skabonner Samba Member
Joined: May 12, 2009 Posts: 854 Location: La Habra, Ca
Posted: Sun Nov 07, 2010 7:45 pm Post subject: Oil Sump |
Ok, this has probably done, but what are the benefits of an oil sump? I heard it can keep your oil pressure up during hard corners. Would it also keep temps down? Would I not be able to slam my bug anymore? _________________
| Douglas Adams wrote: |
| A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. |
'68 Beetle "Sadie" (R.I.P.)
'67 Beetle "Ilsa"
'06 Gti "Heidi" |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80683 Location: Sneaking up behind you
Posted: Sun Nov 07, 2010 7:51 pm Post subject: |
Prevents oil starvation in the corners and hard acceleration.
It really doesn't keep the oil any cooler. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sun Nov 07, 2010 8:00 pm Post subject: |
Ok. How hard is it to install? I realize I would have to drain the motor, remove the current the sump, but what else? _________________
'67 Beetle "Ilsa"
'06 Gti "Heidi" |
Glenn  Mr. 010
Posted: Sun Nov 07, 2010 8:02 pm Post subject: |
Bolt it to the bottom of the case and put on the pickup extension.
Maybe 2 hours if you're really slow and drink a few beers. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sun Nov 07, 2010 8:10 pm Post subject: |
Cool. Sounds easy. Any suggestions about the size? I've got a 1600dp, all stock. I assume I don't need a big one. _________________
'67 Beetle "Ilsa"
'06 Gti "Heidi" |
Glenn  Mr. 010
Posted: Sun Nov 07, 2010 8:14 pm Post subject: |
I have a 2180 and a 1.5qt sump. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sun Nov 07, 2010 8:17 pm Post subject: |
Ok. Thanks for all the help. _________________
'67 Beetle "Ilsa"
'06 Gti "Heidi" |
PSScoots Samba Member
Joined: January 06, 2007 Posts: 505 Location: Chattanooga TN
Posted: Sun Nov 07, 2010 11:28 pm Post subject: |
Any problems with reduced ground clearance for a car with factory stance? _________________ Rebuilt to drive not decorate. -VOLKSWAGNUT
"Service the car and it will give you good service." |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16828 Location: State College, PA
Posted: Mon Nov 08, 2010 4:29 am Post subject: |
| Quote: |
Anytime you hang something on the bottom of the engine, you decrease ground clearance. But I am running one on our buggy (which is dropped slightly) and on my project, which is also dropped. No problems on either, but I also use some common sense and dont run down cow paths with 6" deep ruts. A stock car would be better.
The sumps always bring out debates, but my feeling is that adding oil capacity is always a good thing - more oil means that it gets beat up less by the engine. And as Glenn pointed out, having that reservoir would reduce oil starvation when cornering. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
Glenn  Mr. 010
Posted: Mon Nov 08, 2010 7:04 am Post subject: |
I've had one for 30 years and never had a clearance problems... the rear is lowered 1". _________________ Glenn
Member #1009
#BlueSquare
pupjoint Samba Member
Posted: Mon Nov 08, 2010 8:10 am Post subject: |
| i guess it all depends on how the roads are in your area. i never had any issues with sumps myself. |
