lifter's effect on cylinder compression?
vwvwvwvwv
vwvwvwvwv is offline
PostPosted: Fri Mar 12, 2010 4:59 pm    Post subject: lifter's effect on cylinder compression? Reply with quote
Can a bad lifter/lifters on a 1.9 waterboxer cause almost 0 compression in one cylinder?
Wildthings
Wildthings is offline
PostPosted: Fri Mar 12, 2010 6:05 pm    Post subject: Reply with quote
It could but probably not. If a lifter doesn't pump up at all the compression will most likely read about 20psi. If you have the lifter adjusted way too tight or for some reason the lifter doesn't purge normally it could hold the valve open, but shouldn't cause zero compression.
vwvwvwvwv
PostPosted: Fri Mar 12, 2010 6:14 pm    Post subject: thanks Reply with quote
thanks
?Waldo?
?Waldo? is offline
PostPosted: Fri Mar 12, 2010 6:25 pm    Post subject: Reply with quote
I agree with both parts of that. It depends on several factors. One factor would be the amount of valve overlap in the cam. Another factor is where the piston in that cylinder last was when the engine sat long enough for the pressure to normalize. For instance, if neither valve opened at all and sealed well and the piston was last stopped at TDC for that cylinder, then when checking compression, the piston would register zero. If there is no valve overlap (diesel engines) then if the intake valve is not opening at all then zero compression would result regardless of piston position. In most cases, tho, it will show some compression. A leakdown test is more conclusive.
vwvwvwvwv
PostPosted: Fri Mar 12, 2010 6:35 pm    Post subject: it's not diesel Reply with quote
it's not diesel.
thanks very much!
