Can you help me identify this turbo?
dylan.r.1080
dylan.r.1080 is offline
PostPosted: Tue Dec 01, 2009 6:13 pm    Post subject: Can you help me identify this turbo? Reply with quote
I haven't been able to find it through garrett or anywhere else.
its out of a saab 2.3t
marks on compressor housing read:
B.C.1 M27 A/R.48
there is also the number 92 stamped and circled
on the compressor discharge pipe 48 is stamped (i think this is referring to the A/R again?)
waste gate bracket marks: 434 034-1
the compressor wheel measures: 54mm (exducer) about 41mm (inducer, its hard to measure properly with a caliper)
turbine housing marks:27F92
DH2-2 M4 A/R 0.48
S/N: V10935A
P/N: 465 183-5
C/N: 912834
center housing clamp marks: 413977-1
49 is stamped into the inside of the turbine inlet
the exhaust manifold flange is aprox. 3.5"x2.5"
thanks for the help, dylan
Mr. Unpopular
Mr. Unpopular is offline
PostPosted: Tue Dec 01, 2009 6:35 pm    Post subject: Reply with quote
Looks like a Garrett T3 based on the pics and numbers.
"In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV
dylan.r.1080
PostPosted: Wed Dec 02, 2009 2:59 pm    Post subject: Reply with quote
do you think it could be a T03? i have been reading that they are common on saabs.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Wed Dec 02, 2009 9:25 pm    Post subject: Reply with quote
No...
T25 probably, but I need to know the year of the car. Some Saabs had GT series turbos, but I don't think that's a GT.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
dylan.r.1080
PostPosted: Wed Dec 02, 2009 10:29 pm    Post subject: Reply with quote
For some reason i didn't look at the year when i pulled it, im now kicking myself for that Confused if i had to guess it looked like a late 90's to early 00's.
I'm going to try to go back to the yard and see if the donor is still there but i doubt it will be. I don't think its a GT either, the compressor wheel doesn't match up with any of this years GT's on the Garrett site. I'm going to try calling a Saab dealer tmrw but i doubt I'll have much luck with that.
thanks for the help
miniman82
Samba Swamp Donkey
PostPosted: Wed Dec 02, 2009 11:43 pm    Post subject: Reply with quote
Do some web searching with the part #, some are saying it could be a T28, which is the same family as T25/T2 anyway. It would be the same flange dimensions, so what does your exhaust mounting pad measure? (the last pic you posted)
This is T2/25/28:
dylan.r.1080
PostPosted: Thu Dec 03, 2009 4:18 pm    Post subject: Reply with quote
Sorry for the sloppy drawing, i don't have access to auto cad until tmrw morning. Here's what im getting,
The T2/25/28 pretty much matches mine, everything is within 2mm which im sure my measuring errors and just the castings. thanks for finding that image for me.
didget69
didget69 is offline
PostPosted: Thu Dec 03, 2009 10:30 pm    Post subject: Reply with quote
It's a Garrett T25...
Saab 9000
Year: -93
Engine: 2.3
Turbo Part #465183-5
Model: TB2531
Ran across some other info:
Turbo SAAB
Product Description:
Garret Model TB2531; and GT2531; OEM number is: 465183-1;465183-3;465183-4; and 465183-5.
Applications:
1990-1993 SAAB 9000 2.3L
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
dylan.r.1080
PostPosted: Fri Dec 04, 2009 12:44 pm    Post subject: Reply with quote
Thanks so much, where did you find all of that?
Just another freak, in the freak kingdom.
didget69
didget69 is offline
PostPosted: Fri Dec 04, 2009 5:17 pm    Post subject: Reply with quote
Internet search on Garrett p/n 465183-5...
Or try looking at Garrett website -
bnc
dylan.r.1080
PostPosted: Fri Dec 04, 2009 9:43 pm    Post subject: Reply with quote
Embarassed
shit dude, i guess i didn't look hard enough, all i saw on the garrett site was on the gt series and the old catalogs wouldn't download for me, i wasn't finding anything conclusive on the numbers either, i guess I'll look a little longer next time, thanks again.
