Rear brakes locked?
deronmoped
deronmoped is offline
PostPosted: Thu Dec 23, 2010 11:44 pm    Post subject: Rear brakes locked? Reply with quote
Today my rear brakes locked up on me.
I had just gotten off the freeway and was stopped at a light. As I pulled away from the light I noticed the rear brakes dragging. They kept getting worse, I had to pull over. At this point I could smell the brake linings and a very small amount of smoke was coming off the rear brake drums. I let them cool for a few minutes and then climbed under the Bus and took a wrench to the proportion valve side for the rear brakes. A little fluid came out and I could hear the brakes release fairly loudly. At this point I was able to drive away and the brakes were working correctly all the way home.
What the heck is going on? I know the proportion valve is supposed to hold like ten pounds of pressure on the rear brakes so as to make them react quicker. The only thing I can think of is this valve was holding too much pressure this time. I guess I should tear it apart and see what is going on.
Anybody have similar problems.
Thanks, Deron.
Wildthings
Wildthings is online now
PostPosted: Fri Dec 24, 2010 12:29 am    Post subject: Reply with quote
The proportioning valve decreases the pressure to the rear brakes in proportion to the front during hard braking to keep the rear wheels from locking. I don't know that it hold any pressure against the rear brakes at all. That is certainly not its job.
If your brake pedal doesn't return all the way or something blocks one of the ports in the master cylinder you will get brake dragging.
SGKent Premium Member
SGKent is offline
PostPosted: Fri Dec 24, 2010 7:33 am    Post subject: Reply with quote
bad Master Cyl is my best guess. One of the cups blocked the rear port. Proportioning value has a big ball bearing in it that reduces pressure. Check the booster and pedal assembly to be sure it fully returns - that the floor mats haven't jammed the pedal a little or the return spring isn't broken before you replace the master.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Dec 24, 2010 7:41 am    Post subject: Reply with quote
i would check the rubber hoses too. had one go bad on my single cab. but hell it was 40 years old. did the same thing your talking about
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
1975 Kombi
1975 Kombi is offline
PostPosted: Fri Dec 24, 2010 8:06 am    Post subject: Reply with quote
Second on that. The inner lining can go bad and block the return of fluid. The outer rubber may look ok but the inner lining may have deteriorated.
Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v
enjoispammy8
enjoispammy8 is offline
PostPosted: Fri Dec 24, 2010 11:02 am    Post subject: Reply with quote
start with the hoses and work your way back from there.
1969 Westy, 1690cc. montana red and cloud white.
1969 Standard Beetle [sold]
Watch My Movies: https://www.youtube.com/user/taylorlikesacdc
Desertbusman wrote:
Is there a message here? Enjoy Spammy Ate
EZ Gruv wrote:
Way to fuck up some little kids riding in the car next to you.
hazetguy wrote:
you need to be doing better drugs.
View user's profile Send private message Send e-mail AIM Address Facebook Gallery Classifieds Feedback
SGKent is offline
PostPosted: Fri Dec 24, 2010 11:16 am    Post subject: Reply with quote
you wouldn't think both read hoses would fail at the exact same moment. On principal all the rubber brake hoses should be replaced on a 30+ year old car.
1975 Kombi
PostPosted: Fri Dec 24, 2010 11:22 am    Post subject: Reply with quote
Small piece of rubber blocking the return at the rear union.
Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
2011 Touareg TDI
2001 NB TDI
deronmoped
PostPosted: Fri Dec 24, 2010 11:39 am    Post subject: Reply with quote
I doubt it's the hoses, could be the pedal is not coming all the way up. If you read my post again, I released pressure at the rear brake line attachment to the proportion valve. If the pressure was blocked at the hose, what I did would have not released the pressure. Plus it would have to be both hoses failing at the same time.
I'm going to check the free play and make sure the pedal returns all the way.
Deron.
SGKent is offline
PostPosted: Fri Dec 24, 2010 12:02 pm    Post subject: Reply with quote
as the master cyl is pressed, the cups move forward and cover a small port that leads up to the reservoir. When the cups return to rest that port is unblocked so excess fluid can return to the reservoir and the rear pistons fully retract. There is fluid that gets behind the cups as well. When debris blocks that port (one for front and one for back) the fluid behind the cups can't return to the master so it moves past the cups because of the way they are built. It collects on the front side where pressure is less and holds the brakes engaged.
Those small ports can be blocked by the MC not returning as you suspect, or by debris - such as s small piece of rubber torn or worn from the cup.
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Dec 24, 2010 7:20 pm    Post subject: Reply with quote
Good idea to check the play between MC and the pushrod.
Still replace ALL the flex lines. For the rear there are three. One for each side and the center one that if it goes bad both rear brakes lock up.
Any flex line that is over five years old is a problem just waiting to happen...
In Stereo, Where Available!
wampe
wampe is offline
PostPosted: Fri Dec 24, 2010 8:42 pm    Post subject: Reply with quote
Maybe the brake shoes are adjusted too tight.
Desertbusman
Desertbusman is offline
PostPosted: Fri Dec 24, 2010 10:35 pm    Post subject: Reply with quote
Pull the rear drums and give everything a good inspection. Might be time for a complete rebuild of your brake system.
71 Superbug
71 Westy
Tom Powell
Tom Powell is offline
PostPosted: Sat Dec 25, 2010 11:52 am    Post subject: Reply with quote
the parking brake handle/cable was not fully releasing, causing the right rear to drag and .. new ..
SGKent is offline
PostPosted: Sat Dec 25, 2010 1:08 pm    Post subject: Reply with quote
looks like time for new shoes and maybe drums too.
wampe
wampe is offline
PostPosted: Sat Dec 25, 2010 1:28 pm    Post subject: Reply with quote
Glad you found the problem. It looks like you need a total brake rebuild back there. Did the drums get scored? I did the brakes on mine recently. Replaced shoes, wheel cylinders and hardware. My drums were good. It was a pretty standard brake job, nothing really strange. I would check the front brakes also, they may be as old as the rear.
deronmoped
PostPosted: Tue Dec 28, 2010 12:44 am    Post subject: Reply with quote
I picked up a spring kit for the rear drums. I know the shoes are in good shape as I installed them not too long ago. Weak springs could cause the shoes to not return all the way. Well take a look see and if there is anything else wrong, I will take care of that.
When it rains it pours. Turns out, on the way home my clutch started going, was stuck in bumper to bumper traffic, did make it home though. It was the cable that was frayed and stretching, easy fix.
Deron.
wampe
wampe is offline
PostPosted: Tue Dec 28, 2010 10:08 am    Post subject: Reply with quote
Maybe it's just the photo but it doesn't look like there is any lining left on the shoes. What is left is saturated with fluid which means they won't stop very well. I would recommend a total rebuild. It's best to be safe.
Wildthings
PostPosted: Tue Dec 28, 2010 10:29 am    Post subject: Reply with quote
The return of the parking brake cable is partially done by the spring on the cable itself. If the cable is not returning then replacement of the cable itself is probably in order.
A sticking parking brake cable is not going to cause any residual pressure in your lines, so fixing the parking brake will likely not correct your original problem.
I agree with others, from the pictures it doesn't look like there is any lining left at all, maybe its just the angle and shadows though. It does look like there is something leaking, maybe brake fluid or maybe wheel bearing grease. Slave cylinders and wheel seals may be in order.
germansupplyscott
germansupplyscott is offline
PostPosted: Tue Dec 28, 2010 10:35 am    Post subject: Reply with quote
Tom Powell wrote:
is this photo of the OP's actual bus as it stands?
i agree that it appears that there is no lining at all on the shoes. maybe be a trick of the photo but that's what i am seeing. also agreed that those brakes need to be rebuilt.
SL
