Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Sat Feb 27, 2010 11:59 am Post subject: Early door hinge |
OK, I have a donor door for my '63 Notch. Do the hinges unbolt from the door? Or, do you have to push the pin out to get the half of the hinge that bolts to the door jam on the body?
I'm trying to remove the lower hinge from the door. _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Brentadour Samba Member
Joined: June 08, 2005 Posts: 66 Location: West Chester PA
Posted: Sat Feb 27, 2010 3:27 pm Post subject: |
The hinges are welded to the door. The pins are pretty hard to get out, if they come out. I destroyed a door once trying to do the same thing. Be careful! |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Feb 27, 2010 5:02 pm Post subject: |
_________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22659 Location: Escondido CA
Posted: Sat Feb 27, 2010 6:43 pm Post subject: |
notchboy wrote: |
Cool. A cat eye mirror door  |
Note the date on that bulletin. 3/63 _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sat Feb 27, 2010 6:58 pm Post subject: |
Russ Wolfe wrote: |
notchboy wrote: |
Note the date on that bulletin. 3/63 |
Yeah I saw that. Has to be an early pic printed later. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Thu Mar 04, 2010 9:26 am Post subject: |
Finally had a chance to look at the pages you posted Russ. (Can't view big images on my phone) Thanks for posting!!
This tool seems fairly simple. As I understand it, you drive the pins out from the top. Then reinstall them from the bottom.
Some questions:
The only mention the top hinge, I assume that the proceedure is the same for the bottom hinge?
Are the pins tapered at all?
And, could the pins be driven in from the top to install them? _________________ Phillip Bradfield
Posted: Thu Mar 04, 2010 10:55 am Post subject: |
If you read it, the top hinge comes out downward, and the bottom hinge comes out upward.
If you can see in the one picture, the bottom hinge is in the vise with the door upside down. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Thu Mar 04, 2010 12:16 pm Post subject: |
That's funny. I didn't even notice the door was upside down!!
I need to pay better attention in class, Prof. Russ!  _________________ Phillip Bradfield
Posted: Tue May 18, 2010 9:07 am Post subject: |
I'm still working on my passenger door hinge. I've attempted to push the hinge pin out, just like the bulletin directs above, with the door upside down and pushing the pin into the center of the door. I'm actually using a pin punch that I bought and a good size hammer.
I had no luck what so ever. The pin will not move. So, I had an extra early door that I picked up from a guy fairly local to me. Temporarily, I'm going to use this door. The hinges on this door were really rusted tight. I've sprayed tons of PB Blaster on the hinges, and my friend David from Bug Boys ([plug] http://www.bugboys.net [/plug]) helped me get the hinges freed up by using a pair of vice grips and clamping a rather large pry bar to each of the hinges and working them back and forth little by little. They're both pretty decent now.
Next we had to fix two of the holes that were obviously drilled out in the temporary door. (I'm doing the same thing to get my old broken hinge part off the body) I cleaned out the two holes really well with a carbide bit, and then we sanded the flat surface with an angle grinder and a twist loc pad. My son Harrisen then MIG welded up the two holes. Then, I used a tap and cleaned out all the threads in the other holes. Now, I can get a bolt into all the threaded holes with my fingers.
So, that's where I'm at. One partial hinge still attached to the body. And a temp door prepped. Just need to get better after having surgery a week ago, and I can get back to it.
I hope to post some pics. This has been an adventure that I've never experienced before on a Type 3! _________________ Phillip Bradfield
Posted: Tue May 18, 2010 9:12 am Post subject: |
Read the first page. It tells which way to drive them. And do it off the car, with the loose end of the hinge in a vise.
Posted: Tue May 18, 2010 9:28 am Post subject: |
Yep. I was working on the lower hinge, and had the door upside down driving the pin to the center of the door, just like the pic. Wouldn't move at all... _________________ Phillip Bradfield
Posted: Tue May 18, 2010 9:30 am Post subject: |
Do you have the hinge in a vise, like in the picture?
The sheet metal of the door is not solid enough. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Tue May 18, 2010 9:33 am Post subject: |
Yup. Forgot to post that part. I have a floor vice that is huge. Was using that.
My only thought was that I wasn't hitting it hard enough. I may have been holding back too much, worried that I would break the welded part of the hinge off the door. (I know that the vice is key, and is holding it) _________________ Phillip Bradfield
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18042 Location: Eugene, OR
Posted: Tue May 18, 2010 9:54 am Post subject: |
Better try some heat/dry ice rather than break something?  _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue May 18, 2010 10:12 am Post subject: |
Heat the hinge. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Tue May 18, 2010 10:32 am Post subject: |
Great advice. I thought about that. But my torch isn't set up yet. I do have a small map gas torch. Not sure if that's enough heat... Will try it next time. _________________ Phillip Bradfield
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Tue May 18, 2010 12:23 pm Post subject: |
Notched wrote: |
Great advice. I thought about that. But my torch isn't set up yet. I do have a small map gas torch. Not sure if that's enough heat... Will try it next time. |
Alternate with heat and lubricant, such as Kroil or PBlaster.
Apply heat, wait; then apply penetrant, then heat, wait; then penetrant. After that, use the hammer and punch tool. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Sun May 23, 2010 5:05 pm Post subject: |
This is where I'm at. Still drilling out the lower hinge bolts.
Original door.
Broken bottom hinge on original door.
Hinge in donor door retapped.
Wobbled out holes welded up ready to get tapped.
Top hinge holes on door frame.
rustyfastback Samba Member
Posted: Sun May 23, 2010 8:16 pm Post subject: |
I had the same problem with a broken lower hinge on my '65 squareback. I heated, hammered, sprayed pb blaster on that pin for days would not budge. I actually thought the pin was moving but the hinge broke loose from the door, what a mess. I ended up taking a cut off tool & making a slit in the hinge to finally remove the pin. I took the hinge to the welding shop to have the cut welded. I used an 8mm bolt instead of the hinge pin, works fine. Here are some pics
