82-T/A Samba Member
Joined: March 23, 2004 Posts: 183 Location: Fort Lauderdale, Florida
Posted: Fri Sep 17, 2010 11:54 am Post subject: A few questions, A/C, suspension, brakes... |
Hey guys,
I've been back in school for the past year and a half, and through pretty much most of that time, my Bus has just sat in the garage without being started. I'm going to have a bit more time soon, and I'd like to figure out a couple of small issues I'm having, and make some decisions.
1 - First, I have a problem with my brakes. It developed slowly over time, and now it's flat-out. When I apply my brakes, the rpms shoot up, and I get no brake assist at all. Without having done ANY diagnostic work at all, I'm assuming that perhaps this means the diaphram in my brake booster is shot and that I need a new brake booster. Is there a quick way to verify this? Where's the best place to go? It seems like they don't sell new ones?
2 - The second thing is, the rear end of my Bus sags a little bit. Not much, but it does still sag somewhat. What do I need to do to fix this? In my 2002 Ford Explorer Sport, the rear-end used to sag a little bit. The option was to replace the leaf springs, or just buy a pair of air shocks and use them to adjust the proper ride height. That worked well for my Explorer. I looked on Rock Auto and couldn't find any air shocks for the VW Transporter. I did a search on here and found that someone said to use adjustable spring shocks. Is that still the best option? What do I need to do to actually fix this problem correctly?
3 - I'm thinking about installing A/C in my Bus. It's not a huge priority really, but seeing something like 30 Bay busses go through my local junkyard over the past 5-6 years, I've snagged pretty much everything I need. I've got a Bosch A/C compressor with a bracket that allows me to mount it flush to the side of the Type-4 block (incidently, the previous owner of my Bus actually had a huge chunk of sheet metal cut out which I replaced with tin-work). I also have this massive dash component that sits directly underneath the factory dash. It actually looks pretty decent. It comes complete with two hard-core heavy duty blower fans and the adaptor pieces to connect the unit to the fresh-air ducts from the front of the Bus. (also intercepts the hot air coming from the heater blower fans and delivers it through there too, with or without A/C.
It looks something like this (not my bus), but matches the dash much better.
http://www.joescoolcars.com/images/Pic54.jpg
Anyway, I know how an A/C system works, and it appears as though at one time in my Bus's life it might have had this anyway. I'm just curious to hear from you guys what you think about having A/C in your Bus. What kind of drain does it have on the engine. Anyone have one of these under-dash mounted units like this? How do you like it? I haven't seen anything like it anywhere else, but it matches the factory dash in my 73 Bus exactly. The texture, the color of grey / charcoal matches my dash exactly, everything.
Thanks!!! _________________ Todd,
(Fun cars)
2002 Ford Crown Victoria LX-P74
1987 Pontiac Fiero SE / V6
1973 Volkswagen Type-2 Transporter |
Opossum Samba Member
Joined: February 26, 2005 Posts: 757 Location: Islets of Langerhans
Posted: Fri Sep 17, 2010 1:06 pm Post subject: Re: A few questions, A/C, suspension, brakes... |
82-T/A wrote: |
Hey guys,
What kind of drain does it have on the engine. Anyone have one of these under-dash mounted units like this? How do you like it? I haven't seen anything like it anywhere else, but it matches the factory dash in my 73 Bus exactly. The texture, the color of grey / charcoal matches my dash exactly, everything. |
Very little drain on the engine, if you use a newer style compressor (not the original York). Yes, mine is an under-dash evaporator and it works great! It actually gets too cold.
For most campers, VW dealers used one of two different styles of under-dash units made by DPD. There is also a jump seat evaporator (on some campers) and an overhead unit (mostly for the station wagons). _________________ "You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner |
82-T/A Samba Member
Posted: Fri Sep 17, 2010 1:25 pm Post subject: Re: A few questions, A/C, suspension, brakes... |
Opossum wrote: |
82-T/A wrote: |
Hey guys,
For most campers, VW dealers used one of two different styles of under-dash units made by DPD. There is also a jump seat evaporator (on some campers) and an overhead unit (mostly for the station wagons). |
Yes!!! That's what it is. The one I have says "dpd" on it... I think even in lower case. It's definitely old-school looking. Looks like it's from the 70s.
Thanks for that information! I don't know what kind of compressor I have other than that it's a Bosch. It looks fairly new though, and isn't very large. It seems to be made entirely of aluminum, but no idea really.
(Fun cars)
aeromech Samba Member
Joined: January 24, 2006 Posts: 17653 Location: San Diego, California
Posted: Fri Sep 17, 2010 2:03 pm Post subject: |
1) The booster's bad.. If you hurry you might be able to send it to the guy in Texas before he retires.
2) Coil over shocks are the quick and dirty way to fix the sag. The best way is to adjust the torsion bars/spring plates.
3) A/C = good luck with that mod. Sounds like a lot of work. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
moxnix Samba Member
Joined: September 11, 2003 Posts: 667 Location: Mpls Minn.
Posted: Fri Sep 17, 2010 2:07 pm Post subject: |
IMHO 9 out of 10 buses that had the rear torsion bars adjusted didnt need it. Lots of fussy work to do it too.
They are designed to sit nose high so when you have 2 people up front they run level going down the road.
My bus had its rear bars indexed up by the PO- and if I had the time to fart around with it I'd put it back to stock.
When I bought the thing it destroyed brand new rear tires in a matter of days because the rear wheels were toed in so far before I figured out what he did. (this toe-in issue was corrected by a shop in Phoenix not me- I was on a road trip)
Also it makes the rear suspension verrrry stiff and when I'm driving with a passenger the front rides pretty low with the tail up in the air...
Get some decent (stock) shocks and call it a day _________________ Ritterlich im Kriege, wachsam für den Frieden |
Posted: Fri Sep 17, 2010 2:14 pm Post subject: |
moxnix wrote: |
Get some decent (stock) shocks and call it a day |
Sounds to me like it was raised too high. I've done the job a few times without these problems. All you need is about one spline up or so. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
