Baxta Samba Member
Joined: November 09, 2008 Posts: 356 Location: Abbotsford, BC
Posted: Thu Feb 18, 2010 4:41 pm Post subject: Wiring trickle charger direct to house battery? |
So our house battery is hooked up to various things inside the van, and the memory on the radio causes the charge to dip into the yellow if the van sits for a few weeks in the winter. I bought myself a Canadian Tire $20 1 Amp trickle charger that's on a 'float' so it won't overcharge. I use this to keep the house battery topped up over the winter months, but I got to thinking.
Can I wire this up to the battery on a permanent basis, so that when we're at a wired campsite I can use the interior accessories without having to worry about the battery?
I had to pick up a new battery for the Corrado today and asked the question to the guy at the battery shop and he thought it was a great idea. I'm just worried because I haven't heard of people doing this on here, and I don't think I'm all that smart.
What say you?
Thanks! _________________ Greg
'87 Syncro Westy 'Bastian'
2.2l |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Thu Feb 18, 2010 4:45 pm Post subject: |
I did that with my last sailboat. When I had shorepower I'd just plug it in, flip a switch (put a switch for safety) I then just used my 'house' lites etc... In this way I used my battery charger as a converter. I would like to do that with my van plus and/or a solar house battery charger. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Thu Feb 18, 2010 4:54 pm Post subject: |
You can do that. Wire it into the outlet under the sink, then just plug an extension cord into the power outlet on the side of the van to connect to shore power. Either at home or camping, when the shore power is connected you'll be charging. _________________ 89 Westy 2.1 Auto |
deprivation Samba Member
Joined: September 14, 2006 Posts: 1220 Location: Austin, Texas
Posted: Thu Feb 18, 2010 4:59 pm Post subject: |
| PDXWesty wrote: |
| You can do that. Wire it into the outlet under the sink, then just plug an extension cord into the power outlet on the side of the van to connect to shore power. |
That's exactly what I did and it's great. _________________ 1986 Westy 2WD auto a.k.a. "The Old Girl"
www.kittenfart.com |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
| PDXWesty wrote: |
| You can do that. Wire it into the outlet under the sink, then just plug an extension cord into the power outlet on the side of the van to connect to shore power. Either at home or camping, when the shore power is connected you'll be charging. |
x 2 on that. If you have a Yandina, it will also charge your starting battery as well. I left my lights on last week and just plugged it in when I got home and let it charge overnight. Both batteries were fully charged in the morning. _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Thu Feb 18, 2010 6:19 pm Post subject: |
| GWTWTLW wrote: |
| PDXWesty wrote: |
x 2 on that. If you have a Yandina, it will also charge your starting battery as well. I left my lights on last week and just plugged it in when I got home and let it charge overnight. Both batteries were fully charged in the morning. |
Winner, winner, chicken dinner. This is a great combination. I have a "smart" charger permanently mounted under the driver's seat, plugged into the undersink outlet, and direct wired to the house battery. It charges the house battery until the Yandina goes into "connect both batteries" mode at the appropriate level of charge, and then it starts charging the starting battery. Works perfectly. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
Timwhy Samba Member
Posted: Thu Feb 18, 2010 6:21 pm Post subject: |
I have a 2amp battery maintainer wired to my aux fuse panel at the terminal posts, in addition to a 5watt solar panel for the house battery.
Problem is that these do not keep my house battery fully charged during the winter months. I don't drive my Westy regularly during the winter and only start it up so often, so the house battery doesn't get a good charge off the alternator.
So how long would it take a 2amp trickle charger to full charge a 44amp house battery in less than warm (more like frigid conditions)? I don't think that it can, in these conditions.
During the summer months while my Westy was hooked up to the house, the charger worked as planed. _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Thu Feb 18, 2010 6:57 pm Post subject: |
Volks,
Any specific makes or models of trickle chargers you like for this application?
Any that fit well in small spaces? Links and pics are great, as usual.
-CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Thu Feb 18, 2010 7:19 pm Post subject: |
I have done this but hooked up to my main battery. (don't have a second battery) . It is wired to the alternator and lives in the engine compartment. The cord comes out of the license plate when I need it (along with the plug for the block heater. I use it as well in campgrounds to keep topped up when I have shore power. No pics possible for a while, until the snow melts. _________________ -- 1987 Westfalia automatic (Captain Vino) |
scobax Samba Member
Joined: July 27, 2007 Posts: 236 Location: Bend, Oregon
Posted: Thu Feb 18, 2010 7:37 pm Post subject: |
I just picked up one of these Schumacher units off of Amazon two months ago. It lives inside the galley cabinet under the sink. Works quite well.
http://www.amazon.com/Schumacher-SE-1-12S-Automati...amp;sr=8-1
Schumacher is a time tested name in the charger biz, they make good stuff. You can find these at your local FLAPS, but the Amazon price is about ten bucks better, at least around here. that is if you can wait for it.
Scott _________________ 87 Syncro Westy w/ Suby 2.5
RIP: 2.1 WBX. You were a good dog 'ol feller
“The word adventure has gotten overused. For me, when everything goes wrong, that's when adventure starts” -Yvon Chouinard
"It's not expensive, its priceless" -Unknown |
Bruce Wayne Samba Member
Posted: Thu Feb 18, 2010 8:33 pm Post subject: |
| I think my trickle charger is 1.5 amps,picked it up at HF for $9.99. works great. just plug in the extension cord every now and then to help the solar panel top off the battery. |
Terry Kay Banned
Posted: Fri Feb 19, 2010 12:45 am Post subject: |
<<I just picked up one of these Schumacher units off of Amazon two months ago. It lives inside the galley cabinet under the sink. Works quite well.
Ditto on the Schumacher.
Bolted it to the inner wall under the sink--ran the wires to the auxillary battery.
It's keeps the house battery topped off just ducky when your plugged in when camping.
Best bang for the bucks--- _________________ T.K. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19061 Location: Retired South Florida
Posted: Fri Feb 19, 2010 8:49 am Post subject: |
| I am using one of these http://batterytender.com/rv.html It has a molded plug that is hard wired to my auxilary fuse panel. That way I can use it for maintaining my generator and other things that sit. Combined with the Yandina, both batteries are always fully charged when the van is sitting for some time. In use, I found the 1.2 amps a little slow to keep up batteries that had been run down low. I have since ordered the Xantrex inverter/charger to supplement my setup when camped. This can charge at 20 amps when on shore power, which should bring the batteries up much quicker than the trickle charge of 1.2 amps. |
singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Fri Feb 19, 2010 9:53 am Post subject: |
| I found my old Battery Tender 750mA trickle charger on the self I used to use with the motorcycle. It's plugged into the 110v socket under the sink and bolted to the aux. battery. If the Werker 44Ah battery was run down half way this charger would take ~30 hours to recharge it. But from the other posts here, can this even keep up? |
DAIZEE Samba Member
Posted: Fri Feb 19, 2010 10:01 am Post subject: |
I think one has to take a look at how much draw lights/appliances draw when deciding what size to get. an example would be playing a radio burns up a lot less power than running cassettes. Sorry don't know how much CD's draw. House lights are probably the least depending on their type. A toaster draws more than say an electric plate (I think).
When I have shore power I don't worry about anything but when I'm just using house power then I have to make decisions on what I use. I know this sounds simple. You need to know what an object draws. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
Posted: Fri Feb 19, 2010 10:14 am Post subject: |
| Realistically all I think I need is a trickle charger large enough to top off the aux. battery while we're sleeping at that odd campsite with shorepower. I now realize from Simba's post that my wimpy 750mA unit isn't going to cut the mustard, but works ok in my driveway since our van isn't a DD and can sit there for days without use. I should get a larger one though. |
