Syncro help! Shuddering at 10-20mph
thedavidson
thedavidson is offline
PostPosted: Tue Oct 06, 2009 2:10 pm    Post subject: Syncro help! Shuddering at 10-20mph Reply with quote
I searched the forums and couldn’t find any problems that sounded like what is going on with my Syncro. As I accelerate or decelerate, at around 10-20mph the van shudders and it feels like I am driving on a washboard. It happens even when I pull it out of gear. The engine is not sputtering or varying rpms when this is happening which makes me think it is not the engine. Could this be transmission, cv joints, viscous coupling, etc? Thanks for any help!
jpwerks Premium Member
jpwerks is offline
PostPosted: Tue Oct 06, 2009 2:50 pm    Post subject: Reply with quote
Could be your driveshaft.Maybe bad universals.
81' single cab 1.8T Syncro (converted)
85 Vanagon 1.8T
55 chevy
2008 330i BMW
2000 jetta 1.8T
2004 Golf 2.0
WestyBob
WestyBob is offline
PostPosted: Tue Oct 06, 2009 3:04 pm    Post subject: Re: Syncro help! Shuddering at 10-20mph Reply with quote
Could be the driveshaft needs adjustment/rebuild or replacement. But could also be suspension related. How's the alignment ? Any tire bulges or something stuck in there (inspect) ?
blakeck2
blakeck2 is offline
PostPosted: Tue Oct 06, 2009 3:20 pm    Post subject: Re: Syncro help! Shuddering at 10-20mph Reply with quote
mine does that occasionally and its a 2wd Confused
View user's profile Send private message AIM Address Facebook Classifieds Feedback
Alaric.H
Alaric.H is offline
PostPosted: Tue Oct 06, 2009 5:10 pm    Post subject: Reply with quote
The last time I saw a syncro do something like that the trans nose got riped off from the bad vibes.
Dogpilot
Dogpilot is offline
PostPosted: Tue Oct 06, 2009 5:27 pm    Post subject: Reply with quote
Could be the driveshaft, but could also be one of the eight CV joints as well. A loose or worn out CV can cause odd vibrations to move back through the system.
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
Grizzly_black
Grizzly_black is offline
PostPosted: Tue Oct 06, 2009 10:25 pm    Post subject: Reply with quote
The front outer CV joints vibrate something fierce when they go dry and are shot. It also makes a lot of noise. Turn slightly back and forth while driving at the speed where it is loudest. If the noise gets louder when you are turning the wheel it is probably the outer CV. I have a bad one on my syncro right now. I am up in the Alaskan bush, so 20 mph is about my average speed on dirt roads. I can't wait for my Lobro axles to get here. The noise is driving me nuts!
Sir Sam
Sir Sam is offline
PostPosted: Tue Oct 06, 2009 10:46 pm    Post subject: Reply with quote
Had a similar problem on my 87 syncro years back, replaced the U-joints and the problem went away.
'91 Carat Westy
87' Syncro + '87 Westy conversion coming soon
thedavidson
PostPosted: Wed Oct 07, 2009 1:58 pm    Post subject: Reply with quote
Sounds like the place to start would be to pull the drive shaft. I will give it a try and report back. Thanks again.
'86 Syncro
thedavidson
PostPosted: Mon Oct 12, 2009 11:56 am    Post subject: Reply with quote
Pulled and replaced the drive shaft yesterday. The front U-joint was nearly frozen in one direction. The problem seems to be fixed for now. Thanks again for the advice!
'86 Syncro
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Mon Oct 12, 2009 12:37 pm    Post subject: Reply with quote
did you rebuild your existing shaft or buy a new one?
