If I run Super Cool tins, do I need the heater channel tins?
Page: 1, 2, 3  Next
Chris Paterson
Chris Paterson is offline
PostPosted: Thu Aug 19, 2010 10:38 pm    Post subject: If I run Super Cool tins, do I need the heater channel tins? Reply with quote
So if I run these:
Do I need these?:
This is a 1600dp motor with heater boxes. Maybe it's a stupid question d'oh!
- Chris
58' PGSG
Teeroy Premium Member
Teeroy is offline
PostPosted: Thu Aug 19, 2010 11:13 pm    Post subject: If I run Super Cool tins, do I need the heater channel tins? Reply with quote
If you are running the engine as an upright type 1 or 2, do not use the first pictured tins, but do use the second on any type if you are using the heater boxes or J tubes and industrial tins.
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Aug 20, 2010 5:14 am    Post subject: Reply with quote
Super Cool Tins are actually Type 3 tins. Type 3 had the fan in the back of the engine blowing across the cylinders. A Type 1 has the fan on top blowing
down.
So you should use Type 1 tins on a Type 1.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
lupin..the..3rd
lupin..the..3rd is offline
PostPosted: Fri Aug 20, 2010 7:12 am    Post subject: Reply with quote
The sleds keep the thermostat in the warm air stream, direct the hot air out the back end of vehicle, and also protect the pushrod tubes from road debris.
I've seen several threads on here of people with damaged push rod tubes from running over a truck tire, tree branch, etc. Invariably, they omitted the sleds which would have protected them from this damage.
My vote is to use the correct type 1 tin, and to keep ALL of the tin pieces, it's all there for a reason.
Mr. 010
Glenn is offline
PostPosted: Fri Aug 20, 2010 7:24 am    Post subject: Reply with quote
It's one or the other.. .not both.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Chris Paterson
PostPosted: Fri Aug 20, 2010 1:05 pm    Post subject: Reply with quote
Ok got it! They market the "Super Cool Tins" as if they are superior for all applications.
- Chris
58' PGSG
craigman
craigman is offline
PostPosted: Fri Aug 20, 2010 1:09 pm    Post subject: Reply with quote
Actually they work very well on upright cooling.
A lot of people where i live run them with great sucess. And we see temps in the 115-118 in the summer.
Mr. 010
Glenn is offline
PostPosted: Fri Aug 20, 2010 1:11 pm    Post subject: Reply with quote
Then how come VW didn't use them on the Type 1 engine?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
craigman
craigman is offline
PostPosted: Fri Aug 20, 2010 1:12 pm    Post subject: Reply with quote
Glenn,
i guess you would have to ask VW.
All i know is people around here have had great sucess with them.
[email protected]
john@aircooled.net is offline
PostPosted: Fri Aug 20, 2010 1:27 pm    Post subject: Re: If I run Super Cool tins, do I need the heater channel t Reply with quote
Sled tins
Keep your PR tubes from getting hit with road debris
and
allow the thermostat to work properly, by not getting "cooled" by under-car air as you drive
and
The engine runs COOLER (when hot) by creating a low-pressure exit for the hot air to quickly vacate the area under the heads and cylinders.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
donmurray
donmurray is offline
PostPosted: Fri Aug 20, 2010 1:30 pm    Post subject: Reply with quote
Can you fit sled tins on an engine with A1 Sidewinder exhaust and heater boxes? No thermostat planned, but may have some flaps that are fixed open.
74Superveedub
74Superveedub is offline
PostPosted: Fri Aug 20, 2010 2:03 pm    Post subject: Reply with quote
Question... I see you guys saying not to use the super cool tins, but No one really said why besides they are for a type 3. So, Why are they no good for a type 1? Do they not cool better?
craigman
craigman is offline
PostPosted: Fri Aug 20, 2010 2:09 pm    Post subject: Reply with quote
All i can say is what i've personally seen and used.
Works for me.
People like Gleen say things like that without trying it for themselfs.
74Superveedub
PostPosted: Fri Aug 20, 2010 2:27 pm    Post subject: Reply with quote
Well I trust what Glenn says, he knows his stuff. I'm just looking for a why they work, or why they don't, not just because its from a different engine.
Mr. 010
Glenn is offline
PostPosted: Fri Aug 20, 2010 2:32 pm    Post subject: Reply with quote
Sorry to tell you but you are wrong. I had a set of type 3 tin on my 1904 and it ran on the warm side. When I took the heads off to fix something and I replaced the type 3 tins with type 1 tins.
Guess what.... My engine ran cooler.
So don't assume next time, just ask.
The Type 3 has the air blowing across the cylinders and not down like the Type 1. The tins are different because the cooling system is different.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bugnut68
bugnut68 is offline
PostPosted: Fri Aug 20, 2010 2:34 pm    Post subject: Reply with quote
Works for me.
Jake Raby has performed tests involving these tins, may want to ask him his thoughts as his research and testing has been extensively documented.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
craigman
craigman is offline
PostPosted: Fri Aug 20, 2010 3:21 pm    Post subject: Reply with quote
Yes, i know Jake has googles of data.
All i was saying what i have seen and used in my own personal car and talked with others in my area that use them.
Mr. 010
Glenn is offline
PostPosted: Fri Aug 20, 2010 3:29 pm    Post subject: Reply with quote
Whatever works.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Vee Dub Nut
Vee Dub Nut is offline
PostPosted: Fri Aug 20, 2010 3:31 pm    Post subject: Reply with quote
Bob Hoover had good things to say about them Wink
http://bobhooversblog.blogspot.com/2006/11/vw-kool-tin.html
"I think it would be very difficult to not get better cooling using tighter lower shrouding, unless you installed it in such a manner that it could come loose. Some of the most valuable time you can spend would be to study the lower shrouding on the Corvair, VW Type IV, and most aircraft engines enclosed in pressure-cowlings. When you compare these more efficient cowling methods to the early VW engine it will make the short-comings of the deflector plates painfully evident."
Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut
craigman
craigman is offline
I totally agree!
Glenn, you said you noticed higher temps with the "cool tins",, was this oil temp or head temp?
Page: 1, 2, 3  Next
