sounded as if a small motor was whining down. I started my 87 Vanagon again and something wasn't right. Once again when I shut the motor off a weird sound of something spinning/whining continued a few seconds after. I just had a new radiator and fan put in a few months ago. Anyone got any idea what's going on? _________________ Current VW: 1987 Westfalia
My Past Volkswagens:
1958 karmann ghia
1963 Beetle
1963 Westfalia
1966 Westfalia
1970 Beetle
1970 Westfalia |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sun Sep 13, 2009 5:37 pm Post subject: Re: Strange sound after engine is shut off |
dogcoves wrote: |
I just got back from a 3 day camping trip and when I pulled into the driveway, turned off the motor, a strange sound came from the front of the vehicle. Sounded as if a small motor was whining down. I started my 87 Vanagon again and something wasn't right. Once again when I shut the motor off a weird sound of something spinning/whining continued a few seconds after. I just had a new radiator and fan put in a few months ago. Anyone got any idea what's going on? |
Did it sound just like a radiator fan running?
I have no idea what that could be... _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Sun Sep 13, 2009 6:44 pm Post subject: Re: Strange sound after engine is shut off |
levi wrote: |
I have no idea what that could be... |
No doesn't sound like that. _________________ Current VW: 1987 Westfalia
1958 karmann ghia
1963 Beetle
1963 Westfalia
1966 Westfalia
1970 Beetle
1970 Westfalia |
riceye Samba Member
Joined: March 09, 2006 Posts: 1712 Location: Caledonia, WI
Posted: Mon Sep 14, 2009 6:17 am Post subject: Re: Strange sound after engine is shut off |
dogcoves wrote: |
Check to see whether or not your right-hand a/c knob on the dash is in the off position. If the knob is turned, even a little, the radiator fan will run until you switch off the ignition, and will spin down causing such a sound. _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
Posted: Mon Sep 14, 2009 1:27 pm Post subject: Re: Strange sound after engine is shut off |
riceye wrote: |
Check to see whether or not your right-hand a/c knob on the dash is in the off position. If the knob is turned, even a little, the radiator fan will run until you switch off the ignition, and will spin down causing such a sound. |
Yep that was it--my 3 year old daughter must have turned it a bit at one of our stops. Living in Santa Cruz and camping mostly on the coast I have never used the air conditioning. Now I know that the A/C works. _________________ Current VW: 1987 Westfalia
1958 karmann ghia
1963 Beetle
1963 Westfalia
1966 Westfalia
1970 Beetle
1970 Westfalia |
