Engine lifters
hushcar
hushcar is offline
PostPosted: Sun Dec 20, 2009 8:10 pm    Post subject: Engine lifters Reply with quote
I'm rebuilding a case and while putting in the lifters, I noticed they are pretty tight and it takes a good amount of effort to slide them in and out. Is there anyway to judge how much they should move? Most cases I opened have the lifters falling out when you tilt the case, not these for sure!!
perrib
perrib is offline
PostPosted: Sun Dec 20, 2009 8:13 pm    Post subject: Reply with quote
As I recall .0009" to .0018" is the spec. If the case has been sitting a thin layer of corrsion builds up on the mag.
Unkl Ian
Unkl Ian is offline
PostPosted: Sun Dec 20, 2009 8:14 pm    Post subject: Reply with quote
New lifters ?
hushcar
hushcar is offline
PostPosted: Sun Dec 20, 2009 8:19 pm    Post subject: engine lifters Reply with quote
These are reground lifters
perrib
perrib is offline
PostPosted: Sun Dec 20, 2009 8:36 pm    Post subject: Reply with quote
I have noticed many reground lifters appear well abused and need some attention.
modok
modok is offline
PostPosted: Sun Dec 20, 2009 10:20 pm    Post subject: Reply with quote
The lifters should be .746"-.747"
The bores should be .748"-.750"
Often in old cases that have sat around for awhile, the bores get all oxidized. You may need to hone them a little with a brake cyl. hone to clean them up.
Bruce
Bruce is offline
PostPosted: Sun Dec 20, 2009 10:26 pm    Post subject: Reply with quote
Inspect the lifters very carefully for small burrs. Those will make the lifters hang up in the bores. If you find some sand them with 400 grit.
