Plate under front seat
napat
napat is offline
PostPosted: Sun Nov 08, 2009 9:23 pm    Post subject: Plate under front seat Reply with quote
Have you ever notice there is a plate located under front seat (passenger seat for RHD)
There are some digits indicate something.
For my experience with T1 and T2 ... I could say the plate looks the same with m-plate for my old bus.
All digits in the plate can be decoded and the result will be the option, factory colour, upholstery, date of manufacture and etc.
Is it the m-plate for T3 (vanagon)? Anyone can translate the code?
Thanks,
PAT
love double cab
napat
napat is offline
PostPosted: Mon Nov 09, 2009 8:36 am    Post subject: Reply with quote
Question Question Question Anyone seen this plate?
love double cab
iceracer
iceracer is offline
PostPosted: Mon Nov 09, 2009 10:47 am    Post subject: Reply with quote
I have seen those plates but couldn't tell you what they mean.
86 Syncro Wolfsburg edition
63 Beetle (The Iceracer)
Tristar Eric
Tristar Eric is offline
PostPosted: Mon Nov 09, 2009 11:32 am    Post subject: Reply with quote
That plate tells the factory what should be installed on your van at time of manufacture. There is a decoder somewhere on the net, I've seen it.
There's another sticker that should be under your fuse box that has even more info. It will show your VIN, engine type, trans code, interior code, model code, paint code, and any "M" codes you have (options).
On the later models, there is also another barcode plate riveted onto the end of the left front bumper stamping.
Vanagon/Transporter flares here: www.terrawagen.com
[email protected]
napat
napat is offline
PostPosted: Mon Nov 09, 2009 11:45 am    Post subject: Reply with quote
Thanks iceracer and Eric Smile
If you find the decoder please let me know.
Maybe there are some interesting codes in my dcs.
love double cab
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Mon Nov 09, 2009 10:41 pm    Post subject: Plate under front seat Reply with quote
here is a list of m-codes i found, hope it helps. Not guaranteed to be completely accurate nor the last word in m-code decoding Smile
M-??? Leuchtweitenregelung
M-??? Automatic Beckengurte auf den mittleren Sitzplï¿_tzen hinten (Feuerwehrausstattung)
M-??? Schmutzfï¿_nger vorn
M-001 Allradabschaltung mechanisch
M-002 5-Gang Transmission
M-003 1,9 Liter 44kW 4 cylinder Carburettor engine DF
M-010 Preparation of the rear seat for tiltable backrests
M-012 Controlling of exhaust gases (vor 1985)
M-013 Passenger seat bank 2 sitzig
M-014 Stone deflector for drive belts
M-015 Seat with folding seat-back in the passenger compartment 3-sitzig
M-016 Seat in the passenger compartment in the back 3-sitzig
M-017 Seat in front in the passenger compartment 2-sitzig
M-018 umschï¿_umtes steering wheel
M-020 Speedometer in mile announcement
M-025 Instrument housing for speedometers with trip odometer and clock, and/or speedometers with daily mile counter and clock
M-026 Activated charcoal filter to catching fuel steams
M-027 Fulfillment of the exhaust regulations California 255 (catalyst and fuel filler neck)
M-028 without stretchers (only for KTW II)
M-032 lockable gas cap
M-034 High beam warning lamp blue Italy, FG 24 B 079862 -->
M-038 Be void the driving cab seats with the Joker
M-050 Warning lamp for attractive emergency brake and brake fluid conditions
M-051 Connection and mounting elements for a second alternator prepares for the admission of a climatic compressor
M-053 Material coverings Colortweed strip
M-053 Pad reference material material " Feincord" (old in front Mj. 1987)
M-054 lockable glove compartment LLKG
M-055 Refrigerant compressor petrol engine, Sanden 510 (ca. 5 kW/7 PS)
M-055 changed installation of the refrigerant compressor with TD with Zusatzaggregaten, Sanden 510 (ca. 5 kW/7 PS)
M-057 without strakes (plank bed, Doka)
M-058 Bumper and spoiler such as model Carat
M-060 Additional heating system Eberspï¿_cher DA6 od. BA6 (no Standheizung)
M-061 Geschwindigkeitsanzeige in miles, temperature in degrees of F, city headlight, Great Britain
M-062 Outside mirror on the right of convex and seat belts in front and in the back
M-064 without Bordwï¿_nde (245-248)
M-065 Writing data for axle load and total weight
M-066 Floor mat (rubber) in the loading space (box car) and/or in the passenger compartment (Kombi)
M-067 54 Ah Battery
M-068 2 Towing eye in the back
M-070 Cover for plank bed cars
M-071 Second flap in the side part
M-073 Roof with cut-out for camping cars
M-074 Splash guard in the back (in Austria series with Syncro)
M-080 Sliding door with window or high sliding door with window
M-081 Sprossenwand hinter Fahrersitz
M-089 Windschutzscheibe in Verbundglas
M-092 Gebirgsï¿_bersetzung (nur Hinterradantrieb nicht Allrad)
M-093 Schiebefenster in der Seitenwand hinten gegenï¿_ber der Schiebetï¿_r (ganz links hinten)
M-094 Klappe hinten abschlieï¿_bar (245-248)
M-099 M+S Stahlgï¿_rtelreifen 185 R 14 C
M-099 M+S Stahlgï¿_rtelreifen Fulda Kristall 185 R 14 C
M-102 beheizbare Heckscheibe (nicht kombinierbar mit M-127 Rï¿_ckwandklappe ohne Fenster)
M-103 verstï¿_rkte Stoï¿_dï¿_mpfer vorn und hinten (nicht Allrad)
M-106 Polsterstoff anstelle von Kunstleder (Wirkvelours braun)
M-113 CANADA VERSION 253-255
M-115 4 Zylinder Diesel Motor 1,7 L 42 kW KY
M-121 Heizung und Belï¿_ftung mit Geblï¿_semotor (245-256)
M-121 elektrische Be- und Entlï¿_ftung auf dem Dach
M-122 bis Modelljahr 1986: 1,6 Liter 37 kW 4 Zylinder Dieselmotor 24 B 079862 -->
M-122 ab Modelljahr 1987: Vorbereitung der Hintersitzbank fï¿_r schwenkbare Rï¿_ckenlehnen. Mittelsitzbank wird versetzt und
entgegen der Fahrtrichtung eingebaut. (Einbau erfolgt ï¿_ber KDW Hannover). Vorbereitung zum Einbau
der Utila-Krankentrageneinrichtung (ï¿_ber KDW Hannover)
M-123 2,1 Liter 70 kW 4-Zylinder Digijetronic Einspritzmotor MV
M-124 Scheinwerferlampen Gelblicht Frankreich
M-127 Rï¿_ckwandklappe ohne Heckscheibe
M-130 Krankenwagen
M-135 Krankenwagen (253,254)
M-136 Krankenwagen mit Einrichtung
M-137 vorbereitet fï¿_r Campingwagen Joker 3
M-140 Feuerlï¿_schfahrzeug (253) mit Normausstattung nach DIN 14 502
M-141 Dachluftansaugkanal fï¿_r Verbrennungsluft
M-142 Dachluftansaugkanal fï¿_r Verbrennungsluft links und rechts
M-143 Krankenwagen mit Einrichtung und zusï¿_tzlicher Ausrï¿_stung nach DIN 75080
M-144 Beckengurte fï¿_r M-580
M-144 elektrische Fondsitze fï¿_r Carat, nur mit M-558
M-145 Sicherheitsschloï¿_ fï¿_r Schiebetï¿_r und Rï¿_ckwandklappe (251)
M-146 Fahrer- und Beifahrersitz mit klappbaren, hï¿_henverstellbaren Armlehnen
M-148 Zwei elektrisch verstellbare Einzelsitze im Fahrgastraum
M-149 lackierte anstelle verchromter Teile
M-150 Krankenwagen mit zusï¿_tzlicher Ausrï¿_stung nach DIN 75080 (253,254)
M-151 COMPLIANCE WITH EXHAUST EMISSION STANDARTS (253,255) USA
M-153 Zyklonluftfilter und Vergaser ohne Vergaservorwï¿_rmung fï¿_r 1,6 Liter 4 Zylinder Vergasermotor, Krï¿_mmer mit Zyklonfilter fï¿_r Diesel
M-156 Cyclone air cleaner for dust-rich countries with diesel engine JX
M-157 2,0 Liter 4 Zylinder Jetronic Motor fï¿_r Schweden--> FG A 300000; 1,9 Liter 60 kW, 4 Zylinder Digi Jetronic Motor FG 24 D 051580-->
M-158 Tropenkï¿_hler mit verstï¿_rktem Kï¿_hlerlï¿_fter
M-159 ï¿_se fï¿_r Vorhï¿_ngeschloï¿_ (251,253)
M-160 Rundumkennleuchte blau, Starktonhornanlage
M-162 Gummileisten auf Stoï¿_fï¿_nger
M-164 Stahlgï¿_rtelreifen 195 R 16 C 8 PR
M-165 Wartungsklappe abschlieï¿_bar
M-168 Geeichtes Angleichgetriebe fï¿_r Wegstreckenzï¿_hler
M-171 Stahlgï¿_rtelreifen 185 R 14 C
M-172 Visible location of brake fluid reservoir. ( Benelux countries )
M-173 Bereifung 205/70 R 14 - 97 reinforced, nur in Kombination M-173 + M-401 Felgen 6x14
M-176 Fï¿_hrungsschienen gegenï¿_ber der Schiebetï¿_r und an den Trennwï¿_nden (247,253)
M-177 Sitzbank hinten mit Klapplehne hinten und zusï¿_tzlicher Sitzmï¿_glichkeit im Laderaum 12-Sitzer
M-178 Fï¿_hrungsschienen auf den Bodenblechen (247,253)
M-179 3 Punkt Automatic Sicherheitsgurte imFahrgastraum --> FG 24 A 300000
M-181 verchromte anstelle lackierter Teile (=verchromte Radzierdeckel)
M-183 Hï¿_ftgurte im Fahrgastraum (247-256)
M-184 Dreipunkt Automaticgurte vorn
M-186 Dreipunkt Automaticgurte auf allen ï¿_uï¿_eren Sitzplï¿_tzen imFahrgastraum
M-187 Scheinwerfer fï¿_r Linksverkehr
M-188 Tropenausfï¿_hrung fï¿_r Fahrzeugeinsatz in warmen Lï¿_ndern mit grï¿_ï¿_eremWasserkï¿_hler oder verstï¿_rktem Kï¿_hlerlï¿_fter fï¿_r Diesel
M-189 Zusï¿_tzlich mit zweitem Drehstromgenerator
M-193 Erfï¿_llung der Abgasvorschrift und elektrische Ausfï¿_hrung, Japan
M-194 Auï¿_enspiegel konvex
M-198 Rundumkennleuchte rot
M-201 Groï¿_raum Holzpritsche
M-206 abblendbarer Innenspiegel
M-207 Getriebeï¿_bersetzung 34:7 syncro
M-208 Anhï¿_ngevorrichtung Kugelkopf (bei syncro abnehmbar) und elektrische Teile fï¿_r Anhï¿_ngerbetrieb,
M-210 Differentialsperre vorn
M-217 Verdeck in Fahrerhaushï¿_he fï¿_r Pritsche und Doka
M-218 Mit Typenschild ohne Angabe "West-Germany"
M-219 Zwangsentlï¿_ftung fï¿_r die hinteren Seitenfenster, Serie ab Modelljahr 1988 bzw. Entlï¿_ftungsschlitze in den Seitenwï¿_nden Kastenwagen
M-220 Differentialsperre hinten
M-221 Ausstellfenster in der Fahrertï¿_r
M-222 1,6 Liter 37 kW 4 Zylinder Dieselmotor CS
M-226 Halteseile fï¿_r Ladeklappe hinten (245-248)
M-227 Kopfstï¿_tzen im Fahrerhaus
M-229 Kopfstï¿_tzen im Fahrgastraumje Sitz (bei Carat incl. Kissen)
M-231 Sitz-/Liegebankeinrichtung
M-238 Tagesfahrlichtschaltung Schweden
M-240 1,6 Liter 37 kW 4 Zylinder Vergasermotor mit Muldenkolben fï¿_r Kraftstoff mit niedriger Oktanzahl
M-249 3-Gang Automatic Getriebe
M-251 1,9 Liter 57 kW 4 Zylinder Vergasermotor DG
M-251 2,0 Liter 51 kW Vergasermotor--> 24 C 200000; 24 F 000001=S799;--> 24 D 040000 1,9 Liter 57 kW Vergasermotor 24 D 000001-->
M-254 einknï¿_pfbare Gardinen im Fahrgastraum
M-259 Antennenleitung fï¿_r die Funkantenne von Fahrerhaus-Dachmitte zur Funkgerï¿_tehalterung links neben dem Beifahrersitz. Reiï¿_verschluï¿_ im Dachhimmel.
M-262 Laderaumabdeckung
M-263 Tragfï¿_higkeit 1.2 kg / erhï¿_htes Gesamtgewicht 2.600 kg
M-277 geï¿_nderter Schalldï¿_mpfer Schweiz (spï¿_ter auch D und A)
M-288 Scheinwerferreinigungsanlage
M-298 Vehicle use with Lead Free Fuel (251,253,255)
M-299 Allradantrieb
M-302 Ohne VW Zeichen hinten
M-308 ï¿_ffnungswinkel der Rï¿_ckwandklappe variabel (251-256)
M-314 Sonderaktion "Typ 2 syncro Tristar" mit Stoï¿_fï¿_nger vorn wie Modell Carat, Schutzblende fï¿_r Tï¿_r vorn, Radzierblenden, Abdeckungen fï¿_r Radausschnitt, Gummileiste fï¿_r Stoï¿_fï¿_nger hinten, Halterung fï¿_r Reserverad, Kabinentï¿_ren mit Schiebefenster links und rechts, Doppelscheinwerfer, 2. Wï¿_rmetauscher, Ablagekï¿_sten an den Tï¿_ren vorn, Polsterleiste fï¿_r Schalttafel, Innenausstattung hellgrau, Basis 247 A..
M-315 Doka Zulassung als Kombi
M-318 Geï¿_nderte Schalldï¿_mmwanne TD syncro ï¿_sterreich
M-325 Tragfï¿_higkeit 1,2 / 1,3 Tonnen vorn (= verstï¿_rkte Vorderachse) abhï¿_ngig vom Modelljahr
M-327 Radio Gamma
M-333 ausschlieï¿_lich Uniroyal 16"
M-335 1,6 Liter Vergasermotor 37 kW nur fï¿_r ï¿_sterreich und Nigeria
M-336 Unterfahrschutz hinten
M-340 Fahrersitz und Lehne beheizbar
M-341 Zentralverriegelung
M-343 Reserverad unter Pedalboden (bei Syncro)
M-345 Auï¿_enspiegel mit grï¿_ï¿_erem Blickfeld (konvex) / Spiegel auf Bï¿_gelhalterung
M-346 Hydraulikpumpe ZF (Leistung 4-6 kW, Fï¿_rderdruck 180 bar, Fï¿_rdermenge 3 cm3/U, Fï¿_rderstrom 6 l/min) bei Diesel und Turbodiesel CS, KY, JX
M-347 Nebenantrieb fï¿_r Schaltgetriebe Finnland
M-348 Scheibenrad Stahl 6Jx14H2 ET 30
M-349 Vorbereitung zum Einbau einer Hydraulikpumpe ZF
M-351 Holding device for Oxygen cylinder 10,7 Liter (Krankenwagen)
M-352 Speed control governor
M-355 1,6 Liter 50kW 4 Zylinder Turbo Diesel Motor JX
M-356 Prepared for second Alternator
M-358 Transmission translation 38:7 syncro
M-364 Fenster in Schiebetï¿_r und gegenï¿_ber (251)
M-366 Partition continuous Between - and passenger compartment
M-370 Rundumkennleuchte gelb
M-375 Achsï¿_bersetzung 5,86 : 1
M-380 Trennwand im Hochdach
M-384 Zulï¿_ssige Hinterachslast 1,4 Tonnen
M-386 Teppichboden fï¿_r Fahrerraum (M939=Teppich fï¿_r komplettes Fahrzeug)
M-390 Verzurreinrichtung fï¿_r Ladegutbefestigung
M-391 Dachbox auf Fahrerhaus
M-398 Auï¿_enspiegel (plan), elektrisch verstell- und beheizbar
M-401 Alufelgen 6x14
M-402 Luxusausfï¿_hrung Multivan
M-404 Stabilisator an Vorder- und Hinterachse (2WD)
M-407 Klappsitze im Fahrgastraum
M-424 Entfall der Zwangskombination mit Innenverkleidung- M502 (nur in Kombination mit Turbodiesel).
M-425 Heckscheibenwisch- Waschanlage
M-430 Windschutzscheibe Verbundglas grï¿_n (251-256)
M-432 ABS nicht kombinierbar mit M693, 558 u. 16 Zoll Bereifung) Entfall der Drehsitze bei Joker I und III
M-433 / M-462 Radiovorbereitung mit 4 Stereolautsprechern
M-440 2 Stereolautsprecher
M-456 Tiefergelegtes Fahrwerk 30 mm
M-462 Stabantenne
M-467 Auï¿_enspiegel elektrisch verstell- und beheizbar Fahrer- und Beifahrerseite konvex
M-469 Schlechtwegeausrï¿_stung (Serie 16")
M-475 Reserveradhalterung schwenkbar an Rï¿_ckwandklappe
M-478 Reserverad unter Pedalboden (nur Bereifung 205 R 14 = Getriebeindex 5)
M-488 Drehsitz im Fahrgastraum (253)
M-496 Fï¿_r Fahrzeuge mit Krankentrage klappbar ohne Polster (Stahl)
M-498 Beleuchtetes Dachzeichen (Balkenkreuz) nur fï¿_r DRK
M-500 Trennwand unten durchgehend zwischen Fahrer- und Fahrgastraum
M-502 verbesserte Innenverkleidung des Laderaumes (Seiten- und Heckklappenverkleidung des Kofferraumes aus Hartfaserplatten, Kofferbodenbelag mit Schmelzfolie und Gummimatte ausgelegt. Holzschutzleiste an der Seitenverkleidung unten im Laderaum.) (251-254)
M-503 Dachverkleidung des Laderaumes mit Hartfaserplatte (251)
M-504 Frischluftzufï¿_hrung im Laderaum
M-505 Heizluftausstrï¿_mer im Laderaum (251,252)
M-506 Bremskraftverstï¿_rker und Zweikreiskontrollleuchte
M-508 Schiebefenster in Schiebetï¿_r und gegenï¿_ber
M-510 Trennwï¿_nde links und rechts zwischen Fahrer- und Laderaum (247-254)
M-511 Schalttafelabdeckung gepolstert mit Leseleuchte (wie Carat und Serie Caravelle GL ab Mod ï¿_90)
M-511 schmale Polsterleiste an der Schalttafel (Serie Caravelle CL und bis Mod ï¿_89 GL)
M-513 Hochraumdach Kunststoff (Dehler) (253,254) (fï¿_r KTW II)
M-514 Hochraumdach Kunststoff mit Ausschnitt fï¿_r hohe Schiebetï¿_r (Dehler) (253,254)
M-515 Hochraumdach mit Ausschnitt fï¿_r hohe Schiebetï¿_r
M-516 Hochraumdach Kunststoff fï¿_r normale Schiebetï¿_r (251-254)
M-519 Entfall der Serienverglasung im Fahrgastraum
M-520 Schiebetï¿_ren links und rechts (251-256)
M-521 Luxusausfï¿_hrung Carat
M-522 Netztrennwand zwischen Fahrer- und Laderaum (251-256)
M-526 Luxusausfï¿_hrung Caravelle
M-528 Auï¿_enspiegel konvex, Beifahrerseite rechts
M-529 Trennwand oben durchgehend mit Schiebefenster (Nur Fahrzeuge mit M500) (253-256)
M-530 Automatisches Trittbrett (Zwang mit M??? Schmutzfï¿_nger vorn)
M-534 Schiebetï¿_rschloï¿_ mit Kindersicherung
M-535 Fahrtenschreiber LLKG
M-537 Laderaumbeleuchtung
M-539 Kompaktboden im Laderaum (= Holzboden)
M-541 5-Gang Getriebe (nur Hinterradantrieb)
M-542 Spezialausstattung fï¿_r Bundeswehr (247;253)
M-544 Trennwand oben durchgehend mit feststehendem Window
M-545 Dachverkleidung mit Kunststoffhimmel
M-546 Blinkleuchten hinten auf dem Dach (251-256)
M-550 Schiebefenster mit Fliegengitter in der Schiebetï¿_r (253-256)
M-551 Scheinwerfer mit Halogenglï¿_hlampen (H4)
M-552 Warmluftausstrï¿_mer hinten im Fahrgastraum (2.Wï¿_rmetauscher) (Serie bei Turbodiesel)
M-553 SEALED BEAM-HEADLIGHTS; TURN SIGNALS AND SIDE LIGHTS; BUZZER FOR IGNITION STARTER SWITCH; SIDE MARKER LIGHTS AND REFLECTORS; DUAL CIRCUIT BRAKE WARNING LIGHT; WITHOUT HEADLAMP FLASHER AND PARKING LIGHTS; USA 255
M-556 2,1 Litre 82 kW/112 PS 4 Cylinder Digijetronic Motor DJ
M-558 Zweitbatterie mit Trennrelais kapazitï¿_tsgleich Fahrzeugbatterie
M-560 Mechanisches Stahlkurbeldach (Kombinationsverbot M573 Klimaanlage) (Zwang M-545)
M-561 Drehfenster in den Fahrerhaustï¿_ren
M-568 Wï¿_rmeschutzglas grï¿_n rundum (Windschutzscheibe in Verbundglas)
M-569 Luftfilter fï¿_r staubreiche Lï¿_nder fï¿_r Zweivergasermotor
M-571 Integrierte Nebelschluï¿_leuchte
M-572 Double Horn
M-573 Dachklimaanlage innen
M-580 Folding Seats in Cab
M-586 Sunroof
M-588 Sunroof
M-594 Faustsattelbremse (Deutschland Bundespost) fï¿_r Fahrzeuge mit 4 Zylinder Digijetronic Motor 2,1 L, 82 kW fï¿_r Fahrzeuge mit Tragfï¿_higkeit 1,2 Tonnen
M-595 Trip write
M-597 63 Ah Batterie (bei Dieselmotor Serie)
M-603 Deluxe model
M-608 Australien Ausfï¿_hrung fï¿_r Fahrzeuge mit wassergekï¿_hltem Motor RLKG
M-609 VW Campingwagen (253,254)
M-616 Backup lights in tail light
M-617 Drehstromgenerator 45 A
M-619 Drehstromgenerator 65 A
M-621 90Amp Generator
M-622 Zigarettenanzï¿_nder mit 12 V Steckdose
M-623 electrical system close-screens
M-625 16" Version Syncro
M-626 hydraulic clutch manipulation
M-628 Command car equipment, also suitably as discussion car, office for building sites and for similar cases of application consisting of: 3-plï¿_tzige middle seat bank turned inserted, photographs for lap belts, 1 folding table, 1 transistor light over the folding table and rubber mat
M-629 Mounting plate for Funksprechgerï¿_t to the left of passenger seat and loudspeaker in instrument panel
M-632 erweiterte Entstï¿_rung der elektr. Anlage
M-640 Dauerunterbodenschutz PVC
M-642 Frostschutz bis -35 Grad fï¿_r kalte Lï¿_nder
M-643 Ablagekasten an der Fahrertï¿_r
M-645 vorbereitet fï¿_r Campingwagen (Dehler Profi)
M-649 Dreipunkt Automatic Sicherheitsgurt fï¿_r Krankenwagen Klappsitz
M-651 Elektrische Fensterheber in den Fahrerhaustï¿_ren
M-652 Scheibenwischer Intervallschalter
M-657 Servolenkung
M-658 Kastenwagen ohne Schiebetï¿_r, jedoch mit Tï¿_rausschnitt
M-659 Nebelscheinwerfer
M-666 ohne Lackkonservierung (Dehler)
M-669 durchsichtiger PVC Streifenvorhang zwischen der senkrechten Fahrer-/ Beifahrertrennwand
M-673 Plombierte Tachowelle
M-674 1,9 Liter 66 kW 4-Zylinder Digijetronic Motor
M-675 Drehzahlmesser mit Digitaluhr: Z21 fï¿_r Caravelle CL Z31 fï¿_r Caravelle GL
M-682 Reifenmarke Goodyear Ganzjahresreifen auf Wunsch
M-685 Sitzbank vorn mit Klapplehne zweisitzig im Fahrgastraum
M-687 Fahrtenschreiber mit Aufzeichnung von Blaulicht und Doppelhorn
M-690 Beifahrersitz in Drehsitzausfï¿_hrung (Kombinationsverbot mit M-340 Beheizbarer Beifahrersitz)
M-691 Zusatzheizung Luft
M-692 Briefeintrag Westfalia Standheizung
M-693 Fahrersitz in Drehsitzausfï¿_hrung (Kombinationsverbot mit M-432 ABS und M-340 Beheizbarer Fahrersitz)
M-697 Reifenmarke Conti RS 771
M-700 Reifenmarke Conti RS 321 6PR
M-705 Entfall der linken Krankentrage einschl. Fï¿_hrungsschienen
M-707 / M-730 Factory-installed preparation on chassis with driving cab (basis for Karmann Gipsy)
M-709 zweite Fahrgasttï¿_r bei Doka
M-724 Vorbereitung fï¿_r Verkaufs- oder Campingwagen
M-707 / M-520 Factory-installed preparation for the installation of a complete Karmann Gipsy equipment
M-726 Seitenverkleidungen analog Caravelle C
M-731 Entfall der Zwangskombination - mit Innenverkleidung - M-502
M-732 Entfall der Zwangskombination - Entlï¿_ftungsschlitze - M-219
M-733 Automatic-Fahrtenschreiber
M-736 Fabriksschild fï¿_r Normausstattung nach DIN 14 507 "Grundmodell Kombi als Einsatzleitwagen (ELW 1) fï¿_r die Feuerwehr
M-737 Krankenwagen ohne Tragesessel, jedoch mit Fï¿_hrungsschienen im Fuï¿_boden
M-739 ohne rechte Krankentrage (nur fï¿_r KTW II)
M-740 Typenschild mit 2500 kg zul. Gesamtgewicht
M-743 werksseitige Vorbereitung und Kfz Brief Eintragung fï¿_r farbige PVC Planen (blau oder orange)
M-751 Krankenwagen: 2 Kopfkissen, Schalter fï¿_r Rundumkennleuchte wie fï¿_r Feuerwehr, Tasche mit Schmierplan, Fabrikschild nach DIN 13025
M-755 Entfall der Zwangskombination - Zusatzwï¿_rmetauscher - M-552 (nur Doka)
M-758 "Sonderausfï¿_hrung" Steuerungsnummer fï¿_r Programm Steuerungs-Zwecke von Internen Sonderfahrzeugen
M-768 Aussteuerung "Malteserkreuz" fï¿_r beleuchtetes Dachzeichen
M-795 mit Schiebetï¿_r links anstelle der serienmï¿_ï¿_igen rechts
M-855 M+S Reifen 205R16 Semperit
M-904 ohne Transistorzï¿_ndung und DLS Steuergerï¿_t, Nigeria
M-906 Halogen-Innenleuchte fï¿_r Laderaum
M-912 Steuerungscode fï¿_r den Entfall des Typenschildes (Sonderfahrzeuge wie Kommunalfahrzeuge usw.)
M-920 Trennwand ohne Fensterausschnitt
M-921 Druckender Wegstreckenzï¿_hler Schweden
M-936 Feuerrot R 300, Kfz-RAL 3000
M-939 Teppichboden fï¿_r Fahrer- und Fahrgastraum(komplettes Fahrzeug)
M-941 Werksvorbereitung fï¿_r die D`iteren-WEEKENDER Einrichtung
M-945 Polsterbezugsmaterial Stoff Feincord
M-949 Reifenmarke Goodyear G 800 + S
M-950 Radzierblende Kunststoff
M-953 Haltegriff ï¿_ber Beifahrertï¿_r
M-954 Michelin XTX 185R14C 8PR / XC / XZX
M-956 Verbreiterter Doppelbeifahrersitz Norwegen
M-958 Nottrage fï¿_r Krankenwagen
M-959 Beladeplatte fï¿_r Krankentrage BINZ
M-961 Reflexwarnstreifen fï¿_r Krankenwagen
M-962 Steckdose innen und auï¿_en mit Thermosicherung 220 Volt Krankenwagen
M-964 Motor mit Muldenkolben, Zyklonfilter und konventioneller Zï¿_ndung fï¿_r Nigeria
M-966 High roof in car colour
M-971 A praising of Syncro special vehicles
M-975 Webasto additional heating system water
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
napat
napat is offline
PostPosted: Mon Nov 09, 2009 11:49 pm    Post subject: Reply with quote
WOW Smile thank you very much !!!!!
love double cab
tencentlife
tencentlife is offline
PostPosted: Tue Nov 10, 2009 9:49 am    Post subject: Reply with quote
That is stickilicious!
I love what translators do (and no, I didn't read the whole list, this one just jumped out at me):
So what conditions would make that condition attractive?
Experience is death to doctrine.
elpedro
elpedro is offline
PostPosted: Tue Nov 10, 2009 10:09 am    Post subject: Reply with quote
Perhaps "attractive" means magnetic?
...Peter...
89 Vanagon Bluestar to-be-named
71 hardtop westfalia Brave Little Toaster *sold*
tencentlife
PostPosted: Tue Nov 10, 2009 10:21 am    Post subject: Reply with quote
Good guess, but there are no magnets in either of those circuits, so I'm thinking it's something else.
If I could read it in the original German I know enough that I might be able to tell you what it said. But why, when the computer translations are so entertaining? Funny that only a few of the entries are translated, though.
ragnarhairybreeks
PostPosted: Tue Nov 10, 2009 11:25 am    Post subject: Plate under front seat Reply with quote
the list was posted a few years ago on the vanagon mailing list by Joel W. He found it on a UK vw campers site (gone now) and it was them that attempted the translation.
I like this M-code
M-971
elpedro
elpedro is offline
PostPosted: Tue Nov 10, 2009 12:17 pm    Post subject: Reply with quote
Here's a proper translation, rescued from oblivion by The Internet WayBack Machine at http://web.archive.org/web/20021204090737/http://members.tripod.com/perlindgren/m-list.html
Code:
The M-numbers, the factory installed options
This list is compiled by [email protected],
translated by the author
What is the different model's type designations?
245 = Single cab pick up; LHD
246 = Single cab pick up; RHD
247 = Double cab pick up; LHD
248 = Double cab pickup; RHD
251 = Panel van; LHD
252 = Panel van; RHD
253 = Kombi, Ambulance, Multivan; LHD
254 = Kombi, Ambulance, Multivan; RHD
255 = Caravelle, Vanagon, Westfalia etc; LHD
256 = Caravelle, Vanagon, Westfalia etc; RHD
M 001   Manually selectable 4wd
M 003   1,9 liter carburetted engine DF, 44kw/60hp
M 012    Exhaust control system (before 1985)
M 013   Double passenger seat
M 014   Gravel guard for pulley belt
M 015   Foldable middle seat, 3-seated
M 016   Foldable rear seat, 3-seated
M 017   Middle seat, 2-seated
M 018   Padded steering wheel
M 020   Speedometer in miles per hour
M 025   Instruments with trip counter and clock
M 026   Active gas fume coal filter
M 028   Without stretcher (Ambulance)
M 032   Lockable gas cap
M 034   High beam indicator, blue - VIN 24B079862 ->   Italy
M 050   Warning light for low brake fluid and hand brake
M 051   Mounting- and connection parts for a 2nd alternator
prepared to receive an AC compressor
M 053   Seat covers, colored tweed stripes
M 053   Seat covers "Feincord" alt. from 1987
M 054   Lockable glove compartment, LHD
M 055   AC compressor, gasoline engines
M 055   Modified mounting for AC compressor for TD engines
M 058   Bumpers and spoiler as Carat
M 060   Aux. heater Eberspächer DA6 or BA6
M 061   Speedometer in miles per hour, temperature in F, city lights   Great Britain
M 062   Right hand mirror, convex and safety belts front and rear
M 064   Without bed gates   245-248
M 066   Rubber floor mats in cargo-/passenger room
M 067   54 Ah battery
M 068   2nd tow hook, rear
M 070   Tonneau cover   245-248
M 071   Second lid in side panel
M 073   Roof with cut-out for camper
M 074   rear mud flaps (standard on Syncro in Austria)
M 081   "Jail bar" wall behind drivers seat
M 089   Windshield in tempered glass
M 092   Mountain gear ratio (2wd only)
M 093   Sliding window opposite side of sliding door
M 094   Lockable rear lid   245-248
M 099   Tires M+S steelbelt 185R14C
M 099   Tires Fulda Kristall steelbelt 185R14C
M 102   Heated rear window (Can not be combined with M 127)
M 103   HD shock absorbers (2wd only)
M 106   Fabric seat covers instead of vinyl
M 113   Canada version   253, 255
M 115   1,7 liter diesel KY, 42kw/58hp
M 121   Heater and ventilation with blower   245-256
M 121   Electric roof ventilation
M 122   1,6 liter diesel ??, 37kw/50hp, VIN 24B079862 ->
M 123   2,1 liter Digijetronic MV, 70kw/95hp
M 124   Yellow head lights   France
M 127   Rear hatch without window
M 130   Ambulance
M 135   Ambulance   253,254
M 136   Ambulance with fittings
M 137   Prepared for camper
M 140    Fire fighter vehicle
M 141   Roof air filter snorkel
M 142   Roof air filter snorkel, left and right
M 143   Ambulance with fittings and extra equipment, according to DIN 75080
M 145   Safety locks for sliding door and rear hatch
M 146   Driver and passenger seats with foldable and adjustable armrests
M 149   Painted instead of chromed parts
M 150   Ambulance with extra equipment, according to DIN 75080
M 151   Compliance to exhaust emission standards   253,255 USA
M 153   Cyclone air filter and carburetor without preheater for 1,6 air-cooled
M 153   Manifold with cyclone filter for diesel
M 156   Cyclone air filter for dusty conditions, for diesel engine JX
M 157   2,0 liter Jetronic engine, from VIN A300000   Sweden
M 157   1,9 liter Digijetronic, 60kw/82hp, VIN 24D052580
M 158   Tropic radiator with more powerful fan
M 159   Padlock eye on sliding door
M 160   Blue "Police/Fire" revolving light with sirens
M 162   Rubber strips on bumpers
M 165   Lockable inspection lid
M 168   True gearing for trip counter
M 171   Tires, steelbelt 185R14C
M 173   Tires 205/70R14
M 176   Sliding tracks in cargo room   247, 253
M 177   Foldable rear seat and and additional seats in cargo room, 12-seater
M 178   Sliding tracks in cargo room   247, 253
M 179   Automatic 3-point seat belts in passenger compartment, -> VIN 24A300000
M 181   Chromed instead of painted parts (chromed hubcaps)
M 183   Hip belts in passenger compartment   247-256
M 184   Automatic 3-point seat belts, front
M 186   Automatic 3-point seat belts in all outer seats in passenger compartment
M 187   Headlights for RHD
M 188   Tropic version for warmer countries, with bigger radiator or more powerful fan for diesel
M 189   Additional 2nd alternator
M 193   Compliance to exhaust emission and electrical standards   Japan
M 194   Convex outside mirror
M 198   Red "Police/Fire" revolving light
M 201   Wider bed, made of wood   245,246
M 206   Anti glare interior rear view mirror
M 207   Final drive ratio 34:7 Syncro
M 208   Trailer hitch, ball type (removable on Syncro), and electrical parts for trailer
M 210   Front differential lock   Syncro
M 217   Tonneau cover, cabin height   245-248
M 219   Ventilation ducts for rear side windows, standard from 1988
M 220   Rear differential lock   Syncro
M 221   Ventilation windows in front doors
M 222   1,6 liter diesel CS, 37kw/50hp
M 226   Stop cable for rear pickup gate   245-248
M 227   Headrests for front seats
M 229   Headrests for rear seats
M 231   Rear seats folding into bed (not with M 685)
M 238   Daytime running lights   Sweden
M 240   1,6 liter carburetted engine, 37kw/50hp for low octane gasoline
M 249   3 speed automatic transmission
M 251   1,9 liter carburetted engine DG, 57kw/78hp
M 251   2,0 liter carburetted engine -> VIN 24D200000; 24F000001 = S 799; -> 24D 040000; 1,9 liter 57kw/78hp 24D000001->
M 254   Removable curtains in passenger compartment
M 262   Luggage compartment cover
M 263   Load capacity 1,2 tons
M 277   Modified exhaust muffler   Switzerland
M 288   Headlight washers
M 298   Vehicle use with lead free gasoline   251,253,255
M 299   Syncro 4wd
M 302   Without VW emblem, rear
M 308   Varying opening angle of rear hatch   251-256
M 314   Special version "type2 Syncro Tristar", with Carat bumper front, bumper cover plates for front doors, hubcaps, fender flares, rubber strip on rear bumper, spare wheel holder, cab doors with sliding windows left and right, dual square head lights, 2nd heater, map pockets in front doors, padding strip on dashboard, light gray interior   Basis 247 A..
M 325   Load capacity 1,2 tons front
M 335   1,6 liter carburetted engine, 37kw/50hp   Austria, Nigeria
M 336   Rear skidplate
M 340   Heated front seats
M 341   Power door locks
M 343   Spare wheel under front end   Syncro
M 345   Convex outer mirror
M 346   Hydraulic pump on diesel and turbo-diesel
M 347   Auxilliary drive shaft for additional equipment   Finland
M 348   Steel wheels 6x14 et30
M 349   Prepared for installation of hydraulic pump ZF
M 352   Cruise control
M 355   1,6 liter turbo-diesel JX, 51kw/70hp
M 358   Final drive ratio 38:7 Syncro
M 364   Window in sliding door and opposite side   251,252
M 366   Dividing wall between driver's and passenger compartment
M 370   Yellow "Police/Fire" revolving light
M 380   Dividing wall, highroof
M 384   Rear axle load capacity 1,4 tons
M 386   Carpets in drivers compartment
M 390   Tie down hooks on cargo room
M 398   Electrical mirrors
M 401   Alloy wheels 6x14 et30
M 402   Luxury edition Multivan
M 407   Jump seats in passenger compartment
M 425   Rear window wiper with washer
M 430   Windshield green, laminated
M 432   ABS brakes (not with M 558, M 693, M 625)
M 433   Prepared for radio with 4 stereo speakers, must be combined with M 462
M 440   2 stereo speakers
M 456   Lowered suspension, 30 mm
M 462   Antenna
M 467   Convex power mirrors
M 469   Equipped for bad road conditions
M 475   Spare tire carrier, swing out type
M 478   Spare wheel under front end (with 205R14C, gear ratio index 5)
M 488   Swivel seats in passenger compartment
M 496   For vehicles with stretcher, foldable stretcher without padding (steel)
M 500   Dividing wall, low between drivers and cargo room
M 502   Improved side panels in cargo room
M 502   Side panels made of hardboard, cargo floor covers made of rubber   251-254
M 504   Fresh air ducts in cargo room   251-254
M 505   Hot air ducts in cargo room   251-254
M 506   Power brakes with dual circuit control light
M 508   Sliding windows in sliding door and opposite side
M 510   Dividing wall left and right between drivers and cargo room   247-254
M 511   Padded dashboard with map light (as Carat)
M 511   Padding strip on dashboard
M 513   Fiberglass highroof (Dehler)   253-254
M 514   Fiberglass highroof (Dehler) with cut-out for tall sliding door   253-254
M 515   Highroof with cut-out for tall sliding door
M 516   Highroof for normal sliding door
M 519   Without windows in passenger compartment
M 520   Sliding doors left and right
M 521   Luxury edition Carat
M 522   Mesh dividing wall between drivers and cargo room   251-256
M 526   Luxury edition Caravelle
M 528   Passenger side mirror convex
M 529   Dividing wall, full height with sliding window (must be combined with M500)   253-256
M 530   Automatic sidestep
M 534   Sliding door lock with child safety
M 535   Printing trip recorder
M 537   Cargo room light
M 539   Compact floor in cargo room
M 541   5-speed transmission (2wd only)
M 542   Specially equipped for German Army   247,253
M 544   Dividing wall, full height with fixed window
M 545   Vinyl headliner
M 546   Roof mounted rear turn signals   251-256
M 550   Sliding window with mosquito net in sliding door   251-256
M 551   H4 headlights
M 552   2nd heat exchanger, rear. Standard on turbo-diesel
M 553   Sealed beam headlights; turn signals with side lights; buzzer for ignition starter switch; side marker lights and reflectors; dual circuit brake warning light; without headlight flasher and parking lights ("city lights")   USA
255
M 556   2,1 liter Digijetronic engine DJ, 82kw/112hp
M 558   Prepared for 2nd 63 (64) Ah battery, with relay
M 560   Mechanical sunroof (can not be combined with M 573, must be combined with M 545)
M 561   Ventilation windows in front doors
M 568   Green tinted windows
M 569   Air filter for dusty  condition, for dual carburetted engines
M 571   2 integrated rear fog lights
M 572   2 tone horn
M 573   Roof mounted air-conditioning system
M 580    Jump seats in passenger compartment
M 586   Glass sunroof in passenger compartment
M588   Glass sunroof in drivers cabin
M 594   Larger front brake caliper
M 595   Printing trip recorder
M 603   63 (64) Ah battery
M 608   Australian equipment for cars with watercooled engine, RHD   Australia
M 609   VW Camper
M 616   Integrated backup lights
M 617   Alternator, 45 A
M 619   Alternator, 65 A
M 621   Alternator, 90 A
M 622   Cigar lighter with socket, 12v
M 623   Shielded electrical system
M 625   16" version Syncro
M 626   Hydraulic clutch
M 628   Folding table in passenger compartment, for Police and Fire dept.
M 632   Extended shielding of the electrical system
M 640   PVC coated undercarriage
M 642   Antifreeze -35C for cold countries
M 643   Map pocket in drivers door
M 645   Prepared for camper (Dehler Profi)
M 649   3-point safetybelt for jumpseat in ambulance
M 651   Power windows in drivers doors
M 652   Intermittent windshield wipers
M 657   Power steering
M 659   Fog lights
M 674   1,9 liter Digijetronic engine GW, 66kw/90hp
M 675   Rpm-counter with digital clock
M 682   Tires ...
M 685   Foldable middle seat, in passenger compartment
M 690   Swivel passenger seat (front) (can not be combined with M 340)
M 691   Aux. heater air-cooled
M 693   Swivable drivers seat (can not be combined with M 340 or M 432)
M 697   Tires Continental RS 771
M 726   Interior side panels, plain for Caravelle C
M 739   Without right-hand stretcher (ambulance)
M 904   Without transistorized ignition and digital idle stabilizer   Nigeria
M 920   Dividing wall without window opening
M 921   Press-type km counter   Sweden
M 939   Carpets for the complete vehicle
M 945   Seat covers, Cord
M 949   Tires Goodyear G800 +s
M 950   Plastic hub caps
M 954   Tires Michelin XTX 185R14C 8pr
M 956   Widened double passenger seat    Norway
M 958   Emergency stretcher for ambulance
M 959   Load plate for ambulance BINZ
M 961   Reflex stripes for ambulance
M 962   Electrical sockets in- and outside with thermofuse for 220v, ambulance
M 964   Engine with deep dish pistons, cyclone air filter and regular ignition   Nigeria
M 966   High roof in body color
M 975   Aux. heater water-cooled, type Webasto
M 976   Printing trip recorder
M 982   1,9 liter carburetted engine, 54kw/73hp   245-256
M 984   Square headlights H4/H3
M 987   Sliding window with mosquito net, opposite of sliding door or in sliding door
M 990   Velour seat covers
M 991   Tires 205R14C M+S (only with gear ratio index 5)
M 998   Power mirrors, drivers side plane, passengers side convex
M 999   Passenger side makeup mirror, with light
R 01   Radio Alpha mono
R 11   Radio Beta mono
R 22   Radio Gamma stereo, with cassette player
S 700   Tires ...
S 701   Australian equipment for cars with watercooled engine, RHD   Australia
S 704   Type 2 Great Britain
S 725   800 kg instead of 725 kg
S 735   Special version "Bluestar" with color coded mirrors, black sliding window frames, cup holders, rear seat converts into bed, foldable table, interior color 39 platinum, base model Caravelle GL, VIN 24K090001 ->K095469
S 741   Special version "Multivan Magnum" with Carat bumpers, front spoiler, hubcaps, interior color light gray, rear seat converts into bed, base model Multivan 253 S..
S 746   Caravelle C Coach
S 764   Rebuild kit for California equipment for European use
S 768   Ambulance light, front, with Maltese cross
S 773   Special version Caravelle (up to 1983)
S 775   Bumpers and side panels cloud gray, as Carat
S 779   Vanagon GL Promo
S 789   Shift point light for diesel versions
S 790   Catalytic converter with O2 sensor as enclosement
S 799   1,6 instead of 2,,0 engine, VIN 24D000001 -> D051580
W 75   Bumpers and side panels cloud gray as Carat; square headlights
Z 01   Bad weather package: Front and rear fog lights, intermittent windshield wipers
Z 02   Equipment package: rpm-counter, digital clock, trip counter, rubber strips on bumpers, ventilation windows in front doors
Z 04   GL package
...Peter...
napat
napat is offline
PostPosted: Tue Nov 10, 2009 12:33 pm    Post subject: Reply with quote
Thanks elpedro Smile
I have M210 and M220 on my Syncro !!!
Actually, just brought German dictionary Very Happy
English is a bit easier!
love double cab
keithwwalker
keithwwalker is offline
PostPosted: Wed Nov 11, 2009 12:53 am    Post subject: Reply with quote
How did you manage to steal my doka, and then clone it?
lol
Shocked
