getting a transmission to hold more HP/Torque
Page: 1, 2, 3, 4  Next
( o\_/o )
( o\_/o ) is offline
PostPosted: Fri Apr 30, 2010 11:09 am    Post subject: getting a transmission to hold more HP/Torque Reply with quote
i have used the search for several days but i can't find any info one how to get the stock bug, bus or a 914 transaxle to handle more then 250hp
i know the stock transaxles are almost bullet proof to 250hp, but how do i get it to hold more HP/Torque/Newton meters
i want to run a high horsepower type 4 engine with a massive turbo for racing offroad, or on the drag strip
now i don't want to use a special transaxle or anything. im curious to what do i have to do to a stock transaxle to get it to hold the power. i know the bus transaxle is stronger then the bug so im more inclined to using the bus, but i want the 5th gear option outta the 914.
i know im gonna need a new ring set, larger/stronger gears, and better cv's.
any more info would be of massive help thanks guys
Dale M.
Dale M. is offline
PostPosted: Fri Apr 30, 2010 11:32 am    Post subject: Reply with quote
http://www.ranchotransaxles.com/service.html
Dale
jfats808
jfats808 is offline
PostPosted: Fri Apr 30, 2010 11:38 am    Post subject: Reply with quote
Just wondering.....but off road racing how often would you even be using 5th with a 914 tranny that may have a lower gear ratio than a type 1? I've rode in a buggy in the sand and being a lighter frame I hung mostly in 1 and 2 and very rarely in 3rd. A 6 rib bus tranny would likely suit your needs. Are you going to be entering races?-Jon
2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
( o\_/o )
PostPosted: Fri Apr 30, 2010 11:52 am    Post subject: Reply with quote
endurance racing in the desert, dunes, light trails through the woods, rally races, w/e i feel like doing
( o\_/o )
PostPosted: Fri Apr 30, 2010 12:01 pm    Post subject: Reply with quote
dale thank u for the link!
Hotrodvw
Hotrodvw is offline
PostPosted: Fri Apr 30, 2010 12:38 pm    Post subject: Reply with quote
You'd have to run an unlimited class to run a turbo for off road racing......IF turbos are even allowed. The abuse an off road trans sees is substantial. Thru the bump on the gas is hard on them. Also, any trans will hold a 250hp engine, if you drive the car like it came from the factory. A split case trans will work....for a short while. Now, if you want it to last, that's a completely different story! Call Rancho, or any other well reputed trans builder and tell them what you're going to do with it. Let them give you suggestions on what you'll need to accomplish your desires.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
vwracerdave
vwracerdave is offline
PostPosted: Fri Apr 30, 2010 1:47 pm    Post subject: Reply with quote
I don't know where you are getting that a stock type I transaxle will handle 250 HP but that is incorrect. You need to start upgrading them around 100 HP.
If your really serious about off roading a 250 HP type IV, you need to step up to the plate and buy a Mendeola transaxle.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Fri Apr 30, 2010 2:01 pm    Post subject: Reply with quote
BS, my stock 6v trans lasted with 150 lb ft of 1915 turbo going through it, and I never broke anything. Just the same, I replaced it with a Pro Street. Still have the same axles, though.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
vwracerdave
PostPosted: Fri Apr 30, 2010 3:07 pm    Post subject: Reply with quote
How much off road racing do you do?
How many passes down the drag strip have you made?
Hotrodvw
Hotrodvw is offline
PostPosted: Fri Apr 30, 2010 3:12 pm    Post subject: Reply with quote
Do you seriously think the only answer is a $6k transmission???? Laughing
'67 Sunroof
Eric
lots of money!
Hose & Fittings
vwracerdave
PostPosted: Fri Apr 30, 2010 3:20 pm    Post subject: Reply with quote
Yes, if the guy is serious about 250 HP.
Hotrodvw
Hotrodvw is offline
PostPosted: Fri Apr 30, 2010 3:24 pm    Post subject: Reply with quote
Maybe we should introduce you to the 091 bus trans, 930 CV's, microstub axles, etc.... Many have done it, and still do with no more than $2500 invested. He CAN make it work for a lot less than a Mendy.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
RailBoy
RailBoy is offline
PostPosted: Fri Apr 30, 2010 4:15 pm    Post subject: getting a transmission to hold more HP/Torque Reply with quote
Yea I agree with VWDave, I would not short cut the tranny in any fashion, if the guy is willing to go all out on the serious engine, he must have a worth wild car that can hold up, thus may as well have the right tranny for the job.
Ever been stuck 50 miles from the closest person when thing go bad? Thing is things can go bad when they want, racing or just roaming around..
I blew a tranny once that held together till the next day I started the engine, thing is is would not go into gear or anything, weird thing is it got me home, must of had some stress cracks that developed further into fractures.
All I am saying is if he has the bucks for a Type 4 Wild Motor, don't talk him out of some clearity of mind, you are not the one out in the desert, this guy is and trust me, he is looking for valid input, not B.S.
50 miles is a long way on foot regardless of the weather and preperations.........
Oh by the way, side step your clutch a few times at RPM's see how many times you can do it, think that is the point on applying HP to what ever surface you are riding on.... They all break sooner or later, may as well put it off as long as possible is my stand point and I guess Wild Eyes as well........ RB
bugninva
bugninva is offline
PostPosted: Fri Apr 30, 2010 5:20 pm    Post subject: Reply with quote
i was quoted 3500 for a transaxle to hold the power of my street turbo engine... not a transaxle that will "work", but one that will do the job, do it right, and do it for quite some time... that's just the transaxle, not the axles and such... but you know what? when you have 9-10K in an engine, why would you cheap out on the transaxle?
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
RailBoy
RailBoy is offline
PostPosted: Fri Apr 30, 2010 5:40 pm    Post subject: getting a transmission to hold more HP/Torque Reply with quote
I am interested in hearing which case it is based around....
I do like the idea of the Berg 5-Speed in a bus box set-up, but I thought a clear cut off for that set-up is around 225 HP, this is based on the longer
out put shaft or what ever it is called, twisting off, they do have the optional chromoly one available but I am not sure of HP ratings..
This is all hear say, i have never spoken with Berg about there 5 Speeds, but I do know when in a bus box you can pop wheelies,lol..
Thing is in the past Porsche Tranny's have been run and even 914's suposedly.. Just takes a little re-gearing or just have the engine to turn it over...
Point is the Mendeola Trannys are nice and they have been used with most power plants that are out at some point in the past....
Thing I am worried about with any tranny I run or will run, is cracking the case, not ripping out the gears........ RB
Hotrodvw
Hotrodvw is offline
PostPosted: Fri Apr 30, 2010 5:44 pm    Post subject: Reply with quote
Berg 5's are not known for their strength.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
RailBoy
RailBoy is offline
PostPosted: Fri Apr 30, 2010 5:46 pm    Post subject: getting a transmission to hold more HP/Torque Reply with quote
As noted....... RB
Billyisgr8
Billyisgr8 is offline
PostPosted: Fri Apr 30, 2010 5:49 pm    Post subject: Reply with quote
If you treat the stock tranny well, it will last . Mine is a living testament. 1973 SSC irs over 300 track launches 100+ launches with slicks, 60' in the 1.71 - 1.9 with slicks. Just went 11.9 behind my turbo 2110. I keep my slicks at 22 pounds, and preload hard, as in the back of the car squats 2 " when I am at the tree waiting for the lights
Check out my youtube page, 14 videos of beating on the tranny.
http://www.youtube.com/user/Billyisgr8
Kevin
RailBoy
RailBoy is offline
PostPosted: Fri Apr 30, 2010 5:58 pm    Post subject: getting a transmission to hold more HP/Torque Reply with quote
Your not pushing it hard enough,lol... A 73 Stockers have the fine tooth gears which rip out easier than the pre 69's I think which are the corser geared design which can take way more punishment......
I think it is pre 69 that was the last of the dual side cover cases then after that they went to the fine tooth gearing and single side cover cases which are actually stronger than the dual side covers... This is all bug cases mind you....
What does SSC stand for may I ask, or is this something I am supposed to already know,lol....
I got it, Single Side Cover, Sorry about that, you are running a built tranny like mine if you are not ripping out the fine tooth gearing is all I can say or you are delicate on it,lol...
I run 8" and 10" wide rears on my rod, thus keeping the tranny together is the objective for me at all costs.... RB
bugninva
bugninva is offline
PostPosted: Fri Apr 30, 2010 6:00 pm    Post subject: Re: getting a transmission to hold more HP/Torque Reply with quote
RailBoy wrote:
What does SSC stand for may I ask, or is this something I am supposed to already know,lol.... RB
single side cover.... 73-up
GEX has. Just sayin
Page 1 of 4
