intermittent wiper relay
timo78
timo78 is offline
PostPosted: Thu Apr 01, 2010 11:19 pm    Post subject: intermittent wiper relay Reply with quote
Recently ordered an intermittent wiper relay from Busdepot[111955531]. Looks like a flasher relay, but I,m not sure where to install it. Are these adaptable to the electrical system of a bay window?
EDIT: some pix of the relay.
Green Bay Bus > 78Grµn Westfalia `Donkey`
It may be bigger than you and it may be bigger than me, but it’s not bigger than you AND me; can you dig it?
JeffnDes1977
JeffnDes1977 is offline
PostPosted: Fri Apr 02, 2010 6:23 am    Post subject: Reply with quote
Do you have a pic? I could not find one.
1977 Bay 2.0 FI
1968 Sandrail/ woods buggy project
1970 Sandrail
19?? Sandrail project - soon to be for sale!
1960 Beetle - My first car!
busdaddy
busdaddy is offline
PostPosted: Fri Apr 02, 2010 8:53 am    Post subject: Reply with quote
Search intermittant or interval with Naskeet as the submitter............if you dare Razz
Слава Україні!
buggin74vw
buggin74vw is offline
PostPosted: Fri Apr 02, 2010 9:24 am    Post subject: some advice Reply with quote
ok u have the right relay. but it didn't come in many busses at all. i have a 78 champagne edition with intermittent wipers that i was trying to adapt to my 79 westy. it has that relay on the bottom of the fuse box where the other relays are. should be a blank spot or 2 there for yours to pop right in. the top pic is the wiring harness that goes from the bottom of the wiper switch(steerin column) to the wiper motor(white plug) the other wires which are not on a stock bus (5 of them?) go to this relay in the fuse box. Only problem is you will need the wiper switch from a bus that had intermitent cause the internal contacts are different and to activate the intermittent part u pull the switch towards yourself one click.
i probably confused you more than u were before. just wanted to show you how the factory did it in the late 70s. im sure there are many other ways and options to do this.
jmstu76
jmstu76 is offline
PostPosted: Fri Apr 02, 2010 2:49 pm    Post subject: Reply with quote
Don't you need a 4 position switch as found in the champagne buses, not just the off, low, high switch everyone else has?
James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger Instagram Gallery Classifieds Feedback
VDubTech
VDubTech is offline
PostPosted: Fri Apr 02, 2010 2:58 pm    Post subject: Reply with quote
Yes.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
busdaddy
busdaddy is offline
PostPosted: Fri Apr 02, 2010 3:32 pm    Post subject: Reply with quote
Most 75+ switches are already 4 position, there's a small tab of plastic on the outer column housing that stops it from going past off to the delay position. You still have to add a wire to the harness that plugs into it though.
Слава Україні!
timo78
timo78 is offline
PostPosted: Fri Apr 02, 2010 5:52 pm    Post subject: Reply with quote
Is the wiring proper on a 78 to use the relay or does it require additional wiring? I'll take a peek in the morning, but any advice is appreciated.
dwill49965
dwill49965 is offline
PostPosted: Fri Apr 02, 2010 6:54 pm    Post subject: Reply with quote
I don't know how this particular intermittent relay hooks up, but last year I installed an older style after market intermittent relay switch on my '78 - and it was dead simple. 4 wires to hook up, only two into the stock harness, right under the steering column - no need to mess with the connector at the wiper motor. I'll post pics later - including the early '80's style Canadian Tire packaging.
Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
timo78
timo78 is offline
PostPosted: Fri Apr 02, 2010 7:38 pm    Post subject: Reply with quote
..bump > now w/ pics
busdaddy
busdaddy is offline
PostPosted: Fri Apr 02, 2010 8:41 pm    Post subject: Reply with quote
The wiring for it won't be there unless your bus is a champagne or some Euro delivered special model.
Слава Україні!
calebmelvin
calebmelvin is offline
PostPosted: Fri Apr 02, 2010 8:44 pm    Post subject: Reply with quote
LOL
Caleb
'68 Tagged Manx | My Wanted Ads
timo78
timo78 is offline
PostPosted: Sat Apr 03, 2010 10:38 pm    Post subject: Reply with quote
After a daring slog through several documents. Faced with a daunting task of digesting: dialogue, discussion, and diatribe. I finally struck some samba gold ...... the solution Dancing
Arrow FTW> Fellow sambanista Dodgy's outstanding intermittent wiper wiring diagram
supplied here
http://www.thesamba.com/vw/forum/viewtopic.php?p=3165217#3165217
busdaddy
busdaddy is offline
PostPosted: Sun Apr 04, 2010 6:57 am    Post subject: Reply with quote
Nice work Timo, you're a brave man!
Слава Україні!
Bleyseng
Bleyseng is offline
PostPosted: Sun Sep 04, 2011 1:52 pm    Post subject: Reply with quote
So this intermittent setup works ONLY if you have a wiper switch with the two rows of contacts? (CE?) I just wondered if there was a way to do this with a stock bus switch.
If it can't work then I will look into switching around the switch parts with some 914 stuff as they look the same except for the stalk that is longer. Swapping the stalk looks possible and then I could have a switch that has the intermittent wiring and contacts.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
busdaddy
busdaddy is offline
PostPosted: Sun Sep 04, 2011 2:19 pm    Post subject: Reply with quote
Wink
Слава Україні!
bigbore
bigbore is offline
PostPosted: Sun Sep 04, 2011 2:31 pm    Post subject: Reply with quote
I remember back in the 70's when I found out about that in the rabbits I did the delay mod in alot of those back then.
where its cold and snowy
Bleyseng
Bleyseng is offline
PostPosted: Sun Sep 04, 2011 3:22 pm    Post subject: Reply with quote
busdaddy wrote:
Wink
Got that and since there isn't an extra contact inside that is why I was looking at my stash of 914 wiper switches. Some have the extra contact as 914's did have a "Flick wipe" or "intermittent" wiper setup. The switch body is the same just a different stalk. Guess I'll pull out the switches to see how easy it is to swap in.
Bleyseng
Bleyseng is offline
PostPosted: Sun Sep 04, 2011 4:38 pm    Post subject: Reply with quote
Ok, here is a pic of a late bay wiper switch and a late 914 switch. The bodies are the same, everything is the same except for the stalk which can be swapped in. The 914 one is on the right.
I'll give it a try..
Bleyseng
Bleyseng is offline
PostPosted: Mon Sep 05, 2011 9:20 pm    Post subject: Reply with quote
dug out a 914 74 switch and a 75 wiper switch with the extra contacts for electric washer pump. Note both have the extra position contact for a intermittent relay. I'll swap over the stalk from a bus switch and see how it works. Dunno if I have two 75 switches so I can use that one and also have electric washer too.
Page 1 of 8
