Tghusker Samba Member
Joined: December 15, 2009 Posts: 5 Location: Omaha, NE
Posted: Wed Dec 23, 2009 11:17 am Post subject: How to test a turn signal switch on a 71 super????? |
I am having some troubles with mw blinkers not working. The flashers and all the other lights work fine. I replaced the turn signal switch and the blinkers worked fine for a day. Then it was back to nothing. All fuses and relays and bulbs have been replaced. And all the grounds have been cleaned. Is their a way to test the switch to see if it is good?
Thanks for all of your help. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33153 Location: Hot Arizona
Posted: Wed Dec 23, 2009 12:15 pm Post subject: |
Sure the switch can be checked. Positive voltage goes to the flasher relay, then into the turn signal switch, which just directs that voltage to either left or right.
Get a 12 volt test light, better for this than a voltmeter. Turn the ignition on, check terminal 31 (brown wire) at the flasher relay, and test light should flash. If it does, then the turn signal wires are next to be tested. The brown going in is that 31 wire, that should deliver to the TS switch. Select left turn, check for voltage in the black wire with white stripe, test light should flash; if so, left position is OK. Select right turn, check for voltage in the black wire with green stripe, test light should flash; if so, right position is OK. If those are both OK, then you need to check your turn signal light sockets with the test light in a similar way. If they flash there, problem is the housing, housing grounding, or bulb. Remember, these turn signal bulbs have two filaments, bulbs must be inserted correctly. And one filament can burn out and the other be OK.
If you don't get flashing at that #31 terminal on flasher, make sure terminal #49a there is getting its power (from the light switch). And your 71 SB has metal fenders correct, not plastic/fiberglass and the housings are making good ground (you didn't just have it painted, did you?).
See http://www.thesamba.com/vw/archives/info/wiring/bug_super_71.jpg for wiring diagram and http://www.thesamba.com/vw/archives/info/wiring/bug_super_71_key.jpg for the key. Both can be clicked to enlarge. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
