VWeGoBeachNow Samba Member
Joined: May 12, 2010 Posts: 197 Location: CRUISING DOWN PCH IN THE OC
Posted: Tue Jan 11, 2011 2:17 pm Post subject: Rear Heater Replacement Checklist |
So I plan on changing out my old rear heater core with a new one from VC. It says it comes with a bleeder screw and o-ring.
Some questions I have are.
Is the Rear Seat Heater Core Bleeder Valve the same as the bleeder screw?
Should I replace the Rear Seat Heater Core Control Valve and Heater Core Hose Tee as well?
I will be replacing the the o-ring between heater core and control valve too.
Thank You! _________________ 88 Wolfsburg Limited Edition Vanagon GL Tin Top
Vesuve Grey underneath cheapo Vesuve Grey paint job
2.1 L
4spd |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2074 Location: Ontario Canada
Posted: Tue Jan 11, 2011 6:09 pm Post subject: Re: Rear Heater Replacement Checklist |
[quote="VWeG
1- Yes
2- not if the control works fine
3-no _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
tschroeder0 Samba Member
Joined: April 14, 2008 Posts: 2098 Location: Boulder CO
Posted: Tue Jan 11, 2011 6:25 pm Post subject: |
| While you're at it replace the T's that the lines come off of, they will be brittle by now (TK sells them) they are another one of those parts that can stop you in your tracks if they break...btw use the correct one's not the one's that can be bought at the FLAPS, trust me I know! |
Posted: Wed Jan 12, 2011 12:46 pm Post subject: |
| tschroeder0 wrote: |
How many T's do I need to replace? Is the T underneath or inside the car?
How messy is this job? Should I be ready for coolant spilling out?
Thanks to all!!!! _________________ 88 Wolfsburg Limited Edition Vanagon GL Tin Top
2.1 L
4spd |
Posted: Wed Jan 12, 2011 1:10 pm Post subject: |
| VWeGoBeachNow wrote: |
Thanks to all!!!! |
There are two tees underneath and yes you are going to loose some coolant. |
Posted: Wed Jan 12, 2011 10:18 pm Post subject: |
| Wildthings wrote: |
Thanks to all!!!! |
I couldn't find the 2 tees underneath. Anyone have a picture?
Thanks _________________ 88 Wolfsburg Limited Edition Vanagon GL Tin Top
2.1 L
4spd |
Terry Kay Banned
Posted: Wed Jan 12, 2011 10:58 pm Post subject: |
The T's are on the passenger side, under the Van, kinda along side the trans--maybe a little behind it.
If you haven't crawled under the Van you aren't gonna see them.
Follow the heater hoses forward from the engine--you'll find them. _________________ T.K. |
Posted: Thu Jan 13, 2011 12:07 pm Post subject: |
| Terry Kay wrote: |
Follow the heater hoses forward from the engine--you'll find them. |
Thank You TK
It's nice and warm here in so cal so I get a chance to mess around
underneath. _________________ 88 Wolfsburg Limited Edition Vanagon GL Tin Top
2.1 L
4spd |
